Gasket in top between the top resivour and the bottom holding tank leaks
SOURCE: No manual with Bunn NHBX coffee maker.
Leave the unit unplugged and add a carafe of water to the top reservoir.
Close the lid.
Wait a bit to make sure the water has drained into the tank.
Add another carafe of water to the top reservoir.
Place carafe on warmer plate.
Close the lid.
When water stops going into the carafe, you may plug the machine in and make sure the "travel switch" is in the ON position. ON = |, OFF = O.
Wait at least 15 minutes for the water in the tank to heat up, and brew as you normally would for other BUNN coffee makers.
SOURCE: I have a bunn coffee maker the NHBX is the # it is
Please give Customer Service a call with the model and date code. If the machine is 3 years old or less, it will be replaced with a new machine. If it is older than 3 years, it can be exchanged for a reduced price.
If you will locate the date code on the bottom of the unit and then call Customer Service, the machine will be replaced at no cost or if over 3 years old, at a reduced price.
SOURCE: my bunn coffee maker is leaking water out of the
Please get the model and code date located on the bottom of the brewer. The machine has a 3 year warranty and if it is 3 years old or less, it will be replaced at no cost. If it is older than 3 years old, it will be replaced at a discounted price. Once you have this information please call customer service.
