I have a new HP printer Office Jet J6480 all-in-one. I've had it less than a week. I was doing a lot of printing and it began putting a vertical streak down the paper and then the display said it was low on ink and quit printing. I bought a new ink cartridge and replaced the old one and it is still streaking. What should I do?
  • 628 Answers
Check the rollers that move the paper. There is probably some ink on one if them. You can usually clean them with warm water. Just use a damp cloth and rotate the wheel slowly by hand while holding the cloth against the suspect roller.
Posted on Jul 02, 2009
HP OFFICE JET J6480 ALWAYS SPEWS OUT EXTRA BLANK PAGE AFTER PRINTING
Check if your document has empty lines at the end. Use your keyboard down arrow to scroll past the last line of text. Then backspace until you get to the last line.
Mar 09, 2016 | HP OfficeJet Office Equipment & Supplies
I can't print an Excel spreadsheet on Office for Mac 2011 on my new HP Office jet 8600 printer. The preview is blank! I have check the HP settings & all is in order,i think. Help!
if your printer is already, click file -> print, then do you hear the voice from printer. if not, your printer is not boot.
and you said your preview is blank. you not load the page with content. I guess you don't have the right to print it.
by the way, if you forgot the office password, visit this site to know how office password recovery
Apr 20, 2013 | HP OfficeJet Office Equipment & Supplies
How do i get my hp officejet j6480 all in one scan both sides and print
To automatically scan and print, you need to use the automatic document feeder (for letter-sized documents) and have the HP Automatic Two-sided Printing Accessory installed.
Then to use the duplex printing feature, you need to set the printer properties to use the duplex feature. In Windows, open a document to print then click on File Print. Choose Setup and then Properties or Preferences (depending on your OS). Then click on the Features tab and set Two-sided Printing to Automatic. (This is a drop-down menu on the Features tab.)
You also need to set the scan settings for two-sided in the HP Solution Center. (If you just want to copy the document, you can set this from the Control Panel on the J4680.)
If you want to do this manually, you can scan each side of the pages. Then print them one page at a time. Then when the ink is dry, put the page back into the paper tray. (Note: this could result in paper jams.) The printer prints on the underside of each page put into the paper tray with the top of the page printing on the forward part of the page.
I hope this helps.
Jun 19, 2012 | HP J4680 Office Jet All-In-One Printer
My HP OfficeJet J6480 All-in-One is leaving black vertical streaks on each side of the page when using the document feeder. Does not leave streaks when using the flatbed scanner. How do I correct
Hi
Just remove the ink cartridge. Clean the print head by a soft cloth with rubbing alcohol to remove some sticky or ink residue. Then rub the printhead into a plain paper until ink flows. Then run the print nozzle for 2 times.
I hope it helps you. Regards
Apr 09, 2011 | HP J4680 Office Jet All-In-One Printer
I need an HP office jet 6210 paper tray
ebay.com type in HP Paper tray They are around 20 bucks and you could get it less then a week. hope this helps hun
Oct 24, 2009 | HP OfficeJet 6210 All-In-One InkJet...
How do i get my hp officejet j6480 all in one to scan to my computer?
If you're already set up to print with J6480, you can use the drivers built into Windows XP or Vista.
For Windows XP
For Windows Vista
Sep 22, 2009 | HP J4680 Office Jet All-In-One Printer
I have an HP Office Jet v40. No problems when I
Sannaer glass is dirty: Cleaning the scanner glass and white reference strip Follow the steps below to clean the scanner glass and reference strip: Remove any loose paper debris that may be present.
  1. Carefully clean the white reference strip on the underside of the scanner cover (or top cover) with a clean, lint-free cloth, moistened lightly with isopropyl alcohol. Clean only the white plastic part on the scanner cover.
  2. For those models that have a scanner glass, clean the scanner glass with a lint-free cloth, moistened lightly with glass cleaner. The HP Officejet K series and HP fax 1220 have a scanner opening instead of a scanner glass. Make sure that no debris is in the scanner opening. Use canned air to gently blow dust and debris from the scanner slot.
  3. Replace all removed components and close the unit.
  4. Plug the power cord back in and turn the unit back on.
  5. Make a copy to verify the lines are not present. If lines are still present and there is nothing visible on either the scanner glass or the reference strip, the unit will require service.
Instructions are on this HP link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu50325&lc=en&dlc=en&cc=us&product=60630&rule=30380&lang=en
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 03, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Hp office jet j6480 all in one will not turn off.
remove the power cord directly from the back of the printer.and then wait for a minute.then reinsert the power cord.and check it should.turn ON/OFF properly.
Nov 07, 2008 | HP Office Equipment & Supplies
176 people viewed this question
k24674
jasbo
jasbo
