Question about HP OfficeJet 6110xi All-In-One Thermal Printer
Can i disable the scanner on this model? - HP OfficeJet 6110xi All-In-One Thermal Printer
    Scholar:
  • 155 Answers
No,
to disable you need to remove the conductor for the scanner assembl which you can locate after you open the cover.
but it is highly unrecommended
Posted on Jul 02, 2009
HOW I WANT TO DISABLE ENTER AFTER I SCAN BARCODE..... I USE SCANNER MODEL GRYPHON GD4400
Just download print the GRYPHON quick reference guide (print on laser printer without zooming) and program the scanner to factory default.
Otherwise, you will need to download the FULL reference manual. Then print out the relevant programming barcodes that will remove the last character.
Dec 14, 2013 | Datalogic Gryphon Computers & Internet
Hp envy of unlock passeord
Which operating system ???
CMOS (Complementary metal oxide semiconductor) refers to the battery-powered, semi-conductor chip located on an HP computer's motherboard.
It is where the BIOS stores important information regarding the PC's system configuration. CMOS is required for an HP laptop and its hardware to run stably.
Sometimes, however, it is necessary to clear CMOS, such as if you lose your BIOS password or your BIOS is corrupted.
Clearing CMOS on HP laptops varies depending upon the model, but for a lot of laptops, the process simply requires removing the battery for a short period of time.
Power down your HP laptop. Remove the AC adapter and any other peripheral devices. Turn over the computer so that the bottom side is facing up.
Ground yourself, either by touching a piece of unpainted metal or by wearing an anti-static wrist-strap.
Locate the battery. This will vary depending on your laptop's model, but it is usually located on the back, near the rear of the laptop.
Review your laptop's documentation to find the battery, if needed.
Many newer models require that you remove the battery by releasing or holding down one or two latches, then gently pulling the battery out.
Some models may instead require that you unscrew the battery from its compartment.
Leave the battery out of the compartment for at least 30 minutes.
Do not attempt to turn on the computer and do not touch the battery within that time.
Some HP laptops may require you leave out the battery longer to clear CMOS, others might take only 10 to 15 minutes to reset.
Ground yourself, then put the battery back into the HP laptop.
Snap the battery latch into place or screw the cover back on, if necessary.
Removing a Bios - CMOS Password
http://www.dewassoc.com/support/bios/bios_password.htm
Disable Fingerprint on an HP Laptop
Many HP laptops include a fingerprint scanner to enhance the security of your computer.
When the fingerprint scanner is enabled, the computer requires a fingerprint scan to log onto Windows.
Disable the fingerprint scanner if you do not need or want this feature.
With the fingerprint scanner disabled, you can log on to Windows using a password.
You can enable the fingerprint scanner anytime you need to.
Access the Device Manager on your computer.
Select "Control Panel" from your computer's Start menu.
Click "Hardware and Sound" and then click "Device Manager."
Find "Personal identification devices" in the "Device Manager" list.
Click the "+" sign next to "Personal identification devices."
This opens a list of all of your devices.
Click on "Validity Sensor."
Select the "Driver" tab at the top of the properties window and click "Disable" to disable your fingerprint scanner.
The button changes to "Enable" and you can enable the fingerprint scanner at any time.
Click "OK" to exit out of the window.
Jun 27, 2013 | Computers & Internet
840,01 scanner disable error. how to solve it
This message indicates that the scanner has been disabled cannot be used. The MFP must be powered off and then press and hold the check and the right button and turn on the printer to access the configuration menu
1. In the configuration menu, use the arrow keys to scroll to the Disable Scanner menu item.
2. Press check button.
3. Use the arrow key to scroll to the desired setting. The options are Enable ADF/FB, Disable ADF/FB, Disable ADF only, Auto Disabled. (Please select Enable ADF/FB)
4. Press check button.
5. Press BACK button.
6. Scroll to Exit Config Menu.
7. Press check button. The device restarts.
8. Try running a copy from the ADF and flatbed.
For further assistance, please contact Lexmark Technical Support.
Jul 30, 2011 | Lexmark X364dn All-In-One Laser Printer
ScanAllPro starts, chose the scanner shows the error: scanner is not connected or another application is using it. but no application is used at this moment. and the test with document scanning by...
Hi,Make sure that the driver selected on the [Scan] tab of [Preferences] in the [Tool] menu is installed correctly.Specify which driver is used for the scanner, the TWAIN or ISIS/VRS driver. When a scanner is no longer connected to a USB port to which it was previously connected, this option checks if any scanner of the same model has been connected to the other USB port. If the same model is found there, this option automatically switches to the other port and inherits the settings of the same model.
* This option will not be available, however, if a different model has been connected to the port where the scanner was previously connected. * Disable the settings when you want to connect more than one scanner of the same model to your computer.
Hope the above information is helpful.
Thanks,
ScanCare
Jun 24, 2011 | Fujitsu fi-5120C
Error A000000B enabling scanner. Scanner support has been disable
Looks like laser head does not work and cannot be recognizied by scanner.
Sep 10, 2009 | Zebra Symbol Technologies MC909X-G Series...
Symbol MC9090 scanner disabled
You may need to reflash the OS. you can normally download it from symbol webpage. you will need a cradle and an SD card.
Mar 25, 2009 | Zebra Symbol Technologies MC909X-G Series...
Macafee button stays black saying virus scan diabled but when I run check manualy itsays all systems up to date.Whats wrong?
Its possible the resident scanner is disabled. Right click the scanner icon or check program preferences and locate the option to enable the resident scanner. It is also possible you have malware which is disabling the scanner. No single virus scanner can find all infections.
Run another known good scanner to rule out infections.
Mar 15, 2009 | Computers & Internet
Scanner failure, while booting up, blocks all other functions.
no you can not disable your scanner
you ust have to repair your scanner
if you have any warranty then go for it
or visit any technical person who can check cables and scanning tube of your scanner
Nov 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110xi All-In-One Thermal Printer Logo
47 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
