Question about Grilling
Have a sears gas grill model #16203. looking for hose replacement. has an additional side burner
SOURCE: all 3 Burmers won't stay lit
I contacted the company. Phone number 800-694-0013. You can order replacement parts thru them but they cannot take credit cards by phone you have to mail in the payment and they will Fed-Ex the part when they receive it. The lady I spoke with was very nice and helpful, she stated these grills are made for Meijer's pretty much exclusively and they are made in China and that if you can locate their website it is all in Chinese. She also stated the distributor has opted not to sell the replacement parts for these in the store.
Posted on May 29, 2009
  • 3 Answers
SOURCE: Kenmore elite16690 gas grill - main burner replacement
Call 1-800-4MYHOME and request a brochure for that model. Then you can call the Parts line at the same number and order the parts you need.
The actual grill model number is 141-16690
Posted on Sep 08, 2009
bulldogchief
  • 388 Answers
SOURCE: I need 3 burners for Grand Gourmet Gas Grill Model No. GBC621A-M
Try this link: http://www.grillstuff.com/grill-parts/brinkmann/810-2300-b/?cat=27&brand=5&model=8938
It should bring you right to your specific grill and list replacement parts including burners.
Cheers!
SOURCE: Need 3 burners for Dynasty gas grill model DBQ-42-F-L .
There is one on Ebay: do a search, NEW For Jade Dynasty Grill BBQ DynaChrome Burner. the item number is: 130362941787
Posted on Feb 02, 2010
  • 494 Answers
SOURCE: Replacing hoses and regulator on gas grill
I work for a propane co. I get many customers that bring in their melted or leaking bbq grill hoses and regs. Bring the bad hose/reg to your local propane gas co and see if they can make a custom hose for you. You may have to buy a new regulator to use it with the new hose, but that's better than buying a new grill. Call around first and see which ones can do it. You'll eventually find someone that can fix you up.
Posted on May 16, 2010
Testimonial: "great suggestion - i'll give it a shot. Thank you!"
I would like to convert a grill that was used on natural gas back to propane. Can I just purchase a regulator and hose and be good, or do I need to change anything else on the grill?
Burner orifices must be resized or adjusted to accommodate higher pressure LP.
Air shutters should be opened all the way to allow maximum air to gas ration.
Sep 14, 2011 | Barbeques Galore Capt'n Cook 3-Burner...
Char-broil front avenue, model 463230703, igniter lights side burner but not the 3 main burners.
Sounds like a regulator problem. As it takes less gas to light the side burner, than it does to ligh the main burners.
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helps you troubleshoot & solve the problem. Happy Grilling and thanks for choosing FixYa.
Sep 09, 2011 | Grilling
Purchased a grillpro 3 (three burners plus side burner) from orchard. They installed but side burner will ignite. Igniter is working and I hear gas when I turn the burner knob. Fire the igniter and it will...
You're getting gas to the burners, just not enough to ignite the burners.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank.
I hope this helped you & thanks for choosing FixYa.
Jul 28, 2011 | GrillPro Grill Pro 80016 Hose and...
Recently replaced all 5 burner tubes and now when I light the grill it doesn't get hot enough - stays around 250 degrees.
Gerald, when you turned the gas tank valve back On, after replacing the burner, the OPD Valve in the grill tank partially locked up the grills gas regulator. To solve this problem, follow the steps below:
1. Turn the gas valve OFF and disconnect the hose from the tank. Wait 5 minutes.
2. Reconnect the hose to the tank and open the tank valve VERY, VERY, SLOWLY (Slow motion,
slow).
3. Once the valve is fully open, light the burner farthest from the grill first and turn it to HIGH. Does
the flame height look correct for the highest setting? If so, light the remaining burners the same
way. Now, to all the flame heights look normal for the highest setting. if so, you solved the
problem.
4. Close the hood/lid of the grill and allow it to preheat for at least 15 minutes. The temperature
reading (if your grill thermometer is correct) should between 400 & 450 degrees F, depending on
outside air temperature. Which is hot enough to sear a steak.
If none of the above corrected the problem. You will need to replace the grill's Hose/Regulator Assembly, because the regulator is partially locked up. You can pickup one at any home center or hardware store that sell gas grills and accessories for about $30.00. Take your old one with you for comparison purposes.
Hope this helped you to troubleshot and solve the problem. Happy Grilling!!
Jun 20, 2011 | Ducane 30400042 (LP)
Side searing burner won't ignite
check the gas tube that comes off the burner for spiders. They will build a nest in there over winter and not allow the gas to get through
May 16, 2010 | Kenmore 882 sq. in. Cooking Area Gas Grill...
Searing Unit Keeps Cutting Out After Release of Knob
First I have a couple of questions for your question on how to fix your Brinkmann Gas Grill, Model 810-8501-S
1). Did you push the igniter for 3-5 seconds after you turned on the Sear Burner (remember, this needs to be done AFTER you've turned the control knob to HIGH).
2). Once the burner is lit, you then need to continue to PUSH & HOLD the control knob for another 30 seconds as this somehow seals the deal, thus this should solve the problem.
3). However, if this does NOT work, you may have a defective Sear Burner and the best thing to do is to contact the Customer Service Department over at Brinkmann:
* The Brinkmann Corporation
Attn: Customer Service
4215 McEwen Road
Dallas, TX 75244
Toll Free: (800) 468-5252
Local: (972) 716-4262
OR you may send them an email through this link:
http://brinkmann.net/Customer%20Service/ContactUs.aspx
Hope this helps!
Apr 10, 2010 | Brinkmann Stainless Steel All-In-One Gas...
Gas is not getting to the burners on my Sears Kenmore gas grill.
check if regulator fully screwed to tank, turn on tank,then last burner,should hear/smell gas. if not replace regulator
Jun 25, 2009 | Kenmore 16225 Grill
Only one of four burners will light.
Hello, there is a carry over tube between the burners that looks like a burner hold down at the back of the grill. This is likely rusted closed and will need to be cleaned or replaced. The clips that hold the tube down are part # 7000132 and the tube part # is 7000280. They can be purchased directly from Char-Broil or Sears parts.
http://www.charbroil.com/
http://www.searspartsdirect.com
If you find this helpful please vote yes. Thank You!!
Apr 19, 2009 | Char-Broil Advantage 463453306
Jenn-Air 30 in. JGD8130 Gas Cooktop
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
Jun 08, 2008 | Jenn-Air JGD8130 Gas Cooktop
Grilling Logo
131 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
