Question about General Electric WBVH5200J Front Load Washer
Washing machine just fills but does not wash, it empties without washing.
  • 1 more comment
  • amarshall1 Jul 02, 2009
    The cycle seems to skip the washing part and goes from fill to rinse and spin. Never washes and just keeps wasting water.
    Yes it was professionally installed.
  • william darter
    william darter May 11, 2010
    is the drain up high enough?
  • 61 Answers
Most likely is the switch. I would get that tested to start with..
Posted on Jul 02, 2009
SOURCE: washing machine fills continuously
you may have solved the problem by now....but it is probably a blockage in the level pressure chamber which is eaither a part of the drain pump manifold or a seperate chamber attached to the bottom of the tub. Its easy to find just follow the small pressure hose from the top of the machine. If its part of the drain manifold its not so easy to clear unless you have a large surringe to pump hot water down the hose to clear it.**** REMEMBER TO UNPLUG THE APPLIANCE FROM THE POWER SUPPLY ******
Posted on Sep 11, 2006
  • 1462 Answers
SOURCE: the Washing Machine fills and then empties with not running a wash cycle
possible a pressure stat fault. some pressure stats have a too high water detector which turns on pump
Posted on Mar 27, 2007
WhIzAtIt
  • 136 Answers
SOURCE: washing machine won't spin
The lid switch is likely defective. Test with a VOM meter and replace as needed.
Posted on Sep 21, 2007
  • 1122 Answers
SOURCE: washing machine drum won't turn
need more onfo,make, model number
Posted on Oct 13, 2008
astruttman
  • 45 Answers
SOURCE: water in washing machine from emptying sink.
A washing machine filling with water overnight or when not in use has two possible causes. Either the water is running into the washing machine from the sink ( If the drain hose is connected directly to the u-bend under the sink ) or one of the water valves isn't shutting off properly and water is dripping slowly but surely into the washing machine. The latter problem can take several hours before the water level rises high enough inside the washing machine to be visible.
It's easy to track down the cause of water entering the washing machine when not in use. If turning off the hot and cold water taps stops it, then it's one of the water valves not shutting off properly, and needs replacing. It's just a process of elimination to find out which one it is. If not, the water is likely to be coming from the sink (use above link). Sometimes by removing the soap dispenser drawer and carefully observing inside the soap dispenser you can clearly see water dripping in at regular intervals.
Blocked water valve filters: I've come across cases where a filter in the water valve has become caked in a brown sludgy mud-like substance due to disturbances in the plumbing. This could be because of work carried out on internal plumbing or even after workmen have turned the water off in the street to work on the water mains. After the water is turned back on, muddy or gritty water can enter the household pipework and when you use the washing machine it can draw this contaminated water into it.
In this scenario very fine grit or muck can get past the filter and stop it shutting off properly, or the filter is so blocked that water pressure to the valve is reduced enough to prevent the valve shutting off properly. Remove the water valve filter with some pliers and thoroughly clean it out. If the fault persists, replace the valve.
Important things to watch out for are -
  1. Washing machine water valves need a certain amount of water pressure to actually ensure the water is shut off properly. Therefore, if your water pressure is very low, it can seep in past the closed valve. This problem is less likely to suddenly appear unless your water pressure has suddenly dropped. It's more likely to be a problem with a new installation. ( Related: Low water pressure and washing machines )
  2. A faulty tap can mean that although you turn it off, the water supply isn't actually cut, so be careful of assuming if the fault still occurs, that you have definitely discounted the water valves. If unsure, you would have to disconnect the hot and cold fill hoses to ensure the water supply is properly cut when the taps are turned off. This problem is a lot more common with water taps that turn off with a red or blue plastic lever.
  3. If the washing machine has just been filling, you may get some dripping of water into the soap dispenser for a few minutes after. Don't mistake this for a valve not shutting off properly.
  4. If the water ever gets turned off while work is carried out on the water mains in the street or for major plumbing in your home, run lots of water in the house through taps at the sinks until it runs clear after the water is turned back on.
Faulty water valves should be replaced or there is risk of flooding.
Posted on Jan 11, 2009
My clothes are coming out dirty. dirt is settling on my clothes from the rinse.
Put a cup of vinegar in an empty washing machine fill with water and wash without clothing in it. Should sort the grime caused by fabric softner.
Feb 04, 2016 | Kenmore 24032\24036 Top Load Washer
Machine fills then emptys without washing
The first thing that comes to mind is that the drain hose might be too low and is siphoning the water out of the wash machine as it is filling. Try to raise the drain hose up and see if that helps any.
Let me know how it goes.
Dec 24, 2014 | GE Profile WPRE6100G Top Load Washer
The machine just empties its water without filling up the drumb
The hoses are not hooked up right ...
Here is a tip that tells you how to fix that problem...
Water will not stay in Washing Machine
heatman101
Oct 10, 2010 | Indesit W 123 Front Load Washer
Moffatt washer is washing and draining but not spinning out the clothes
All content © 2000 © 2009 Washerhelp
> Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
Dec 03, 2009 | Washing Machines
Washer stop in middle of rinse cycle
Dec 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Frig. Gallery washer and it will fill up and drain but not spin. What could be wrong and how can I fix it??
Dec 02, 2009 | Frigidaire Affinity ATF7000E Front Load...
Fills but does not wash
Hi!
That happens when for some reason any of the two drain/spin cycles are interrupted. Try this:
have the washer empty, then set the machine to run the last cycle to the end of it, when you usually
lift the cover to take out the clothes, that ought to do it, I had the same problem when diagnosing a
timer problem.
Nov 09, 2008 | Maytag Performa PAV2200
Washing machine will not drain.
I have the same problem. If I press on the lid by the switch it starts up and finishes the load. Hope this works for you!
Mar 25, 2008 | Washing Machines
The Washing Machine fills and then empties with not running a wash cycle
Mar 27, 2007 | Zanussi F1245W Front Load Washer
General Electric WBVH5200J Front Load Washer Logo
204 people viewed this question
Top General Washing Machines Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a General Washing Machine Expert? Answer questions, earn points and help others
