Question about Aloha Housewares 02044 Compact Heater
My Airtech ceramic heater model 02044 no longer heats. The 3 comfort controls (cool, low, high) all emit cool air. The filter is clean, the fans, swing and remote control all work.
    New Friend:
How much did it cost new ????
Posted on May 25, 2013
3 Suggested Answers
shastalaker7
  • 1515 Answers
SOURCE: cz 446 comfort zone ceramic heater shuts off
Hi, the problem you are having is the thermostat control, and dimming the lights is a indication of the neutral side of the control if faulty.It is drawing enough amps to make you're home lights blink, so I would stop using it now and if you are inclined to replace this control yourself I would. If this is something you would not care to take on, I would get an estimate for repair at a appliance repair store, compared to replacing the unit with a different one.I am sorry to tell you this, but it will only get worse and what I have recommend is for you're safety.
Sincerely,
Shastalaker7
PS Please keep me informed of the situation, as I would love to be of any help you may need.
Posted on Dec 05, 2009
  • 4736 Answers
SOURCE: The Holmes Comfort Temp ceramic heater works fine
These heaters were not designed to be serviced in the field. If it's not over a year old, it may still be in warranty. Contact Holmes through there website www.holmesproducts.com for more info.
Posted on Jan 19, 2011
I have an airtech fan heater model 02044. Is it possible to get a replacement remote control?
Only from the company that made the product, but we do not sell parts here.
Jul 10, 2017 | Dryers
My Comfort Zone Ceramic electric heater CZ488 does not heat on high or low, but the fan that puts out cool air works. What is wrong.
It's mostly likely that somewhere in the circuit for the heat that it has opened somewhere so you don't have a complete closed circuit anymore. If it's old and not terribly expensive I'd just replace it. If it's not that old I would see what kind of factory warranty or store warranty night still apply to it, because I can only imagine that it would be very difficult if not impossible to get replacement parts for it, or the price of said parts would cost more than the price of a new unit. Please vote for my answer if you found it helpful, and let's us know your results. Thanks and good luck!
Feb 03, 2015 | Comfort Zone CZ488 Ceramic Heater
I need to know what the voltage for this unit
Model: REG-123H
  • UPC: 855326002968
  • Product Type: 12,000 BTU Window Air Conditioner & Heater
  • Product Dimensions: L: 24.00" x W: 24.00" x H: 16.00"
  • Product Weight: 88.00 lbs.
  • Product Color: White
  • Application: Used to cool individual rooms
  • Type: Window Air Conditioner
  • Warranty: 1 year; 5 years sealed system
  • Coverage Area: 550 square feet
  • Voltage: 230 volts
  • Heater: Yes
  • Air Flow: 266 CFM
  • Amps: 5.5 amps
  • Heating Capacity: 11000 BTUs
  • Frequency: 60 Hz
  • Cooling Capacity: 12000 BTUs
  • Dehumidifying Capacity: 3.6 pints
  • EER: 9.8
  • Heat Pump: No
  • Number of Fan Speeds: 3
  • Programmable Timer: Yes
  • Timer Length: 24 hour
  • Refrigerant Type: R-410A
  • Air Conditioner Type: Cool/Heat
  • Energy Star Rated: No
  • Air Filter: Yes
  • Built-In Air Purification System: No
  • Display Type: Digital
  • Remote Control: Yes
  • Adjustable Louvers: Yes
  • Adjustable Side Panels: Yes
  • Compatible Window Size: Min. Window
  • May 31, 2014 | Comfort-Aire RED-123 Air Conditioner
    My Aloha (Airtech) electric ceramic heater 02044 does not work on high. Could it be that the filter needs to be changed and if so, where can I buy the filter-that size does not seem to be readily...
    Take the entire unit outside and blow it out with compressed air.
    1) The filter is likely dirty and obstructing airflow. Be sure to clean per the user manual.
    2) The unit is probably full of dust and needs to be cleaned periodically.
    Jan 31, 2018 | Aloha Housewares 02044 Compact Heater
    Aloha breeze tower fan can it be a heater too?
    The one I have can. Pushing the comfort control button will cycle from cool, to low heat, and then to high heat and then back to cool.
    Sep 15, 2010 | Heating & Cooling
    Lg window-type ac
    Most little window units are mainly for 300-500 Square foot rooms.
    Should be putting around 80-105 degrees top out of those little units, Make sure that your thermostat is set for heat rather then the normal setting of cooling (Turn more towards Heat) also if you have a fan setting you may want to try lowering the fan to low speed vs high fan, which should give you more heat.
    Make sure the Filter is clean as well as the coils behind the filter or it will shut down the heaters quicker due to lack of air, shutting down your T-stat and bi-metals quicker.
    Nov 11, 2009 | Heating & Cooling
    My heater will kick on right away but after 3-5mins it stops producing heat then a few mins later it will start heating again. Why?
    The furnace could be shutting off on High Limit ...means your furnace is running too hot...check your filter and make sure return air vents are clean and clear....also it can be the Heat anticipator in your thermostat...which controls how many times your furnace cycles...basically your furnace should come on and off 5-6 times/hr ....need more info on your type of furnace and type of thermostat
    Oct 19, 2009 | Holmes Products HCH4062 Ceramic Compact...
    Williams wall furnace no longer adequately heats home
    A couple thoughts. On some of the wall furnace gas valves there's a knob that you can set for low fire or high fire. If your valve has this make sure it is in the high fire setting. Is the wall furnace controlled by a wall thermostat or a knob on the heater? With the thermostat turned all the way up like to 90, does the burner and fan continue to run or is the burner short cycling. Is the fan clean and running up to speed. Some of the Williams wall furnace had a two speed fan motor so when the fan came on at first it would run on low speed. As the heat exchanger got hotter the internal fan switch would switch it to high speed. Outside of that you would need a monometer to check the manifold gas pressure.
    Aug 31, 2017 | Heating & Cooling
    I have an Aloha Breeze heating unit Model #02044. It stays on for 2-3 minutes and then turns off. It will not stay on when the switch is turned to "on" position.
    Ya see, what you need to do is take it apart and clean it
    thoroughly. Clean the filter and the heating element. Insure proper air flow.
    Dec 18, 2008 | Aloha Housewares 02044 Compact Heater
    Aloha Housewares 02044 Compact Heater Logo
    613 people viewed this question
    Top Aloha Housewares Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you an Aloha Housewares Heating and Cooling Expert? Answer questions, earn points and help others
