Question about Eljer Home
I havve two Eljer non-wateraver toilet (Patriot?)
I have two Eljer non-watersaver toilets (Patriot?) that plug up much easier than any other toilets I have ever had. Is this a common problem with these Eljer toilets?
  • 224 Answers
I've never had a problem with Eljer toilets. Try adjusting the fill valve so that it allows more water to enter the tank (if you're over the flush valve, install a coupler made from PVC around the neck of the flush valve- inside diameter of the coupler needs to be the same as the outside diameter of the flush valve filler neck).
Posted on Jul 10, 2009
Why does my new toilet spurt water?
There's a small clog. Plunge it until it flushes and flows freely.
Oct 12, 2014 | Eljer & Patriot& Elongated Toilet Bowl
Toilet is only a couple years old but gets a ring at the water line that won't come off. I have 3 other toilets in the house much, much older that don't have this problem. This one is rarely used. ...
The problem is as you said it is rarely used and the ring is from the lime build up from the water evaporating at the same line all the time. You will need to use or at least flush the toilet more often and maybe put a auto type bowl cleaner unit in this toilet. The auto unit I speak of would be a hang in or tablet type. http://www.bing.com/shopping/searchq=auto+toilet+bowl+cleaner&FORM=HURE
I do not mean to recommend on over any other.
Mar 19, 2011 | Eljer & Patriot& Elongated Toilet Bowl
Need eljer toilet seat savannah part no.124-1900-00
Google search: eljer toilet seat savannah
Top result shows following product:
http://www.lockeplumbing.com/detail.asp?c=Toilet%20Seats&s=Odd%20Eljer&s2=&sku=ELJ-124-1900-00&r1=WHE-USS25C&r2=GRU-595916&r3=FEI-NL9-LED
Eljer pdf shows same toilet seat
http://dallas.eljer.com/Products/Toilet/CatalogPage/0911905.pdf
Eljer customer service:
800-442-1902
Monday through Saturday
8:00 A.M. to 6:00 P.M. EST
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on plumbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 24, 2011 | Eljer Toilet Twopiece Savannah ...
I need a Toska toilet seat replacement
Toska seat is called Manarque seat, for the Herbeau toilet.
I searched for square toilet seat.
Site shows toilet seat for the Herbeau $135
http://www.bizrate.com/miscellaneous/herbeau-toilet-and-toilet-seat/
http://www.faucetdirect.com/herbeau-0651-monarque-elongated-toilet-seat-with-cover-and-finish-matched-hardware/p671327?source=shz_671327&aid=228165868
Pdf from Eljer showing Tosca toilet looks very similar to product shown on links above.
1.6 gallon water-saving flush tank.
http://dallas.eljer.com/Products/Toilet/CatalogPage/0912000.pdf
Dec 14, 2010 | Eljer Toilet Seat Tosca 124200000
All of a sudden it won't flush, little resavoir in take empties but water in tank doesn't
The Problem can be fixed by fixing a new flush meganisum to your cystern, sound like the old flush rubber is stuck in the cloused posision, have a look by taking the meganisem of, if so replace it .
Jun 11, 2010 | Eljer & Patriot& Toilet Tank With Lid
Not enough water in the bowl after flushing
I don't know what kind of toilet you have, but if it has a tank, then probably the tube that squirts water down the pipe into the bowl has come out. Take the top off the tank and as you watch, flush the toilet and make sure water is going thru the tube down into the pipe. good luck
Mar 07, 2010 | Eljer & Patriot& Elongated Toilet Bowl
I have 40 year old eljer toilets seat cracked,
This website appears to have what you need
http://www.plumbingsupply.com/eljertoiletparts-patriot.html
Hope this helps?
Jan 20, 2010 | Eljer & Patriot& Elongated Toilet Bowl
Describe your Eljer &
I have not heard of any toilet manufacturers offering a lifetime guarantee (except maybe for defects in manufacturing), especially since flappers tend to deteriorate with exposure to chlorinated water, fill valves eventually fail, and toilet seats do break. Pick out a replacement that suits your fancy, unbolt the old one from below, and install the new one. Don't overtighten as the porcelain could break.
Jul 17, 2009 | Eljer & Patriot& Elongated Toilet Bowl
Shifting & leaky toilet
They make plates that go under the  (plastic pipe?) flange which allows one to tighten down the toilet better. Seems that your flange and toilet are not level with one another? You may need to use plastic or other shims to level the toilet before  tightening the bolts.
Feb 26, 2009 | Eljer & Patriot& Elongated Toilet Bowl
Home Logo
312 people viewed this question
Top Eljer Home Experts
john h
Mike
Charles T Nevin
Charles T Nevin
Are you an Eljer Home Expert? Answer questions, earn points and help others
