Question about Epson LQ 570+ Matrix Printer
Epson lq-570+ my printer is printing too many blank sheets after the print is done
    Problem Solver:
  • 4 Answers
Need larger print my epsonlq570+
Posted on May 06, 2012
Which OS are you using?
Posted on Dec 12, 2007
  • 452 Answers
Please check the printer driver you have installed, or easy way is please add the printer using the cd/driver disk recieved with printer
Posted on Nov 10, 2007
My printer epson lq-2180 print a blank paper and continuously ask me to feed paper..after i feed paper the same situation print a blank paper and continuously ask me to feed paper..this...
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed.
Jul 06, 2011 | Epson LQ-2180 Dot Matrix Printer
How do I print just one mailing label without running through an entire sheet time I print using an Epson LQ-590 and printing from the mail merge option in MS Word (MS XP)? In other words, when I print...
I assume you are using a sheet of labels, such as the typical 3 x 10 sheet. Word sets up the mail-merge document for printing the whole sheet, so if you print just one or two labels, you will `waste' the rest.
One way of using that sheet over is to create a mail merge that contains blank `dummy' addresses. It is rather involved and at best time consuming, and considered not worthwhile to save a partial sheet.
I service printers, and personally do not recommend that any label sheet be re-used. The printer curls the paper, in some cases fuses it, and causes the corners of the labels to be exposed, and possibly get caught in the printer (I have removed a lot of labels from inside printers)
Oct 18, 2010 | Office Equipment & Supplies
The printing goes off the page
pls set the paper size to the actual paper size you load.. you have probably selected legal size in your pc and load an A4 size paper onto the printer...
May 26, 2010 | Epson LQ 300+ Matrix Printer
I have an LQ Epson printer which has refused to print it passes out the paper which is blank. when i command a job, it just prints a blank page with out any writings
Do you hear the sound of the solenoid of the printer head during printing? if not then there is a cut traces on the head cable. if you hear it then you have to change the ribbon. try also to check the lever adjust bar on the printer (usually found with a blue head on the left part if it is an lq-2180++ model or on the right part if it is an Lx300++)
Feb 13, 2010 | Epson Stylus Multifunction Inkjet Printer/...
LQ 570 Printing garbled text
1st you cancel all the print jobs from the pc .
In run window type services.msc and the go to print spooler option just stop and restart the service. and also switch off and switch on the printer and try to cancel all the documents form print spooler it will remove all pending jobs.
Jan 12, 2010 | Epson LQ 570+ Matrix Printer
Epson print LQ-590 always paper jammed at roller when printing continuous 5 sheet of paper. May I know how to fix this?
the paper you are using may be moisten. pls try another paper sheets . purchase new papers.
if the problem continue clean the paper feeder assembly roller with moist cotton using cleaning liquid eg petrol or spirit etc.
Aug 21, 2009 | Epson LQ-590 Matrix Printer
Paper out
Have you considered buying an ink jet printer? You will find your money will be well spent. Epson all-in-one printers can be bought for less than $100.00 when they are on sale.
May 27, 2009 | Epson LQ-2180 Dot Matrix Printer
Speed of print
A printer is designed to print at a certain ppm (page per minute), so really there is only one way to speed it up. When you select the print option from the File menu, you can select properties and see if you can change the dpi (dots per inch) of the document. Your document will print faster but you will lose quality.
Nov 27, 2008 | Epson LQ-2180 Dot Matrix Printer
Epson lq590
check if your LQ590 is set for manual feedor continuous feed. There is a toggle switch somewhere near the rubber rollers,there are symbols that will indicate for continuous paper printing or manual, select manual printing. Also in your print window,select printer properties, select manual printing. Yourprinter might be set up for sheet feeder or continuous paper printing. hope this helped.
Apr 23, 2008 | Epson LQ-590 Matrix Printer
Epson LQ 570+ Matrix Printer Logo
141 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
