Question about Kenmore Heating & Cooling
Need support brackets to cure NYC facade law issue
I have a 5,600 BTU/hr, 4.9 A thru-window unit in my bedroom. Model #25371055003 dated June 2000. The unit itself runs OK. However, my apartment has been cited by my landlord under a NYC ordinance (Local Law 11/98) requiring support brackets for A/Cs in building facades. They are threatening $1,000 fines if brackets are not installed immediately. How do I find out which brackets to use and where to get them? Thanks in advance, Dan musicBDfood@yahoo.com
  • musicbdfood Jul 02, 2009
    This is a Kenmore machine.
I have the same problem with a 10,000 BTU unit. The installer told me to get an AC-080 support bracket. It's $30 at Home Depot. It is total BS that they didn't tell us we needed the bracket in the first place and now want to charge $160 to install it since the A/C has to be removed and reinstalled in the process. The warranty on installation is only 30 days. I'm still going to try to get them to do it for free.
Posted on Feb 25, 2010
Btu rate model ckl49-il serial 0506103005
Built in June of 2005, it has a BTU rating of 49000 BTU or 4 tons. This is a 12 SEER, R-22 cooling only unit.
Aug 10, 2014 | Goodman Heating & Cooling
Can't find a manual for air conditioner
BTU means "British thermal units" and is a measurment of cooling and heating capacity. Other units are Kw "Kilowatts", and HP "Horse Power".
To convert
Multiply by
To obtain
kW
1.341
hp
kW
3,413
Btu/hr
hp
2,545
Btu/hr
May 21, 2010 | Fedders Q Chassis A6Q10F2A Air Conditioner
BTU of air conditioner?
Here are all the specs of the air conditioner whirlpool ACU102PK
Key Features Type Thru-Wall/Window Cooling Capacity 10000 BTU/hr Energy Efficiency Rating 8.5 EER Remote Control Without Remote Control Fan Speeds (Cooling) 2 Dimensions Width 25 in. Depth 20.5 in. Height 14.5 in.
Hope this helps you and Good Luck.
May 13, 2010 | Whirlpool ACU102PK Air Conditioner
GE model AJM10DFV1 window unit I need the
remove front panel and there is an info plate that says:
Cool BTU/ HR AHAM 9 700 / 9 500
AHAM - Association of Home Appliance Manufacturers
May 06, 2010 | GE Heating & Cooling
Coleman Gravity Floor Furnace need millivolt gas valve & pilot ki
Go to www.grainger.com and look for a "power pile generator" this is a millivolt thermocouple that may be just what you need to make your heater work again
Nov 12, 2009 | Heating & Cooling
How many tons and what Seer is my Bryant model 561CJ048-A
12000 btu/hr equals 1 ton. The 48 in your model number tells me it is probably a 4 ton unit. 48 divided by 12(000) equals 4. Not sure on the SEER
Oct 08, 2009 | Heating & Cooling
BTU's on Emerson Quiet Kool A/C
AC Type dtrquestion.gif Thru-Wall/Window Cooling Capacity dtrquestion.gif 10000 BTU/hr Energy Efficiency Rating dtrquestion.gif 9 EER Fan Speeds (Cooling) 3
May 27, 2009 | Emerson Quiet Kool 10GV13 Air Conditioner
How large a room does a 10,000 btu air conditioner cool
What size unit do I need for my room? Use the following chart to find the appropriate size air conditioner to use:
AREA TO BE COOLED / CAPACITY (BTU/HR)
100 to 150 square feet = 5,000
150 to 250 square feet = 6,000
250 to 300 square feet = 7,000
300 to 350 square feet = 8,000
350 to 400 square feet = 9,000
400 to 450 square feet = 10,000
450 to 550 square feet = 12,000
550 to 700 square feet = 14,000
700 to 1000 square feet = 18,000
If the room is heavily shaded, reduce needed capacity by 10%
If the room receives a lot of direct sun, increase needed capacity by 10%
Add 600 Btu/Hr for each person in the room if there are more than two people
If the unit is for a kitchen, increase the capacity by 4,000-6,000 Btu/Hr.
if this helps please vote me a fix ya
Jul 21, 2008 | Heating & Cooling
Window or wall mount
The differance between a window and wall mounted A/C is the mounting system.
Window units are usually smaller BTU systems they set in the window, so you do not have to cut a hole in the wall to install it.
For a bedroom say 10 x 10 you can use @ 5000 btu it plugs into a standard 120 volt electric outlet. If the room is bigger then go bigger say @ 6000 btu or so. Take your room dementions with you when shopping for a unit. sometimes they have sizing on the side of the unit box.
Wall units are usually larger units. Like whole house 18,000 btu
they slide in and out of the case and use a 240 volt seperate circuit.
Best place to shop for A/C's are Home Depot, Lowes, Sams Club, B.J.'s, and Cosco they buy in large volumeusually give a Good deal I've seen 5000 btu units as low as $89.00
Just don't drop the unit out the window when installing it
From the second floor it will void your warranty. LOL
Good Luck Phil
May 19, 2008 | Frigidaire FAC124 wall/Window Air...
Heating & Cooling Logo
1,045 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
