Question about Singer 3116 Simple
Buttonholer stays in one spot
I have a Singer 3116 and when I try to use the buttonholer it stitches in one spot only and won't move. I have everything set according to the manual. It sews everything else fine.
SOURCE: singer 7436 buttonhole problem
I have found that the problem lies with the button hole pull down. Either it is too far down, or too far up. The problem that I have with it now is that it will never sew the button holes consistantly. I will set it where the button hole needs to be, and it will then proceed to place it where it wants to. Any help on this problem?
Posted on Apr 20, 2008
  • 13433 Answers
SOURCE: Singer 7462 buttonholer
try adjusting the size, see if it changes the result and go from there, you might also want to ask other experts, sewing machines are not my speciality.
Posted on Sep 28, 2008
SOURCE: buttonholer on Singer 2639 sewing straight ahead
Also make sure that you pulled the buttonholer lever down and pushed it back (it's on the left side of the presser foot) ... the machine won't make the forward and backward motions to form the buttonhole without it.
Posted on Aug 06, 2009
  • 4 Answers
SOURCE: Singer 3116 - SIMPLE the needle move up and
check that the needle is in correctly
Posted on Nov 20, 2009
  • 1116 Answers
SOURCE: I am trying to sew buttonholes with the one step
There doesnt seem to be a reason - you are doing everything as it should be - lever down to stop the foot according the the button size is the most overlooked step.
I would take the buttonhole foot off and see it is moving as it should. Don't force as the plastic parts can break and then try again to make the buttonhole.
If you still cannot make the buttonhole, the problem may be the control switch and this would have to be checked by a Singer Sewing Machine Tech.
Check your warranty - faulty switches are covered for two years, but you pay the labor.
Posted on Mar 29, 2010
Singer simple 3116 buttonholer does not move
Hello Tamera. If you still have the manual, have a gander at page 48 or download for free at this link: Singer 3116 Simple Instruction Manual Page 55
Make sure that the Automatic buttonhole foot is clicked-on the correct way. The slider for the button should be at the back.
Please give me a 'thumbs up' or ask more specific questions.
Happy buttonholing.
Sewingirl/
May 09, 2018 | Singer Sewing Machines
Singer 1036 1-step buttonhole foot. It will make 1 perfect buttonhole. When I try to make the next one it makes a short buttonhole, never moving forward enough to hit the lever.
Possibly your machine does not make repeat buttonholes and you need to set every time? Are you stitching all the way around before resetting.
Dec 17, 2016 | Singer Sewing Machines
When using buttonhole attachment, machine does not move instead sews in one spot and collects thread coming up from bobbin. Any ideas?
make sure the buttonhole option is chosen
and then pull down the buttonhole lever
it should come down against the buttonhole foot
Apr 25, 2016 | Singer 5400 Sew Mate 60-Stitch Sewing...
Singer Simple 3116 only sews backward.Looking for answer I saw earlier that involved several steps including buttonholer
You are stuck in buttonhole. The selector knob does not spin round and around. It is moved from Stitch 1 to stitch 14 and back. Try selecting buttonhole and then running the knob in the other direction to straight stitch. If that does not work, (1) drop the lever that senses the button hole attachment, (2) sew a few stitches backward, (3) push the button hole lever rearward, once, hard, (4) rotate the stitch selector to straight stitch.
Jan 09, 2015 | Singer Sewing Machines
Sews one spot won go forward back buttonhole
It is stuck on bar tack...change the mode to normal, reset then try again
Mar 12, 2014 | Kenmore Sewing Machines
My fabric isn't moving... the stitch is staying in one spot. Help?
What stitch length are you using? And are your feed dogs engaged?
Apr 21, 2011 | Singer 3116 Simple
My sewing machine does not stitch when I press the motor. The needle moves up and down but only stays in the same spot. What should I do?
:o) Did you re-engage the clutch after you wound your bobbin? Also check to see if your feed dogs are lowered... and that your stitch length is adequate.
Feb 05, 2011 | Singer 3116 Simple
I am trying to sew buttonholes with the one step button hole function on my Singer 3116 - Simple. I have been using the function with no issues, but now for some reason, the machine is stopping short and...
Mar 29, 2010 | Singer 3116 Simple
Buttonhole making instructions from the manual of the Singer Simple do not seem to be accurate. The tension is incorrect and the machine is only sewing down one side without creating the satin stitch/...
Some machines will start out by sewing a straight stitch all the way around the buttonhole area first and then will zigzag/satin stitch along the sides. Bar tacks will be the last stitches sewn - hope this helps!
Nov 09, 2009 | Singer 3116 Simple
Buttonholer operation
push the lever back, look at your manual and you will see what I mean. Read the manual and watch the dvd and you will see what you are doing wrong.
Apr 10, 2009 | Singer 3116 Simple
Singer 3116 Simple Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
