Home | Sub-Zero | 642 | I have ice forming on ...
Sub-Zero 642
Problem for Sub-Zero 642
I have ice forming on back wall above top drawer
By saraharding9 on Jul 02, 2009
i have ice forming on back wall above top drawer in refrigerator. Belive seal may need to be replaced. Any other suggestions?
Best Solution
posted on Jul 24, 2009
Very Helpful)
halftank123
Rank: Guru
Rating: 87%, 28 votes
The gasket would be the last thing I would suspect. Is the ice a ball to the left side or is it all the way across? Could be a sealed system issue or a bad thermistor. I would recomend calling a factory authorized servicer for proper diagnosis before putting the money into a gasket. Besides look at the gasket all the wat around for any damage and make sure the door is closeing properly. Isee units with torn gaskets all the time and it doesn't cause ice build up in th refrigerator side.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jul 02, 2009
Not Rated)
gmsierra91
Rank: Guru
Rating: 86%, 35 votes
Try replacing seal and defrosting the whole unit.. May be ice building up in the back wall of the refer and freezing condensation
Was this helpful?
Yes
No
Popular Solutions for Sub-Zero 642
Questions and Unsolved Problems for Sub-Zero 642
Do you recommend Sub-Zero 642?
Answer
Answer
Whar size allen wrench do you need to tighten the handle on a sub zero 642 fridge?
Answer
How high do the ceilings have to be to install a sub 642
Answer
Black pan below refrig is filling up and overflowing with water; what should I do to minimize the... (More)
Answer
ice maker is not working. I cleaned out ice and put back but now it won't make ice .
Answer
the refrigerator is not working. the temperature is at 60 degrees even though I have the temperature... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sub-Zero 642:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
