Washing Machines Logo
A
Anonymous Posted on Sep 03, 2014
How do I reset my Frigidaire Affinity front load gas dryer when the LOC is displayed
Sam
Level 3:
  • Master 3,247 Answers
  • Posted on Sep 03, 2014
Sam
Master
Level 3:
Answers
3247
Questions
0
Helped
1306255
Points
10378
Likely solution as I do not have the full model number of your dryer.
This means dryer control board thinks your machine is locked--- to get it out of lock mode normally do this:
press and hold "Options" and "Select" at the same time until it unlocks
If it doesn't unlock within 20 seconds you have a bad control board and it needs to be replaced.
see page 11 in this manual.
http://manuals.frigidaire.com/prodinfo_pdf/Webster/137118600een.pdf
5 Related Answers
Anonymous
  • 639 Answers
  • Posted on Aug 25, 2008
SOURCE: frigidaire affinity indicates 'err' light - nothing else
Dear Abhkss
ngfam at you service,
Sounds like you need service for electronic parts!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Anonymous
  • 166 Answers
  • Posted on Sep 08, 2008
SOURCE: Frigidaire - GLTF2940FS0 -LOC message on display
Peace,
ngafm at your service,
With an error code or loc message the only way to find and to repair this is,
First unplug the washer and wait a ten minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Anonymous
  • Posted on Aug 05, 2009
SOURCE: Frigidaire front load, ERR LOC, washer won't run
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
Anonymous
  • Posted on Nov 02, 2010
SOURCE: How do I reset my Frigidaire Affinity Front Load
My Fridgidaire Affinity front load washer has a ERR pause and I can't reset it. How do I clear this
Anonymous
  • 196 Answers
  • Posted on Mar 01, 2011
SOURCE: How do I access the drain pump on a Frigidaire
If you cant access it from the front You will have to tilt the machine back as far as safely possible to access the bottom of the machine. Locate the drain pump which will be at the bottom font or back corner and remove the hose that connects the pump to the tub, you will need to have a basin ready to catch any water. You most likely have a sock or something stuck. Hope this helps
Cant open the front door seems like its locked
My frigidaire affinity dryer displays LOC - Fixya
www.fixya.com/support/t4561247-frigidaire_affinity_dryer_displays_loc
my frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please - Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer question. ... Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its ... Open Questions:.
1helpful
Frigidaire affinity dryer loc
LOC is a generic lock code meaning the door was either locked manually or accidentally. Also LOC will lock the control panel and can be manually locked as well. Try to reset the unit for about 10-15 minutes and retry.
Error loc on frigidaire dryer
The LOC indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. Hope this helps.
1helpful
Push any button and 'loc' flashes seems to be locked out
Press Options and Select at the same time and hold for 10 seconds or until "LOC" is no longer displayed to unlock the controls. Press and hold the same buttons for 10 seconds until "LOC" is displayed alternately with the estimated cycle time to lock the controls. Unplug the machine for at least half an hour, if pressing the buttons does unlock the controls, to forcibly reset the machine control and eliminate the possibility of an electronic glitch.
3helpful
Loc
It means the control is locked to avoid having someone accidentally start or stop the dryer. Press and hold the Options and Select buttons for 10 seconds or until the “LOC” on the display is cleared. Locking the control is done the same way it is unlocked.
1helpful
The LOC flahes on my display, it allows me to pick a cycle but i can not start it. Please help, i tried to press options and select at the same time for the LOC to stop flashing...is there anything else...
"LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. This will fix the issue.
Thank you !!
75helpful
7answers
My frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please help
Hi, "LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. Hope this helps.
When trying to start washer LOC shows on the display and washer wont start and we're unable to change settings????
Unplug the washer power cord and plug it back after 2 minutes and see if the washer reset it self. I think it will.
1helpful
Dryer shuts off, no heat, AD code
During normal operation, the display may show: “ad” - dryer is in an auto dry cycle. “dn” - cycle is done in auto dry. “PF” - a power failure to the board has occurred. “Err” - an error has been detected. “LOC” - control lock is activated. “PAU” - cycle has been interrupted.
3helpful
LOC Blinking
Control Lock
To avoid having someone accidentally start or stop the
washer, press Options and Select at the same time and
hold for 10 seconds until “LOC” is displayed alternately
with the estimated cycle time. To unlock the controls,
press Options and Select at the same time and hold 10
seconds until ”LOC” is no longer displayed.
Top Washing Machines Experts
john h
