Does not allow for hot water
The temp of the water is always cold. The machine ignores the temperature setting and only allows for cold water. Both hot and cold water are attached to go into the machine.
  • Jay Sackett May 11, 2010
    Have you tried changing water temp switch?? Is there a warranty on it??
  • 999 Answers
Check the hot valve screen. If clean you will have to verify there is voltage present at the valve when using hot cycle. If there is and the screen is clean then the valve is bad.
Eric
Posted on Jul 02, 2009
Hot water fills with hot and cold not strictly hot what is the fix
see the causes: and proceed with common sense. God bless you
Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine isn't working the way it used to--or should--try these tests: Is the hot water turned on? If not, turn it on. Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct. Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine is not working the way it used to--or should--check the following. Is the cold water turned on? If not, turn it on. Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct. Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the
Sep 22, 2012 | Roper Washing Machines
When trying to wash with hot water only machine fill slows and adds cold water then adds hot this continues until load level is reached and you end up with barely warm water is there any way to fix this...
see the causes and use the common sense. God bless you
Water temp control wont work, wrong temp comes out periodically set on hot comes out cold or set on cold comes out hot, already changed the temp control and new one does the same thing, any ideas?
There is a sensor switch that allows water from one tap or the other, or both. If this switch is flawed, it will confuse the temperature that is allowed to come from the faucets. You'll need to replace it. If you're skilled at this sort of thing you can do it yourself. If not, you'll need to call a professional. The replacement and repair doesn't take much time and is reasonably priced. If you're calling a professional, now that we've narrowed down the problem, you can call around and tell them you think your water temperature switch is bad and how much will it cost to have it replaced. When you've found a reputable pro with the best price, get them out.
I hope this helps. If it does, please come back to Fixya and rate my advice. Thanks.
Aug 05, 2011 | Washing Machines
Water temp setting of warm gives cool water
Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.If you're sure the machine isn't working the way it used to--or should--try these tests:Is the hot water turned on? If not, turn it on.Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct.Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
Jan 03, 2011 | Kenmore Washing Machines
I cannot get cold water to flow into the washer when this temp is selected? Only warm and hot work.
Hello there:
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine is not working the way it used to--or should--check the following. Is the cold water turned on? If not, turn it on. Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct. Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve. shoul look something like this somthing like this 15f2ecb.jpg
Oct 05, 2010 | Washing Machines
Oasis Elite auto temp control does not allow cold water
Ok, often the actual inlet Solenoid/Valves get "Gummed Up" and need to be "Stripped Down" and put in a bath of solvent for a bit, But, sometimes a couple of good "Whacks" with a suitable tool, will "Free Up" the jammed valve. I wouldn't wonder if this wasn't your problem all along? Anyway try that...
Mar 15, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool washing machine (WTW5200SQ0) temp problem
I turn off the cold water during the fill up, and then turn it back on after it has filled. I hate this washer too because of that.
Jan 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washing machine...only uses hot water
Make sure the hoses are connected correctly to the water valve on the machine. The connections will be marked with an "H" and a "C".
Given they are correct, most current washing machines have and auto temp feature on the water fill. It allows even cold water settings to bring in some hot water to make sure the water temp is hot enough to efficiently disolve your laundry detergant. The preset temps are usually around 75* for cold, and 105* for warm. Hot water comes in at whatever temp your household water temp is.
Sep 12, 2009 | Washing Machines
Washer wont allow cold water
Mixing valve should lock out the hot water when on the cold water setting. Either your hoses are crossed, or the mixing valve is flipped. To see if one of these is true, try it on a hot water setting to see if cold water comes in, or try just swapping the water hoses.
Jul 05, 2009 | Kenmore Elite 45986 Front Load Washer
Hot water not going into washing machine
hi there,
try the following, it may help:
* Is the hot water turned on? If not, turn it on.
* Is the washer getting cold water but no hot water? If so, check to see if the control panel
Nov 05, 2008 | Frigidaire Gallery GLWS1339EC Top Load...
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
