Check your power supply. Most common reason for your problem is that the psu has died. Also near your main psu connection on the motherboard should be a little led light. If your board is getting a proper power connection/supply that light should be green. If not it will either be off or red. If it is green then the problem may be your motherboard. If it is red or off then it is most likely a bad psu. Replace with a compatible psu & you should be back up & running. Hope this helps.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for E-Machines eMachines Desktop
eMachines T3418 mi no arranca solo suena el ventilador ya prove con elotro Power Supply y sigue...
(More)
eMachines T3418 mi no arranca solo suena el ventilador ya prove con elotro Power Supply y sigue igual
Was just curious if there was a way to set my refresh to an auto position, to make it refresh...
(More)
Was just curious if there was a way to set my refresh to an auto position, to make it refresh automatically ? and if so can I regulate the time it refreshes ?
