Question about Westinghouse SK-32H240S Television
Westinghouse TV screen flickers
I had the same problem.  I bought a refurbished model and after about an hour of the TV being on the screen began to flicker uncontrollably.  It would return to normal after turning the power off for about 15 minutes and then turning it back on.  I sent it back to westinghouse and they sent me a replacement refurbished model.  The replacement tv works properly..
4 Suggested Answers
Adolph
  • 137 Answers
SOURCE: Flickering/pixelating screen on LTV-27w6 HD after 30 minutes.
Sound like dry goint on Power Supply bord. I had the same problem and resolder most of the parts of the power supply and TV was ok.
Posted on Dec 22, 2007
SOURCE: Flickering/jumping picture
I HAVE THE SAME PROBLEM. TV WAS FINE UNTIL A FEW MONTHS AGO. OF COURSE ITS OUT OF WARRANTY. FROM WHAT I HAVE READ, AND BEEN TOLD, IT IS THE POWER SUPPLY TO THE UNIT. IT IS DEFECTIVE, OR IT OVERHEATS AND TRIES TO SHUT DOWN. A LAW SUIT IS IN PROGRESS AGAINST WESTINGHOUSE TO RESOLVE THIS MATTER. KINDA REMINDS ME OF THE XBOX 360'S WHEN THEY CAME OUT. ALL YOU CAN DO IS TAKE IT IN FOR SERVICE. OR, YOU CAN KEEP TURNING IT ON AND OFF, LIKE I DO. I HAVE HAD THIS TV ON ALL NIGHT BEFORE WITH NO PROBLEMS. AS SOON AS I START CHANGING STATIONS, OUT IT GOES. GOOD LUCK. WESTINGHOUSE WILL NOT EVEN EMAIL ME. I HAVE TRIED SEVERAL TIMES TO CONTACT THEM. I HAVE HEARD FROM THE LAW FIRM IN CALIFORNIA THAT IS GOING AFTER THEM. GO ONLINE, AND JOIN THE CRUSADE.
Posted on Apr 08, 2009
SOURCE: Westinghouse 1080P 42" LCD TV - HDMI stopped working
The above mentioned ide by seanpf worked like a charm I have had this happen multiple times.
Posted on Jan 23, 2010
I have a white westinghouse 40 inch tv model vr4090 and the tv wont come on it shows the power indicator turn from red to blue but no picture or sound
Westinghouse tx-42f430s wont turn on fix repair - YouTube
? 5:29
https://www.youtube.com/watch?v=DdfLu5RdVEQ
May 12, 2014 - Uploaded by After Hours Tv & Pc repair
Westinghouse model # 32H1G1 won't turn on , but If I unplug the TV and wait for a ... -tx-42f430s-42-inch-lcd-tv-appears-bricked-595806.html ... I have a Westinghouse 40" TV that is working, but sometimes it won't turn on.
Westinghouse LED LCD TV Repair - YouTube
? 12:32
https://www.youtube.com/watch?v=DGg5iuFEfdM
Feb 8, 2014 - Uploaded by INSIDEHARDWARE CHRIS
Westinghouse Model: LD-4680 Similar (LD4655VX LD4255VX ...Samsung LCD TV Repair - TV Won't Turn On - How to Replace Power Supply ...
40 inch Westinghouse lcd tv black screen help - YouTube
? 1:39
https://www.youtube.com/watch?v=tKLRihGgZAs
Nov 21, 2011 - Uploaded by Jason Flynn
Dec 19, 2015 | Westinghouse Televison & Video
Westinghouse how to
Back-light problem.Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.It will be best to replace the inverter board as card basis.
Aug 08, 2014 | Westinghouse LD-3260 32-inch LED LCD TV...
Wd65738 flickering
I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
Jul 10, 2012 | Mitsubishi WD-65738 DLP TV
Will my westinghouse tv work in the uk in conjuction with a bush hd freesat box?
Both the tv and the Bush HD freesat box was bought in the Euoupean union?Wright?Yes,it will work together with no problems,both the tv and Bush HD freesat box both are recieving the same tv incomming broadcasting signal in PAL signal frequencies will be compatible.
Oct 27, 2011 | Westinghouse TX-47F430S 47 in. LCD TV
Westinghouse tx-52F480s. flicker, turned into colored lines. now all black. all inputs. what is the problem. which board?
Most likely the T-CON board it is dead.The tv have colors vertical lines alway causes by a dead T-CON board,if only this problems,happen by the tv itself only.Not causes by u or an object by hitting it with forces,than the tv LCD screen panel it is damages and tv it is worthless as a whole tv set.Because the tvs LCD screen panels are very important to the tvs and it is 90% of the costes of all tvs.The T-CON board sit in the middle at the bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Jun 13, 2011 | Westinghouse TX-52F480S 52 in. LCD TV
Westinghouse 32 inch lcd hdtv model # VR3209DF. screen problems
Ur tv the Tuner board,that where the coalax broscast signal cable come in to this board.This board is starting to have problems.
Jun 07, 2010 | Televison & Video
My 27inch westinghouse flat screen has sound but
Ur LCD inverter board is dead.Replaced this LCD inverter board u will get ur picture back.This a simple repair take ur tv aparts,take out the LCD inverter board,it a long shape of a board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replament.U will get ur picture back.Ok,good luck,labors about an hour work.
May 08, 2010 | Westinghouse 26" LCD Flat-Panel HDTV
I bought the westinghouse Model sk26h520s back in January. I bought a refurbished model from Mac Mall. The picture has never been great. We only got it to look halfway decesat with many adjustments to the...
Hello, please email me some more information about the TV to westytech@wde.com, I will need the model#, serial#, and the TW#, all located on the back of the unit. I can assist you as far as to check to see if you need a firmware update and if you do I will provide it for you.
Oct 23, 2009 | Westinghouse SK-26H520S 26 in. LCD HDTV
Televison & Video Logo
1,137 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
