Question about Maytag Dryers
TIMER DOES NOT TURN, TAKES A LONG TIME TO DRY
  • sergarace Jul 02, 2009
    I am not next to my dryer but will check later today and will let you know.
    thanks
  • sergarace Jul 06, 2009
    It was the Exhaust Vent.
    Thanks for your support!
    Genius:
  • 1,341 Answers
I assume this timer your are referring to is the control unit of this dryer.So far I have understood is that this is the control unit you are referring as a timer,which when set on turns around while sending signal to appropriate components during a drying phase.If this is so then this control unit needs replacing which is causing such delay in this process.
Posted on Jul 03, 2009
  • 355 Answers
If there's heat inside the drum the heater coils are ok. Check the exhaust vent, make sure it's not kinked or squished behind the machine and that the outside vent is not clogged with lint. You should feel air blowing freely to the outside.
If there is no heat, first check for 240V at the outlet. If you have 240V, it could be the element, the hi-limit thermostat, the thermal cut-off, the timer, the motor or a wiring issue (loose or shorted)
Good luck!.
Posted on Jul 02, 2009
  • Rohit  Asthana
    Rohit Asthana Jul 02, 2009
    check your vent it must be clean 4 inches all the way out make sure the
    damper door on the vent hood is clean easy way to track down a vent problem is to disconnect the vent and run a load if drying time improves then you have a vent problem if not reply to me and we will look at something but the vent is number 1 cause of your problem
  • Rohit  Asthana
    or
    What you have is a obstructed dryer vent. If you remove the vent hose from the unit you will see moisture inside it. This is why your unit isn't drying. If the heater has no air flow the overload is tripped. Check your vent for any blockage most of the problem
    is at the outside end of your vent. there's a flap or chicken wire you
    may find the obstruction there. Or you can use a leaf blower connect it
    to the inside vent, cover the outside vent with pantyhose. ( so you
    don't get lint allover your yard ) and you can clear your like that
    way. Good luck hope this helps
Kenmore elete model 110.67032600 timer changes to higher # and takes a long time to dry on auto dry.
I had this and it was lint trapped in door below lint filter screen.( several handfulls) Took door apart/ reassembled and he worked fine.
Oct 07, 2015 | Kenmore Dryers
It takes hours to dry the clothes. The dial moves
sounds like a bad timer. if it sticks every time replace they are expensive
Mar 25, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Model SDG305DAWW, gas unit...begins to dry and then stops...timer stops and unit continues to tumble but no heat...turn unit off and wait for about 2 hours then can dry again....replaced cycle timer,...
Sounds like you have the same problem I did. You need to replace the flame sensor. Takes about 15 - 30 minutes. You can order the part online here
Feb 06, 2010 | Maytag Dryers
Maytag Performa Electric dryer timer is bad
Look up an appliance parts store in your area. If there is no appliance store, try www.searspartsdirect.com.
If it does not turn off during timed dry then it for sure has gone bad. If it takes a while on timed dry then it is most likely that your thermal fuse/ valve coils are going bad.
Jan 14, 2010 | Dryers
Hi. Our dryer will start normally and then the
HI. This will occur when the there are issues that concern the integrity of the timer motor. This mechanism is responsible for the rotation of the timer module.It is damaged at this time, and it must be replaced asap.
A damaged timer motor will affect the nature of the drying cycle. It is the main initiator of all functions during the selected cycle.
Oct 29, 2009 | Dryers
I have a Frigidaire dryer model FDE437GHS0 It has been working fine til this morning. If I turn the timer switch to time dry and push the start button it sounds like the timer is turning(or the gears are)...
IT SOUNDS LIKE THE TIMER IS BAD. IF THE TIMER MAKES NOISE IN ANY POSITION AND GRINDS THE LITTLE TIMER MOTOR OR THE TEETH ON THE MAIN GEAR IS SLIPPING
Aug 11, 2009 | Dryers
Kenmore dryer timer will not turn.
Bad timer motor if you are using timed dry.
If using auto dry probably a bad sensor.
Verify by using any time dry or air fluff cycle and see if the timer moves.
Mar 03, 2009 | Kenmore 64902 Electric Dryer
Whirlpool electric dryer LEQ8611LG1 not drying on sensor dry.
Check your lint trap and the vent. make sure that there are no obstructions in either of them. Then take a look at your timer to since it is not stopping when you tell it too.
Feb 11, 2009 | Whirlpool LEQ8611L Electric Dryer
Maytag Nepyune not drying completely
There is a cheap PDF repair manual on eBay for this model. It is item number 200258764242.
Premmy
Oct 14, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
44 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
