Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a 19 hp craftsman there is no spark in the plug, it has a new battery and it does turn over.
  • 61 Answers
Check coil.. Most likely the problem.
Posted on Jul 02, 2009
I have a craftsman riding mower model 247.288810. While cutting my lawn the engine all stalled and would not start anymore. I changed the spark plug and the battery is new, what could it be?
there are 3 safety switches,clutch,deck and seat, Craftsman 247288810 Lawn Tractor Parts
take the cover off so u can access the coil,unhook the black wire from the coil,not spark plug cable,try to start it,if it starts then a safety switch is bad,if it doesnt,then jump the solenoid,if it starts then it is the seat or clutch switch,if you want to bypass safety switches,connect a switch to the ground and coil
Jul 28, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Show me where spark plug is
i think that uses the kohler 19 or 20 hp engine the spark plug is just above the center of the wide valve cover it is easier to change if you remove the plastic upper cover from the engine it's only a few bolts and while it is off clean the fins off that's how the engine cools off
Jun 08, 2012 | Craftsman Lawn Tractor Operators Manual...
Craftsman 17hp 42" cut riding
Sounds like its not getting enough fuel. clean the fuel system and the carby. The valve clearances also need to be checked.
Apr 07, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Battery reads 19 volts,mower just spins when trying to start
The spark plug is most likely NOT getting spark. Is the wire connected to plug? If tractor was stored over the winter, who prepared the engine for storage? Some mechanics will take out plugs & spray some oil into cylinders to avoid any rusting in cylinder then the plug is replaced but NOT connected.
Maybe the plug needs looking at.
Louie Almond
Mar 27, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
No spark
It sounds like the coil or a wiring issue.Try a new spark plug or coil.
Jul 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a Sears Craftsman Lawn Tractor, Model 917.272751, S/N 060503B025327, B/S engine 18 Hp Model 31H777, Type 0202-E1. I have a new battery and a new starter on it but when I hit the starter the engine...
Have you checked the oil in the crankcase, is it full ?
Has engine been sitting along time ?
Have you double checked all the battery conections, all are tight, good ground connection to motor ?
Please let me know.
Feb 07, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Run out of things to check
coil{solid sate ingnition) see if u hav spark ground plug,low light {shade} to see spark,AWAY FROM BUILDING and GAS!! hav fire extinguisher handy..remove all ignitable fuilds,well ventilated area..if spark,check "kill" switches on throttle,clutch pedal and seat.
Aug 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
19.5 HP Craftsman Lawn Tractor won't start...any ideas?
Does the motor even turn over. Have you checked the carb. for gunk or gas trash.
May 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How to get the spark plug out from 17.5 HP 42
should be behind the front of the mower grille, tilt the hood foreward to gain access to the plug or try getting it from under the front.
you will need a plug socket to remove the plug
May 10, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Have new proper batt.Have new starter celenoid,new
Remove spark plug and attempt to crank. If it turns faster (without compression) it may be valve adjustment. If it still turns over slowly with plug out check battery ground for tightness to mower body. If the ground is good check the starter by removing battery and atttaching jumper cables to pos and neg battery terminals first, then the pos jumper to starter terminal (where red wire attaches). Then touch the neg jumper to a good engine ground (I use shroud bolt). Be careful as this last connection will cause some arcing. If it still cranks slowly with the plug out, it is probably the starter.
Apr 11, 2009 | Craftsman Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
182 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
