Epson V700 Photo Scanner
I purchased the scanner about 2 years ago. It works fine for print scanning but I have never been able to get a decent scan from a slide. Colours in particular are nothing like original and sharpness is not good enough
I have read the manual and tried evry alternative I can think of
  • 526 Answers
Are you scanning it at the right resolution and are you using the negative holder?
Posted on Dec 20, 2009
Scanning 110 Instamatic slides on Epson Perfection V700 photo scanner
Hi Stanley - does this youtube video help?
If not, let me know and we can investigate further.
Jan 17, 2014 | Epson Perfection V700 PHOTO Flatbed...
My epson perfection scanner doesn't work since i upgraded my iMac to OSX.10.8
Make sure you have installed the scanner drivers bcos sometimes it only installs printer drivers. I suggest you install the scanner drivers again. Make sure the scanner is turned in first b4 computer.
Oct 03, 2017 | Epson Perfection V700 PHOTO Flatbed...
I am using the Epson Perfection V700 photo scanner to scan dental xrays. Sometimes the xrays come out perfect, other times I get streaks across the image. Sometimes the streaks are colored, othertimes...
You have to use the "FILM AREA GUIDE" included with the scanner. This black plastic guide leaves a small area at the top of the glass open so that the scanner can calibrate itself at the start of each scan. Use the guide or leave at least 8mm between the top of your film and the top of the scanner glass.
Jan 24, 2011 | Epson Perfection V700 PHOTO Flatbed...
I have an Epson Perfection V700 Photo scanner and an Imac version 10.5.8. Are these compatable?
Yes the scanner is compatible with a downloaded driver from epson. however some of the supplied third party software may not be. Also with MACS the push button scan may not work.
Dec 28, 2009 | Epson Perfection V700 PHOTO Flatbed...
Epson V300 Photo Scanner Streak When Scanning Negative
I also own a v300, and I have noticed that I occasionally get rainbow streaks if I bump the scanner at all while it is scanning negatives, so this might have something to do with vibrations in the machine. Is it sitting on a stable surface?
Mar 14, 2009 | Epson Perfection V700 PHOTO Flatbed...
I cannot get clear scans from my photo negatives
If you are seeing pixelation, the issue is either insufficient resolution during the scanning process or a problem with the output device. If it's a focus issue, which will NOT cause pixelation, the problem may be the height of the negative holder. The Epson Perfection V series scanners have a fixed focus point which only adjusts between two settings depending on whether you select the film holders (which raise the film off the glass) or the film guide (which scans film directly on the glass) in the software options. If you are going to scan transparencies or negatives, familiarize yourself with the holder height adjustment issue and be willing to experiment with different height settings until you are getting optimum results. This is not documented much at all in the Epson user manual but there is a little bit about it, including some examples of results at different settings, here: Apparently every scanner is slightly different so even though the lowest holder foot setting (default) is working best for some, other settings work better for others. On my V700, I have the feet on the film holders set to the highest setting plus I shimmed them with a 1mm piece of styrene before I could get the scans in focus. Once I found the right height though, I've been able to get beautiful scans from this machine. BTW, scanning negs directly on the glass will almost always result in Newton Rings.
Sep 08, 2008 | Epson Perfection V700 PHOTO Flatbed...
Huge difference in film scanning quality
For ARCHIVAL quality scans, there is no comparison. The Nikon wins hands-down. For making small prints and web sharing, either will work fine.
Apr 16, 2008 | Nikon LS5000 Film Scanner
Scanning Slides from Epson Perfection V700PRO
Please reinstall Epson Scanner software it will solve your problem
Apr 11, 2008 | Epson Perfection V700 PHOTO Flatbed...
EPSON V700 Photo Scanner
Unplug the power supply from the power port on the scanner then plug it back in after a few seconds and power-up if it isn't already on. This happens to me a lot and this works every time. Frustrating though.
Jan 14, 2008 | Epson Perfection V700 PHOTO Flatbed...
Scanning slides with the Epson Perfection 1250
To be honest, I have no idea of how you were able to scan larger transparencies in the past. The scanner and its software were never designed to do this and there is no workaround.
Feb 04, 2007 | Epson Perfection 1250 Photo Flatbed...
158 people viewed this question
