Air conditiner cuts on and of as if a breaker is being thrown and the no. 7 and 3 flash on unit, it may stay on one second or five seconds or a little longer.
  • 158 Answers
Could be the main PCB board is faulty
Posted on Jul 02, 2009
How do i reset a zone circuit breaker in an hz432 control panel
remove cover and look for a micro switch labeled purge press and hold for three seconds all zones will reset all dampers will open equipment fan will run for up to five minutes and a yellow lite will flash
If you need further help, I’m available over the phone at https://www.6ya.com/expert/mike_9693b5ad75773352
May 31, 2014 | Honeywell Truezone HZ432 Zone Control...
Can't set temperature
first go turn breakers off at indoor unit or if gas turn switch or unplug for thirty seconds.should be a hold button on thermostat , set desired temperature and press hold allow five minutes to go by.listen doen anything at all happen at unit.
if nothing happens after five minutes remove sub-base from wall and at the thermostat jump with a wire the r terminal and the white terminal see if it comes on if so you got a bad thermostat most likely.
Dec 02, 2011 | Honeywell Programmable Thermostat Heater
My Fujistu AST9LSACW split system air-conditioner wont blow cool air. the outside unit AOT9LSAC doesnt seem to be working at all. The power light stays on but the timer light flashed about 15-20 times a...
There are two things you can check outside before calling a service technician. The first is the breaker to the outside unit. There is a breaker or disconnect near the unit. If there is nothing wrong with the electrical supply, check the refrigerant level. If the level is low, the pressure switch will cut off power to the compressor to protect it from damage. DO NOT try to recharge the compressor yourself.
Jan 30, 2011 | Fujitsu Heating & Cooling
The message waiting light keeps flashing on the phones despite all messages being deleted ...how do I stop the light from flashing on the upper left of each unit??
Hello! At the base unit press and hold the "FIND" button for five seconds....Base unit will begin to beep; Ignore and hold for five seconds...
Guru..............saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Jan 05, 2010 | Cell Phones
Flashing airbag light on 97 maxima. Car was in an accident, airbags deployed, replaced bags and controller why won't the light stay off
To manually check air bag codes, turn the key On and push the driver's door switch (at the bottom of the B-pillar) 5 times or more within 7 seconds of turning the key ON. Then watch the air bag light flashing codes. The air bag light will come ON for 3 seconds and then give fast flashes if there is a code. Count the fast flashes as the code. So the air bag light on for 3 seconds and then 8 flashes is a code 8 for the passenger air bag circuit. after counting code clear codes and see if they come back
Nov 22, 2009 | 1997 Nissan Maxima
Window a/c unit won't turn on...dead.
Made an appt. with a repairman.
Jun 22, 2009 | Heating & Cooling
I have a Rheem (Criterion) unit and i'am having promblems with the main burner staying on. When i turn the unit on everything operates like it should up to the main burner staying on.Once the main flame...
Run a wire from the sensor down to the control board conector. Bypass the sensor wire around the connector in the blower deck.
The connection can be wire nutted on the sensor lead with the wire (16 or 18 guage stranded wire works) routed through the blower deck to the other side of the plastic wire connector on the blower deck.
The Sensor operates at high voltage but very low current. The connector will sometimes fail due to humidity or wear.
I have seen this on the Rheem or Ruud furnaces.
Hope this helps.
Matt
Jan 07, 2009 | Heating & Cooling
Triton Millenium Power Shower
generally if the flow sensor notices no water through the pump it will auto matically shut the pump down. so it could be the flow sensor is bad or the pump is not working like it should. now it depends on how old the pump is. i would start with the flow sensor.
Aug 30, 2008 | Home
Possible heat related problem to television.
If you had the back off ,while in there jump any switchs that are related to cover being off,turn on set kisten for fan bearings .check air path ,especially in light unit.wayne
Oct 19, 2006 | RCA D44LPW134 44" HDTV
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
