Question about Sta Rite Sr333lp - Max E Therm - Pool & Spa Heater - Dual Electronic Iginition Lo - Nox - 333,000 Btu - Propane Gas
Pool heater runs but the air coming out of the unit is cold.
The spa heater is connected to the same propane tank and is heating fine. The digital reader on the pool heater says r3 when you turn it on and then flashes 181 and 183 as error messages. The heater sounds like it is running properly but no heat is coming out.
  • 83 Answers
R3 is not one of the actual error codes, but is part of the computer system. What you can try to do is reset the computer in the heater. First you will need to turn the heater off, then turn off the circuit breaker for the heater. Wait about 15 to 20 minutes then reverse the order, the circut breaker then the heater. Try and start the heater and watch the display panel.
If they R3 reappears, then the problem is the control board for the heater and it will need to be replaced.
Posted on Jul 08, 2009
Air Flo Switch on
see if hose clogged or hole or collapsed
Jul 14, 2013 | Jandy LAARS LX250 - PROPANE, DIGITAL...
HAYWOOD POOL HEATER
if voltage ok coming in check transformer if ok bad display or fuses
Apr 22, 2013 | Hayward H Series Pool & Spa Heater 200k...
Heater takes a long time to fire up.
There is a flow switch if that's not working. same problem needs to be tested Gas valve solinoid could cause this Igniter could cause this problem Gas pressure regulator wrong pressure should be about 2.7KPA LPG Gas valve should be set to about 2.6 KPA LPG
Mar 28, 2013 | Rheem M206A 206K BTU Pool and Spa Propane...
Brand new versa 130 propane .Was working fine but then it was unplugged while running.Plugged it back in and it wouldn't work.Found out it was out of propane.Had the propane tank filled.Now the...
I would contact Raypak technical service and they may be able to help you correct the issue over the phone. This is even more likely since the heater is new. I hope this helps.
Aug 12, 2011 | Raypak 130,000 BTU Propane Gas Pool...
Unit runs about 10 minutes then stops but red light says its heating. unit comes back on after about 30 secons but now there is a very heavy smell of propane.
Hi pameroo,
I see that you are having issues with your Pool Heater.
I have hear Links that may help you regarding your concern, you also mentioned that it runs about 10mins then stops and a red light says it is heating then the unit comes back on after 30 seconds but there is a heavy smell of propane.
maybe you can check all the connection if there will be any leaks on the machine.
make sure that the line to the Gas tank does not have leaks, turn Off of the Gas connection before doing any troubleshooting...
Link1
Link2
Manual/Service Manual
See the Links above, the third Links has the Owners manual and the service manual for the Troubleshooting that can help check with your concern.
I hope that this helps.
Thank you for choosing Fixya,
mvincentc
Jun 30, 2011 | Pentair 460736 Master Temp Pool Heater...
My pool heater suddenly stopped working. It sparks, it calls for heat but then I get a ILO ignition lock out reading. Can this be fixed? please advise. Thanks
Propane...Make sure you have 30% in the tank (and the valve is open on the correct tank). Natural gas...You may have carbon/debris on the ignitor.
Sep 26, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Pool Heater. Hayward H100ID Starts fine and heats for about 5 minutes. Then heat stops. You can feel the blower its just cold air.
It sounds like your pool heater is not firing. I would check several things: the burner might be blocked and clogged, the gas valve might need to be replaced, the direct spark module might be malfunctioning, or the combustion blower might be cleaned. One of these is probably the issue. A service man can repair all of these problems.
Aug 08, 2010 | Hayward 100kbtu Pool Or Spa Propane Gas...
The heater come on and cycles on and off, but the water no longer reaches the correct temperature. Pool techicina has replaced the thermostat and disassembled and cleaned something, but it still will not...
This could be the flow rate / value...maybe the unit is under rated in its BTU value. But if it did work fine and heat the water ok then its not this...next thing would be the system control switches...each of these needs to be tested one by one to see if it cutting out the system too early...failing that it is the flame being produced and the heat value is cold see if the flames are blue or yellow...blue is fine nice and hot yellow is too cold to heat the water passing through
http://www.laarsman.co.uk
Miles
Jun 05, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
What type of regulator do i need to connect my propane tank to the heater?
You need a regulator rated for the heater. Your propane dealer can provide you with exactly the right regulator.
May 24, 2010 | Hayward 100k Btu Propane Gas Pool Heater...
Sta Rite Sr333lp - Max E Therm - Pool & Spa Heater - Dual Electronic Iginition Lo - Nox - 333,000 Btu - Propane Gas Logo
227 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
