Televison & Video Logo
A
Anonymous Posted on Sep 03, 2014
Hoe do i retune my bush tv
Why can i not watch,source keeps searching ?
Level 3:
Top Expert:
  • Bush Master 76,851 Answers
  • Posted on Sep 04, 2014
Bush Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14987045
Points
237762
Sounds like main system control memory IC fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
2 Related Answers
jairo sanchez
  • 276 Answers
  • Posted on Dec 05, 2010
SOURCE: Hi, I have a bush flatscreen LCD TV approx 2 years
has a problem in the main or control trarjeta what most Epron circuit fault is a technical search
Anonymous
  • 902 Answers
  • Posted on May 14, 2011
SOURCE: Retuned my BUSH freeview TV
did you get another tv in its place and cant receive the same channels? if so have you did a channel scan for both over the air and thru the cable? usually located under the settings menu
I have retune my bush smart tv and now have no itv, channel 4,5,and all other related channels don't no what to do
Check your aerial connection then retune again.
It could be that set has picked some very weak channels, for those you mention. So make certain you select the option for best signal when retuning.
Hi, my aunt lives in Scotland. She has a Bush TV, don't know the model. The numbers on her remote do not correspond with the channel she's searching for Eg, BBC 1 is 25 on the remote. Thanks, Shona
When retuning the TV make certain you select the right region or it will order the stations wrong. You should also be able to swap channels manually. Read the instructions carefully. If you have lost the manual you should be able to download a free PDF of it by searching for the TV model number on Google. I can't be more specific without a model number.
Mitsubishi cold 3.0 v6 workshop manuals
If your philips tv keeps losing it's stations when you switch it off, this my be a solution -----my 42" tv would need to be retuned every time I wanted to watch it this fault just started over night it was all working fine then sat down to watch tv and had to retune tv from scratch I could then watch telly all night fine change channels no probs all great switch it off next day retune and so it went on if you have this problem switch telly on then hold in menu button on tv until screen goes black (this reboots software) then retune tv as normal it will ask if you want a full retune (yes) when this is complete digital and analogue your tv should now remember channels when switched off and work as it used to ----( Hope this helps you if you have had this problem it worked for me ). Good Luck
2answers
Retune
try cleaning the remote buttons and circuit board inside your remote using a pencil eraser
Lg tv losing stored channels when turned off
I purchased an LG43UN7100 just before Christmas 2020. It has used the same aerial connections (ports/cabling) previously used by both Samsung and Philips televisions, which worked perfectly. After twelve days of use, I've now retuned it 4 times and have even followed advice to disable the Quickstart Plus and reset back to initial settings. From an internet search I suspect that this is a common 'feature' of LG televisions :(
3helpful
2answers
I bought a TOSHIBA 32KV500B tv. At the Initial Installation mistakenly I selected "yes" for 'do you want to search analogue channels?' guestion. And then I lost all my automatically selected...
I had this problem and searched the internet for hours looking for an answer and was given the initial same reply as this and it does not work. To solve this problem all you simply need to do is press source button on the controller followed by pressing the DTV/USB option. All your digital channels will come back to you and you will find the menu setup options you are looking for!!!
Bush tv idlcd26tv16hd. does this have freeview if so how can it be retuned
Problem solved I managed to retune after finding manual
How do i retune my bush 1433
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit
http://tvretune.co.uk/productmanuals
1helpful
2answers
CANNOT RETUNE THIS TV BUSH TV DVD COMBO LY2211WCW
Press menu button then press 7935, if like me you bought a display model it will be set to hotel mode, this hides all the menus, once accessed switch hotel mode off, job done x
Top Bush Televison & Video Experts
matt martin
matt martin
Sean Wright
Sean Wright
john h
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
