Frigidaire Front Load Washer
Problem for Frigidaire (ATF6000ES) Front Load Washer
Brown spots on clothes
By thewarbys on Jul 02, 2009
My frigidaire front loading washer is doing the same thing. It's very frustrating, because I can't get the spots out.
Solution #1
posted on Jul 03, 2009
Not Rated)
pob-h
Rank: Wiz
Rating: 83%, 299 votes
Brown spots indicates a bearing is breaking up, the spots are the grease from the bearing and as the seal breaks down due to the bearings going off centre, the grease gets in the drum.
Get the bearings replaced if affordable.
Was this helpful?
Yes
No
Popular Solutions for Frigidaire Front Load Washer
Questions and Unsolved Problems for Frigidaire Front Load Washer
Do you recommend Frigidaire (ATF6000ES) Front Load Washer?
Answer
Answer
Model: FWT645RHS0Cycle started and washer filled but has since stopped. Light is on but door is not... (More)
Answer
how do I fix frigidare front load washer code E20
Answer
my front loading frigidaire washer is leaking. It is a small leak on the outside plastic drum seam.... (More)
Answer
ltf2940es3 - washer will agitate and drain. It will enter the spin cycle drain.for about 2 min. THen... (More)
Answer
clothes get into pump and pump stops. Tech says we should use laundry bag, however, when I watch... (More)
Describe your Washing Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in Newport, KY
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
