We have a split A/C unit. Model kf-18c or kf-24c,
We have a Rheem split A/C unit. Model kf-18c or kf-24c, The indoor unit will power off on its own, the outdoor unit remains on and the inside unit freezes up. To power off the system, we have to shut off at the circuit panel. Is there a part that i can replace to get us working again? Thank you,
Thomas
  • 158 Answers
Could be the main PCB board
Posted on Jul 02, 2009
Aircondition builds ice on coil
Either lack of refrigerant, stopped up metering device or capillary tube/s, or lack of air flow (due to bad blower motor, or dirty indoor coil) Good luck.
May 19, 2014 | Rheem Complete Split System Gas Furnace 5...
F6 error code on Frigidaire split unit ac, model FSC12CM6J/FSE12CM6J. Solution says to check fuse? Where is this located?
It seems like the indoor fan is not running. Quite a few split systems have a fuse on the indoor board. It will require stripping off the outer cover of the indoor unit and removal of the electronic box cover. The indoor board is in there. The fuse may be replaceable or it may be a type that is soldered on which makes it virtually non replaceable. ( A new indoor board will be required) Make sure all power is turned off or disconnected before you do anything. Another possibility is the fan motor start capacitor has failed. Try this first before stripping the unit. When the unit is turned on and the outdoor unit has started, give the indoor fan barrel a flick with your finger to start it spinning, if it keeps spinning and the error doesn't appear, it would indicate that the fan motor start capacitor has failed. The capacitors on indoor units are normally small black square boxes with 2 terminals on it. These capacitors are mounted inside or close to where the indoor electronic box is. Again, make sure all power is disconnected or turned off at the meter box before you do any disassembly.
Apr 09, 2014 | Frigidaire Heating & Cooling
LG SPLIT SYSTEM AIR CONDITIONER INDOOR UNIT WILL NOT POWER UP
as described the voltage you are seeing is fake. if there is no led lighting in the indoor unit check the small transformer in the indoor unit you should get 12V DC or 24V DC out from it
Feb 10, 2014 | LG Heating & Cooling
Hi,i have split air condition unit AMCORAIRE the model is AOS241HX and an inside unit i se code P7 and compresor and condensan fan doesent start on
P7- communication problem between indoor and out door. Check power in out door. if there repair/replace out door PCB> If no power in out door, replace indoor PCB.
Jun 01, 2011 | Heating & Cooling
Can the LG LP1010SNR air conditioner operate in farenheit instead of celsius?
Hi there
According to LG nope. However this may help you
61f = 16C
63f = 17C
64f = 18C
66f = 19C
68f = 20C
70f = 21C
72f = 22C
73f = 23C
75f = 24C
77f = 25C
79f = 26C
80f = 27C
Regards
Gordon
Apr 17, 2011 | LG Heating & Cooling
I have a Chigo Mini Split KF-32GW/A. What is
E5
PG motor
display at
off state
flicker 5/7
SEC
display
at off
state
no feedback
signal of indoor
fan
1、Check whether two sets of plugs on the outlet end of
the motor have loosed from the socket of the
electric control board, insert it firmly when loosing.
2、Check whether the indoor motor has damaged, the
motor should be replaced when it is damaged
3、 Check whether the controllable silicon and other
components on the electric control board have
damaged, replace the controllable silicon or electric
control board when they are damaged.
Jun 12, 2010 | Heating & Cooling
Indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Apr 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Going to replace hvac system. Don't know what
According to the model number it is a 2 ton or 24,000 BTU unit. It is very important that you change the indoor coil as well as the outdoor section, due to it being a 10 SEER unit, and the new basic systems are 13 SEER, the old coil cannot handle the higher SEER ratings.
Rheem and Ruud are the same equipment, just 1 number different on the model number.
I hope this has helped, please rate the new guy :)
Please contact me if I can be of any further help to you.
Have a great day!
Sincerely,
Paul Gibson
Apr 04, 2010 | Ruud Matching Split Air Conditioner
I have a Rheem model 111250 - Can I Control Tempurature?
Remove the cover where the power cord connects (there are 2 screws on the lower side of the cover). There is a small black dial with numbers like 50, 55, 60, 65, 70. Just turn the dial to a new number.
Aug 15, 2009 | Rheem Gt199dvp Heavy Duty Tankless Water...
Heating & Cooling Logo
207 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
