Question about Motorola Computers & Internet
Show connections back of SBV 5222 modem
Show connections back of SBV 5222 Motorola modem from Cablevision
What do i do next
No that is simply showing that there is signal coming from the router. If the router has no incoming data or communication it can't connect even limited.
Apr 09, 2014 | Arris Tm802 Cable Modem For Cablevision
My computer does not recognize my modem so I can send a fax.
2 completely different technologies.
FAX uses phone line (analogue) and router is digital.
It's one or the other.
Plugging what is essentially a modem into another modem was never going to work.
Scan and email is much faster and easier.
Or FAX to FAX through phone line.
May 14, 2017 | Computers & Internet
Hi I have the Motorola SBV 5120 cable modem and it is currently connected to my PC with Cat 5 cable and my internet works fine. I want to make a wireless connection to my laptop which is 802.11 a/b/g/n...
The SBV5120 is simply a device that converts your cable internet signal to a RJ45 computer output that connects to your single PC
It also has two RJ11 phone jacks if you use the modem as your home phone as well. It has no wireless function,
For you to have a wireless connection, you will need to purchase a Wifi Router. These can easily be got at any local computer store or a big box retailer like Best Buy, Staples, Computer City etc,
Most come as a 4 or 8 port wifi router, your choice will be the number of wired connections. In your case it looks like one.
Once you have your router, connect the Modem RJ45 to the WAN input on the router and your PC to one of the LAN ports on the router. In its default state, it should connect you to the internet as normal.
The router will have setup instructions which you can use after you connect the modem and PC.
Nov 05, 2017 | Arris SURFboard SB5120 Modem
Error 103
This may or may not be of help, but this is easy enough to try....
Power off computer, cable modem, and router.
Connect router to cable modem via WAN port, PC to router via LAN port
Power up cable mode first, wait until for connection light
Power up the router, wait about a minute
Power up the PC
I have Cablevision and have had an issue when you are going to connect a different device directly to the cable modem (eg router instead of PC), you need to reset the cable modem first or it will not work.
The following link shows you how to log directly into the router and run the setup Wizard from the router.
http://www.trendnet.com/kb/kbp_viewquestion.asp?ToDo=view&questId=1442&catId=524
Apr 09, 2011 | Trendware TRENDnet TEW-432BRP Cable/DSL...
I have a RCA Thomson DHG 535-2 without the disk for the installation and the ethernet wont help everything is hooked up etherent/cable to tv power yes... and that's about ti all im really missing is the...
Thomson Cable modem has an ethernet connection...
The ethernet connection goes to your computer via a standard Cat5e patch cable. There is no USB that I know of...
Cablevision wire goes to the modem. It should be the first device on the cablevision wire. If you need a splitter, it needs to be a GOOD one, connected DIRECTLY to the incoming Cablevision wire as it enters the house. Use good copper wire.
Order of events:
Connect the cablevision wire to the Modem.
Connect the Ethernet cable to the computer and the modem.
Power on the cable modem.
Right click the network Icon near the clock and click 'repair' (Or reboot the computer)
Apply for and get an account for cable Internet from your Cable company.
After a few days, cable Internet should work.
Apr 16, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
What does it mean if the link light is out on the surfboard v 5222 digital voice modem?
The link LED on the LAN card and/or on the hub/router is switched on then it indicates that the communication between the the computer and hub/router is established and therefore data can transfer between computers, hun/router, Internet etc.
If the link LED light is out then the fault could be a faulty LAN cable or faulty LAN card in the computer or a faulty hub/router.
Nov 15, 2009 | Motorola Computers & Internet
Slow download speed on motorola SB4200
open the internet explorer2_bing.gif on the addresss bar put 192.168.100.1 then go to hack add on file adress file d11_m_speedtierextreme2_c01.cm
then on ip server file put 68.87.68.35 the press change id then unplug the modem then plug it back the speed should be back
Jan 17, 2009 | Arris SURFboard SB4200 Modem
Motorola 4200 modem
ya switching back this cable modem would be tough bcoz of the battery back up
you hav two choices 1) remove battery and put it back up
2) with power nad everything connected to modem just unscrew the cable wait for 30 sec n screw it back in
Oct 30, 2008 | Arris SURFboard SB4220 Modem
Comcast Cable Modem with Polycom Soundstation Premier
Try adjusting the ringer volume, dial tone volume, and speaker volume. Make sure that the ringer type selection is not set to off. Also make sure that you are not bridging your call.
You can also use the Upgrade feature built into the phone to look for updates which may resolve your issue.
If this has only started happening recently, Restore the default settings and see if it resolves your issue.
Mar 20, 2008 | Polycom SoundStation
Computers & Internet Logo
694 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
