Question about NRS Wayne& Lawn Sprinkler Pump
How do I remove the motor housing from a wayne reliantone 1 hp lawn pump?
How to wire it from 110v to 220v...
Most pumps have the eiting diagam on the outer motor housing. What brand is the pump? Some motors have a jumper that is moved over to 220v or 110v post and the red/black(220) or white/black(110) stay on the regular screw terminals. Ground stays on the same terminal usually a green screw
Jul 21, 2013 | Utilitech 1-HP Lawn Pump UTP10P1
Shallow water pump keeps stopping
new pump --not big enough for the job
old pump --motor windings problem, faulty start run capacitor
I suspect that as the motor is 1/2 hp if will run good when there is a need for water but under pressure the pressure switch is set to high so the motor overloads and gets hot
Mar 24, 2017 | RTO Wayne 1/2 Hp Shallow Well Jet Pump
How do you remove impeller from wls200 pump
Impellers unthread counter clockwise.
Take a large flat head screwdriver and put it in the slot on the end of the motor oposite the impeller end and hold it tight as you unthread the impeller off the shaft of the motor.
Rod
US Parts Center
Apr 17, 2013 | NRS Wayne& Lawn Sprinkler Pump
Motor removal on a Jacuzzi magnum force pump.
The impeller is threaded onto the end of the motor shaft and the housing (pump body) is attached to the motor with the same bolts that hold the rear cover on the motor they run all the way through on most pumps.
May 27, 2010 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
Seal leaking on motor side of wayne pc4m pump
Wayne sells parts direct and deals direct with homeowners as well as contractors. You can reach them here.
Oct 08, 2009 | Wayne Water Systems Wayne 1/2 Hp 115 Volt...
SEal replacement on Flo-Master 1 hp 2 speed pump? Tough to remove. Any tips on removal?
Pump seal is in two pieces. The piece with the spring should be easy to remove. To remove the piece that is inside the motor side of the pump housing, place the housing with the side that should be facing the motor downdwards on a flat surface. The hole in the housing is larger than the seal, so use a screwdriver and, placing first on one side of the seal and then the other, strive the handle of the screwdriver sharply and the seal should pop out the bottom. The seal is rubber, with a ceramic insert, so if you don't tap the screwdriver too sharply the insert won't be damaged. In any case, it's a good idea to replace the entire seal if you have had to open the pump and remove the impeller
May 23, 2009 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
No information on Wayne 55701-RP1
This isn't a valid Wayne pump model number according to Wayne's website. Please double check your pump and visit:
http://www.waynepumps.com/producttype.aspx?pt_producttypeid=8
May 23, 2009 | Wayne Water Systems Wayne RECONDITIONED...
1/3 hp wayne pedistal sump stoped working
yes there are brushes,, but there is also a shaft that goes thru the tube make sure it is not broke or bent,, it happens,, suggest to get a zoeller submersable pump its the best cast iron, float is attached to the unit, will fit in small pits, only 1 plug needed,, cost for pump 100
Dec 31, 2008 | SPV Wayne Pumps Spv500 1/3hp Cast Iron...
NRS Wayne& Lawn Sprinkler Pump Logo
202 people viewed this question
Top NRS Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a NRS Pool and Spa Expert? Answer questions, earn points and help others
