Sherwood AI5010 no sound from either channel
I recently purchased a 2nd hand Sherwood amp but on arrival I couldnt get it to produce any sound ( I think both channels are blown). The power button lights up but having checked the speaker selector, balance input selector etc. there is still no sound. Any idea how to fix this problem?
  • camera9 May 11, 2010
    Let me say upfront that I can't help you. However I do hope your problem was fixed. I'm wondering if maybe you could help me? I'm looking for the user manual for the very Sherwood amp you have - the AI5010. Would it be possible to obtain a copy in some form from you. It would be a big help if you could.
    regards, Cam
    Scholar:
  • 31 Answers
Hi There DEKCAT
Its very unusual for both channels to blow......
I suspect that there is a blown power fuse inside the case......
There are fuses sometime located on the outside rear of the case and these can be easily checked to determine if they are blown..If you find one is blown please replace with the corrrect rated fuse,..... its current rating wil be on a small label on the case outside rear. like 1.0amp, or 1.5amp etc...
If you need to go inside the case please ensure the power plug is removed from the wall socket first.
You will find small glass fuses in the DC power supply feeds and probably one of these has blown, once again replace with the correct rated fuse.
Im not sure if your amplifier is a FET type or a large 32-40 pin IC type as if these are blown you will need a service person to do the replacement...
Please note there is a small relay that clicks 20seconds after turn on at the switch....if this click is not happening then there is problems with the timer circuit or the relay itself...
This relay controls the output to the speakers and as such stops all the sound output if its not working...so the first thing is to check all fuses, if they are OK then check the Relay operations....
Cheers From YUBEUT
Posted on Nov 16, 2007
How do i wire up my sherwood rx-4105 reciever for a subwoofer
If the amp has no subwoofer channel then you take the right and left channels to the speakers and feed them in the subwoofer first, then out to the left and right speakers.
Oct 02, 2017 | Sherwood Audio Players & Recorders
Sherwood AX-4103 amp keeps clicking
Hello there.... Check your speaker wires and then if that doesn't do it? try replacing the fuses on the back of the amp.. make sure power is turned off and unplugged. If that doesn't work? Try one speaker at a time ... something is causing the system to short out. Hopefully it is not internally
Apr 21, 2014 | Sherwood Audio Players & Recorders
Turntable troubleshooting
A loud hum is usually from an earth problem (in fact 'not earthed')
So your best bet seems to try the 2nd pre-amp again, and see if there is a pin or connector for an earth link. Mine earths to the chassis of my main amp.
Jan 31, 2014 | Audio Players & Recorders
I just recently bought a brand new MTX magnum amp and dual 10" enclosed subs deal off of amazon. They arrived today, and with the help of a friend who is good with car audio systems, we set the whole
the best thing to do is get in touch with amazon,and see what they can do about it,if you try to fix the problem yourself it will invalidate the garantee!
Dec 05, 2012 | MTX Car Audio & Video
Low volume through amp
you will probably need to buy a phono pre amp , i have a Dual 505 turntable that worked fine on my ROTEL amp but when i changed amps and went to NAD i had to buy a phono pre amp or else listen to really low sound . hope this helps
May 23, 2009 | Technics SL-1200MK2 Turntable
Technics turntable plays but no sound with Sherwood receiver
The problem is the fact that the new receiver has no phono input. The phono input has an extra stage of amplification built in. Your receiver is working fine. You need to purchase a phono pre-amp. These run around $20. Connect the turntable to the preamp and the presmp output to any line level input on your new receiver and everything will work as expected.
Dan
Apr 12, 2009 | Sherwood RX-4103 Receiver
Harwa tv childlock code
Harwa password is 000000
Nov 18, 2008 | Televison & Video
Amp powers on, but no sound is produced
a failed volume control potentiometer? it's possible.
Jun 04, 2007 | Sherwood RD-6108 Receiver
849 people viewed this question
 Grubhead
Grubhead
