Water on passanger floor...how to unclog a/c drain tube
  • 3 Answers
Disconnect tube, fish a piece of bailing wire thru it and blow it out. You can hurt it. It's just arubber tube.
Posted on Jul 02, 2009
Why does my air conditioner leak water on passager side floor
The Evaporator box has a Drain tube, this is blocked and not letting the water drain off ,hence the build up of water in the box which will overflow into the passengers side .
The drain tube needs to be unblocked to let the water drain off.
Jun 12, 2014 | 2001 Mitsubishi Montero
Where is the sunroof drain located on 2002 monte carlo ss and how do i unclog it?
Water leaks are fun to trace out. the drain holes and tubes can be seen with roof open and can be unplugged with compressed air . but usually the headliner is soaked and leaks on to seats the windshield will leak on to passenger floor. remove glove box and check for wetness along "A" pillar.
Apr 30, 2014 | 2002 Chevrolet Monte Carlo
Location of air conditioning drain tube ? ( water condensate )
Passenger side under the van at the base of the engine bulkhead.
Aug 30, 2012 | 2000 Dodge Grand Caravan
95 BUICK ROADMASTER LEAKING WATER IN FLOOR
while you have asked your question in the Major Appliance (washer,dryer,oven,microwave ect) catagory. I know the drain line for the air conditioner is blocked so the water leaks onto the passanger side floor. Under the hood by the back firewall on passanger side is going to be a tube where the water is supposed to drain. Find that tube and clear it using a wire hanger
Aug 11, 2011 | Maytag MZD2766GES Side by Side...
Wet passenger floor pan
clogged drain line for the a/c evaporator, use a stiff wire or pipe cleaner to unclog line. Located on passenger side underneath car nest to firewall. Good Luck Tim
Oct 19, 2010 | 2005 Chrysler Sebring Conv
My a/c not working properly and water leaks onto the passanger floor mat. the box is cracked or broken water coming from their?
drain is not draining may be clogged look under car and with a small wire or pipe cleaner see if you can unclog it. Hope this helps tim
Aug 29, 2010 | 2002 Ford Mustang
Front floor board stays wet, believe it's the air conditioner
If the floorboard is wet on the passanger side of van it would be the drain tube causing the problem. Raise the hood and go to the passanger side of van and look down on the firewall. You will see a black tube about 4 to 5 inches long hanging down. Use a heavy duty tie strap to insert into the drain tube to remove the obstruction so the water can drain. Do not use anything sharp that will punch a hole in the tube. By doing this it will correct your problem. Hope this will help.
May 16, 2010 | 2007 Dodge Caravan SXT Minivan New Cars
How do I unclog defrost drain on a model TBX18W?
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 26, 2009 | Refrigerators
Water is showing up on the passanger side floor. Is this a result of the HVAC drain tube?
Yes, most likely. Locate drain tube under vehicle on that side and clean it out.
Charlie
Aug 17, 2009 | 2005 Dodge Stratus
Heating & Cooling Logo
138 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
