Question about Canon Office Equipment & Supplies
I have a Canon Imageclass MF4150. Red light is blinking indicating error with message of paper jam. Lifted the cover, took out the ink cartridge, open and check the back for papar jammed. I do not see any paper jammed or stucked up. Machine continous to indicated paper jam and can't make it to work. I think I've done everything in the manual to no avail.
    President:
  • 392 Answers
when u removed ur previous jammed paper it had somehow pulled off a spring from inside the machine. The spring was linked to the paper jam sensor.1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
if the above doesnt solve then follow this
1) Take off the front first (lift up the cover and there is 2 screws at the front and 2 clips on the bottom of the machine) . 2) Then remove the 2sides and finally the top (screws should be easy to see, to get the sides off, un-clip along the front edges and gently move them outwards and slide them backwards to release the clips on the back) being careful with the wires going to the scanner part). 3) Then look for the fuser unit which is near the top at the back, there is a black rounded cover over the fuser. 4) To remove the cover, look for 2 small clips one at each side and unclip the cover and gently lift upwards. 5) Under the cover on the left side you will see a small plastic rod which goes from the left side to a small tab in the middle, if you look about half way along that rod you should see a tiny spring, make sure this is clipped on properly and that you are able to rotate the rod and it should spring back to the proper position when you let go.
Once this is done, put it all back together again and it should work fine.
plz rate my answer .
Posted on Jul 02, 2009
ImageCLASS 2300 not printing, check printer cover message
Had the same problem spent 2 hours opening and closing everything trying to reset turn off and on etc. Here is how I fixed it, slammed all the doors on left side starting with above cartridge to cartridge door and 2 little doors by paper hard - and I mean hard - and whammo error cleared immediately. Sensors that check for open door obviously stick and report they are open when they are really closed. I am sure this saved me an expensive service call.
Apr 05, 2010 | Canon imageCLASS 2300 All-In-One Laser...
My canon imageclass mf 4150 says toner not set but there is a cartridge in it.
my canon imageclass mf 4150 says no paper even paper loaded, kindly help to solve.
Feb 11, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
I had a major paper jam at my printer (Canon, Super G3, imageClass MF 4150). I removed all the paper which was not easy. The printer is not working and switches to following messages: Paper Jam, Lift panel...
  1. Protect yourself from shock. Disconnect the power cord from the back of the Canon Inkjet Printer. This is an important step when working inside ANY electronic device.
  2. Step 2 Unhinge the back access panel of the printer. It seems repetitive to say this, but this door will be in the BACK of the printer.
  3. Step 3 Look through the opened back panel and look for paper. Remove any and all paper you find jammed there.
  4. Step 4 Close the back access panel. Make sure that it latches into place and looks the same way that it did before you opened it.
  5. Step 5 Find the front or top access panel. This is the panel you would lift to change ink cartridges. Open this access panel. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer, go back and do that now. Look for paper that may be jammed in this area of the printer.
  6. Step 6 Remove any paper you find jammed here. When pulling from the front there will be resistance from the paper feeder. Pull slowly or the paper will rip and create a more stressful problem.
  7. Step 7 Close the front access panel. Make sure that it falls or latches back in place. It should look the same way that it did before you opened it.
  8. Step 8 Plug the printer's power cord into the wall outlet, and attempt to print again. If the printer prints the job, then you have successfully removed the paper jam.
Jan 26, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Canon Imageclass MF4370dn constant paper jam errors
Dear
Inside the back panel there are paper sensors attached to lever, a small spring connected to lever to keep its home position, the spring may dislocated from its position or the lever sticked to the base. some times a small piece of paper sticked at this may cause the problem.
Thanks.
Apr 20, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
PAPER JAM
give this a shot
try this, its probably a small part of jammed paper or then theres a problem with the pickup, try cleaning it.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Apr 14, 2009 | Canon imageCLASS® MF4150 All-In-One Laser...
Two error messages persist after replacing toner cartridge.
This kind of error indicates that your toner is not properly set or there is some paper jam. so please follow the instruction and open the panel and remove the toner and check for any kind of paper piece and than refit toner properly and close the panel and than check you will definatly able to resolve the problem ok
Dec 20, 2008 | Canon imageCLASS MF4270 All-In-One Laser...
Canon MF3240 Paper Jam - No Real Jam
try this
alternative :
Dec 18, 2008 | Canon imageCLASS MF3240 All-In-One Laser...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
24 people viewed this question
old marine
old marine
