Question about Konica Minolta DiALTA Di200 Copier
COBAO error on NEC IT3520/KM Dialta 2010
When i start up the copier, i receive the error, "Malfunction Detected. Call for service. COBAO" Can anyone help define that code? Thanks
  • Konica Minolta Master
  • 6,696 Answers
Sir,
Was there a trash can or box of paper underneath the finisher part that moves up down. the code is failure of the up and down motor for the finisher. Normal happens when the trays that move down they hit something. or the mootr has failed. Open/close the door to the finisher, power off both power switches including the one on the rear left side and the one on the front panel. wait ten seconds then turn them on again. Also check to make sure there is not something binding the tray system
Posted on Jul 19, 2009
Bizhub 2510earer coad cobao
The FN finisher unit elevator motor malfunction.Remove the finisher unit and work with out.
Jul 22, 2014 | Konica Minolta Clutch for Di3510 3010 2510...
Dialta di 2510 has code COBAO
Did someone leave a trash can or boxes under the output trays? To solve this problem requires removal of the rear cover of the finisher. Then remove the elevation drive motor assemble. Be careful don't want the output trays to fall!!!!!! Then while placing them in their proper position re seat the drive assy. The top tray should be just below the orange rollers (If they are cleaned) you will see several actuators the trays has to just touch them.
Nov 14, 2012 | Minolta DiALTA DI2510F All-In-One Laser...
Cobao error after powering
Exit tray of the finisher is not moving up or down correctly, some leave a trash can or boxes under the tray hit it and damage was done, recommend a tech look at it
Apr 06, 2012 | Minolta DiALTA DI2510F All-In-One Laser...
WHAT DOES THE CODE COBOA MEAN? IT IS AN NEC IT3520 COPIER
It is the elevator malfunction.For reset press the trouble reset switch on the tech.rep.setting switches board or open and close the front door or turn OFF and ON the main switch.
Sep 28, 2009 | NEC IT3510 Copier
Minolta Di3510F indicated malfunction error with code COBAO. Can anyone help?
COBAo = Elevate mechanism malfunction.
The exit tray home position sensor is not blocked even after the lapse of a given period of time after the tray has started moving up.
An encoder clock input is not detected within a given period of time during operation of the tray.Check the sensors,motors and his connectors.
How to reset:
1. Press the trouble reset switch on the Tech.Rep.Setting Switches Board to reset the following malfunctions:scanner,fusing,exposure related malfunctions and C3FF.
2. For any other malfunctions open and close the front door or turn OFF and ON the power switch.
Aug 07, 2009 | Minolta Di3510f Bizhub Copier
Konica di3510 there is a code on the screen cobao
Elevation drive motor failure for the finisher /service manual
May 05, 2009 | Konica Minolta DiALTA Di200 Copier
Minolta dialta Di200 on screen :malfunction detected code:COO4E
C004E: Power Unit Cooling Fan Motor malfunction
Check the power supply fan for proper operation.
Nov 11, 2008 | Konica Minolta DiALTA Di200 Copier
Minolta dialta di520
problem code c1039  for d-i 620
May 10, 2008 | Minolta DiALTA Di520 Laser Printer
Copier not working
Is the copier a Minolta? If so what model there are different ways to rest code.
Feb 09, 2008 | Konica Minolta DiALTA Di200 Copier
Konica minolta Di3510...C0500 troubleshooting
C0500 refers to a low fuser temperature. You can attempt to clear the code by using the tech rep service mode.
Go to "Counter"
Go to "Trouble"
Trouble reset
If "warm Restart Swich" is asked for- This can be actuated through a small access hole on the right side of the control panel, using a straightened paper clip or something similar.
You may need to clear the counter by pressing "clear" and then "end".
After clearing the code, power cycle the copier. If it comes to "ready" you are all set. If not, you may have a blown heat lamp or thermal fuse which would need to be replaced by a technician. Good Luck!!"
Oct 30, 2007 | Konica Minolta DiALTA Di200 Copier
Konica Minolta DiALTA Di200 Copier Logo
925 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
