Question about Canon PowerShot SD890 IS / IXUS 970 IS Digital Camera
SD 890 LENS STUCK IN OPEN POSITION
I took it to the beach, was very careful to keep it clean, but my guess is there is a tiny grain of sand interfering with the lens closing, warranty ran out last month. . .
    Scholar:
  • 155 Answers
Turn on the camera. now press the buttons W and T alternatively. while doing so gently assist the lens assembly to roll in. it will help.
once you get the lens assembly in. shutdown the camera and open it.
its easy if you have the proper tools.
now reach for the lens assembly and reassemble it carefully
Posted on Jul 02, 2009
I went to the beach, and took puctures there. When i got home and tried to use my camera, the lens wouldnt fully expand and the camera says "lens error"
My guess is that the lens has some sand in it. You might just want to open the lens as much as possible and give it a good cleaning with rubbing alcohol on a cotton swab as well as blowing it out with canned air. I know it seams kinda nuts, but if cleaning it doesn't work try to manually push the lens in slightly to free up some stuck sand. Also, you could tap the camera on a hard surface with a small piece of fabric under it to try to knock out some more of the sand.
Hope that helps!
May 10, 2011 | Nikon Coolpix S4000 Digital Camera
Well I took my camera to the beach and I think I may have got a grain of sand into my camera lens. Now it turn on and the lens comes out but not fully and it says lens error it also makes a beeping noise...
your camera will need a good air clean up in the lens mechanism its mean to be dissamble to do so
by a tech ...
hope that give you an idea
regards Allan
Sep 02, 2010 | Cameras
Digital camera dropped lens-opened on the beach and now the lense will not open properly
Hi
There is sand in your lens and it is jamming upthe gears. One grain of sand will cause the lens to fail! You can try to take the lens apart and clean out the sand but it's not easy and an opened lens usually never focuses exactly right again.
Look for a defective camera online that has a good lens but broken LCD or some other problem and fix that one using yours as parts or have yours fixed with a new lens.
We can do a new lens install for you for about $80-90 I believe. If we can help please let us know!
Thomas D
Owner, Darntoothysam com
Affordable Digital Camera Repair
Sep 20, 2009 | Canon PowerShot SD870 IS Digital Camera
Sand in my camera
Sand, water, salt water, dirt and dust can damage the lens to the point of no return, so to speak.
It may not have been dropped if you had used the wrist strap, how ever it is now in damaged condition.
The lens needs to be taken apart to completely clean out the sand. This is a very tedious and is a job for a professional with experience.
The parts are extremely small and have close tolerances, thus any dirt or sand can cause grinding or damage to the internal parts of the lens mechanism.
If you ever get a chance to see the gears and the gear teeth, you would understand why just a few grains of sand can jam these small parts. One grain of sand can stop a lens gear from working and possibly cause a broken gear. The parts are so small that in order to see the grains of sand which cause the problem, it may be necessary to use a magnifier lens.
To even make things worse, there is grease usually on the gears. The grease will hold any sand and cause it to stick in place. Cleaning these gears is not very easy.
I have done it, and returned the camera to working condition, but not an easy job.
Aug 30, 2008 | Nikon COOLPIX L3 Digital Camera
Lens cover is stuck half way open on Lumix DMC-TZ3
argh! me, too! i love this camera, but the lens cover is just plain stupid. we used the camera at the beach for a couple days, and i could tell a grain of sand got stuck behind the lens cover. now it is jammed and the camera is totally out of commission. why make a camera built for outdoor conditions, then put a lens cover like that on it!! i can't find a tech who can fix it, either. went to three shops in NYC and all said the cost to deal with it would pretty much buy me a new one... ! :(
Jul 29, 2008 | Cameras
Spot appears in pictures and LCD display.
That's a good bet, I think the service centers will do this as an
"annual internal cleaning" although I don't know what they will charge. Taking apart the optics is challanging and risky.
Jul 01, 2008 | Fuji FinePix F20 Digital Camera
Does it need regular cleaning?
Sand generally has no effect on the electronic side of the camera, however it will definitely can cause problems with the mechanical aspect of the camera such as the zoom lens. this can be removed with a can of compressed air.
Suntan lotion likewise should not be any problem except for smudges on the housing/casing and especially bad for the lens. Additionally, the lotion would help the sand adhere to crevices and nooks of the camera. Wiping should get you just fine.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 17, 2008 | Canon PowerShot SD600 Digital Camera
Lens cover stays open
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Oct 30, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Canon SD600 lens jam
I followed the directions contained in http://www.avh.dds.nl/Fix-Canon-SD600-Lens-Error/ and by disassembling the camera and turning the rotor just a little bit (page 4 of the instructions), it freed up the lens and it is now working perfectly! The camera had been put down on the lens as the lens was retracting and I assume that jammed the retract mechanism. While the camera was open, I blew out whatever dust/dirt was there (didn't see much). The fix took me probably 20-30 minutes, and I am very pleased with myself!
Oct 24, 2007 | Canon PowerShot SD600 Digital Camera
Lens cover
I was lucky to solve my problem with sand-stuck-lenscover with 6 bar compressed air.
Aug 11, 2007 | Nikon COOLPIX S9 Digital Camera
Canon PowerShot SD890 IS / IXUS 970 IS Digital Camera Logo
599 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
