Question about Kitchen Ranges
When you try to use the oven the igniter glows but it takes about 5 min before the oven burner lights and when it does light the gas fame is low and you can hear it sputtering. The oven never gets up to temp.
  • 999 Answers
You have a weak ignitor and the valve is not opening completely. Replace the ignitor.
eric
Posted on Jul 04, 2009
I have a 5 burner gas range and cooktop one burner on cooktop won't start
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Apr 12, 2014 | Kenmore Elite Stainless Steel 40" Dual...
Igniter starts to glow for 3-5 sec while making noise every minute or so
Check the thermocouple it is going bad or already has and that is why the gas valve is not staying open.
Jul 08, 2017 | Whirlpool GGW9200L Gas Dryer
My oven takes a long time to light and there is a strong smell of gas..why?
This can be caused by a weak/inop hot surface igniter ,defective gas control valve or debris in the burner orfice/venturri. The gas odor is going to be caused by unburned gas due to a by-passing gas control valve or a weak igniter(not lighting the gas coming from burner) First you will need to verify that the hot surface igniter is coming on(you should see it glow in the burner compartment). If it is not glowing then you will need to verify that the wiring harness has voltage to it when the oven thermostat is on. Also check the igniter for any cracks or damage and if found then replace the igniter. If it is glowing then one thing that you can try(be very careful doing this) is to give the gas control valve a light tap with something hard like a wrench when the oven is turned on,igniter is glowing but the burner is not on. You will need to remove the broiler/storage drawer at the bottom of the oven. Once you pull the drawer out you should see the gas control valve at the back of the range. Try turning on the oven and lightly tapping the valve housing after the igniter is fully on. This may loosen up any debris inside the control valve housing that might be causing the by-passing problem. If the oven burner comes on when tapping the valve then try completely turning the oven on and back of several times. And when I say completely I mean turn it on after the igniter is not glowing and burner has shut off. This works about 30% of the time. If the burner control valve sticks again after trying this procedure then it could be the control valve and/or the hot surface igniter defective. The hot surface igniter would need to be disconnected from it's harness and tested with an OHM meter. Most igniters should have a 500 to 700 OHM reading. If you get a reading that is way off then the igniter is defective and replace it. If the igniter tests good then the gas control valve is suspect and replace it. Most appliance parts retailers will test your igniter for free. When the igniter is on it should glow very brightly. If it is dim then that is a sure sign it is bad. Also inspect the burner venturii and burner orfice for any possible debris(grease,lint ect) that could be restricting gas flow. One more thing you can try is to manually light the burner. Make sure the oven and burner compartment are COMPLETELY cleared out of gas. Then make sure there is a flame from a match or lighter right next to the burner where the igniter is located(it is best to use a long fireplace match) before starting oven. Once the flame is lit and next to the burner then turn on the oven thermostat and listen for the flow of gas. Once the flow has started the oven burner should light immediately! If the burner does not light within 2 seconds the remove the flame and shut down the oven. If the burner lights with the match then either the igniter is not hot enough to light the burner or there might be a restriction in the burner head blocking the flow of gas to the hot surface igniter...or a restriction in the venturri or orfice. You will need to be extremely careful performing these procedures! If you are smelling gas then the oven and burner compartment could fill up with enough gas to cause a delayed ignition! You could get burned or seriously injured so I advise you not to try these procedures if you are not experienced with gas appliances. You are taking your own risk trying these procedures and if you feel uncomfortable trying these then I suggest call a professional.
Apr 17, 2010 | Tappan TGF363 Gas Kitchen Range
Maytag Prec touch 750 lower oven takes too long to preheat
This is a common problem that happens when the oven gas control valve is sticking. This can be caused by a weak hot surface igniter or a defective gas control valve. One thing that you can try(be very careful doing this) is to give the gas control valve a light tap with something hard like a wrench when the oven is turned on,igniter is glowing but the burner is not on. You will need to remove the broiler/storage drawer at the bottom of the oven. Once you pull the drawer out you should see the gas control valve at the back of the range. Try turning on the oven and lightly tapping the valve housing. This may loosen up any debris inside the control valve housing that might be causing the problem. If the oven burner comes on then try completely turning the oven on and back of several times. And when I say completely I mean turn it on after the igniter is not glowing and burner has shut off. This works about 30% of the time. If the burner control valve stick after trying this procedure then it could be the control valve and/or the hot surface igniter defective. The hot surface igniter would need to be disconnected from it's harness and tested with an OHM meter. Most igniters should have a 500 to 700 OHM reading. If you get a reading that is way off then the igniter is defective and replace it. If the igniter tests good then the gas control valve is suspect and replace it. Most appliance parts retailers will test your igniter for free. When the igniter is on it should glow very brightly. If it is dim then that is a sure sign it is bad.
Mar 23, 2010 | Maytag MGR4452BDW / MGR4452BDQ /...
Ka gas range the glow bar comes on but it takes sometimes 15 to 20 min before gas is supplied to burner in oven and finaly ignites
Hi, this sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, if it does light the burner, there may be delayed ignition (pop), does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 22, 2010 | KitchenAid KGST307 Gas Kitchen Range
How do you light the oven? We turn the dial and
I take it the range is electric ignition because you say the top burners have a clicking(igniter) noise. If the top burners are electric ignition then the oven is also. The oven probably uses a hot surface igniter and that is why you do not hear any clicking. Turn the oven on and open the broiler compartment. You should see a bright glow from the hot surface igniter. If you do not see any glow there may be a grounding issue or the igniter could be bad. If you do see a glow but the burner does not come on in a few minutes then give the gas valve a tap with a wrench and see if the burner comes on. Shut it off and then back on several times. If the burner continues to light after this you may have fixed the problem. If it does not come on gas valve could be sticking or igniter is weak.
Sep 10, 2009 | Magic Chef 31000 Gas Kitchen Range
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
Oven Burner
try this,when you see the ignitor glow use a match and try to light the burner itself BE CAREFUL!! if the burner lights the problem is its clogged or low gas pressure.remove the burner and use brake cleaner to clean the burner AND pilot.if your using propane youll have to do this occasionally.let me know.
Jan 04, 2008 | Ovens
Oven burner delays too much to light
Zanes, Your oven igniter is getting weak. The glowing bar next to the manifold must draw between 2.7 and 3.3 amps before the safety valve will acknowledge that it's actually hot enough to ignite gas and open up. Your igniter is most likely right at ~2.5 amps and the valve is "wanting" to open, but won't without some persuasion (hammer anyone?). The part number for your igniter is 9753108 and is available. Your local appliance parts house may not carry it, but there is a substitute that they WILL carry. Its' part number is WB2x9998. It's a universal flat igniter. Unplug the oven before repairing it, OK?
Aug 01, 2007 | KitchenAid KGRT607 Gas Kitchen Range
Oven burner doesn't light
If memory serves me,there are a couple of screws on oven floor.Remove panel.Sounds like ignitor is the culprit.It feeds back to control.It may glow and light but unless it is sending full signal,gas valve will not open fully and oven will take forever to heat.
Jan 01, 2007 | Maytag MGS5870 Gas Kitchen Range
Kitchen Ranges Logo
146 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
