Question about Ricoh AC104 All-In-One Laser Printer
The machine still show the toner empty, new toner in
    Scholar:
  • 155 Answers
This problem is mostly reported when you refill the toner incorrectly.
flush out the whole toner(not with water) just shake it upside down.
now refill it.
if it doesnt work try cleaning the terminals of toner catridge and the terminal of the printer
Posted on Jul 02, 2009
4 Suggested Answers
kavala7
  • 5 Answers
SOURCE: HP 2600n printer showing empty black toner
maybe u have to reset the printers counter..
Posted on Jul 25, 2008
nakshatraipu
  • 241 Answers
SOURCE: 3 month old machine, low print usage, showed
you need to reset printer thorught software
We have Zero cost solution for samsung -scx-4300, ml-2240,ML
2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
www.nakshatraworld.com
mob: 9713862555, 9893282285
vivekryp@yahoo.co.in
Posted on Nov 14, 2009
SOURCE: Any way to reset the toner empty sensor on C 3400?
THIS POSSIBLE SOLUTION IS FOR AN OKIDATA C3400N PRINTER ONLY.
You can try taking out the complete toner & drum assembly for the Cyan (or any you have this problem with). To do that you open the top and just lift the recalcitrant assembly straight up. Once it is out, with it oriented exactly as you lifted it out, look on the RIGHT end of the assembly for a small rectangular window - about 1/4" square. It should be about 3/4" below the two metal contact points on that end - near the top that you lifted out about the same level as the toner itself. In that hole, if it looks like the opening is covered (just inside) by a bit of black plastic, take a pointed object (like a straightened paper-clip) and try gently to lift this plastic piece UP - don't stick the clip in too far. If you gently do this (may take a try or two) that piece of plastic should stay UP - allowing you to see a bit farther inside. Replace the assemble, close the door and let the printer recycle.
Just to help you understand what may be happening - this little piece of plastic is supposed to start in the UP position when the toner is new. Eventually, as the toner becomes used up, the piece of plastic is designed to gradually drop down and eventually block the sensor - indicating to the printer that the toner is spent.
I have had this happened to me several times with new toner cartridges - especially with the non-OKI OEM knock-off "compatible" toners. This has always worked for me - but no guarantee it will for you!
The other possibility of course is that you actually have a bad toner, which trying this should help to confirm.
Posted on Jan 23, 2010
Toner epmty
Toner pump gone bad will need to be replace
Oct 12, 2015 | Ricoh Aficio Mpc2800 Digital Color Copy...
Hi Sir. I got a problem of my Toshiba e studio 3510c printer, when I swich on the button, the screen shows there is a sentence said ;'disposal of the used tonner', should I replace the wasted...
It said exactly what? If it mentioned waste toner, emptying that tray (Toshiba has nice zero-waste-to-landfill toner recycling program) should have pretty much cleared things up; it appears that the sensor for that still sees lumps of toner..or something...coming up close to the paper path. Check it out carefully and replace the tray.
Sep 10, 2011 | Office Equipment & Supplies
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
Muratec mfx 1600 drum replaced alarm will not reset
Ignoring the Toner Empty Message
When the toner cartridge is empty, the machine shows a “Toner Empty”
message and stops printing.
You can set the machine to ignore the message when it displays and to
continue printing the pages.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button (�� or ��) until “Ignore Toner” appears on the
bottom line and press Enter.
3 Press the Scroll button (�� or ��) to select “On” or “Off.”
Select “On” to ignore the Toner Empty message.
Select “Off” to stop printing when the message appears. This is the
default setting.
4 Press Enter to save the selection.
Jun 18, 2009 | Muratec F320 Plain Paper LED Fax
Samsung sf-5100 fax toner empty
I have a feeling that it is a re-manufactured or compatible cartridge??
There is a fuse that needs to be replaced on this unit. it blows when the cartridge is installed to reset the machine. If the fuse has not been replaced or is defective the machine will not recognize the new unit.
Mar 05, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Message showing toner empty with the new toner cartridge
Please clarify, you're saying copier and toner problem but it's showing a typewriter which uses a ribbon ???
Oct 23, 2008 | Olivetti MS25 Typewriter
Jul 22, 2008 | HP Color LaserJet 2600n Printer
TOSHIBA FAX
There was a chip in back side of toner if its memory erased it shows toner empty symbol.so you please replace the toner catridge to solve this problem
Jun 09, 2008 | Office Equipment & Supplies
Pagepro printer toner empty problem
1. It tries to pump toner into a reservoir. If it doesn't activate a full sensor for the reservoir, it shows toner low. 2. Take the toner out and shake it hard about 10 times, this will make any settled toner loose, and should solve this. The problem is normally caused by old toner (your supplier might have had it on their shelf for a year or two).
Aug 11, 2007 | NEC Nefax 655E Plain Paper Laser Fax
Magicolor 5430 showing wrong toner levels
Are yo using genuine Minolta toner? Some generic toners do not replace the chip on the cartridge which tell the machine the toner levels. If this is not the case let me know. John A.
Jun 29, 2007 | Konica Minolta magicolor 5430 DL Laser...
Ricoh AC104 All-In-One Laser Printer Logo
189 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
