Question about Toto Aquia II Dual Flush Toilet
Looking to buy/install Toto Aquia II in my circa 1964 co-op apt.
Upcoming bathroom reno. Older bldg. Steep learning curve here.
Want to buy a Toto Aquia II. However, on ckg blogs I see there may be problems. My existing toilet is approx. 10.5" fm wall. Taps are 5" fm floor which is tile and probably lots of concrete underneath. (I'm on the top floor). From what I've read it seems that the Toto II may not fit. Also, installation (by a plumber) may be costly & take quite a bit of time.
Any comments/suggestions, please.
Susan
  • musicalfootp Jul 27, 2009
    Yes , it does appear to be 10.5 to the centre of the drain. Thanks for the feedback.
  • 62 Answers
When you say 10.5 inches from wall, do you mean that from the center of the drain in the floor to the back wall is 10.5 inches? If so, you need a toilet for a "10 inch rough-in" dimension. The Aquia doesn't come in that dimension. Sorry!
Caroma Sydney Smart model 270 comes in a 10 inch rough-in and is a dual flush model. Note that all dual flush toilets are fairly expensive as compared to normal toilets. HOWEVER, genrally speaking, ALL 10 inch rough-in toilets are fairly expensive just because the low volume that are sold.
Posted on Jul 11, 2009
Flush Valve leaking
replace the whole valve. It's cheap and easy to do. Probably you can install a universal valve. Look on e-bay or amozon
Dec 05, 2012 | Toto Aquia II Dual Flush Toilet
The rubber flap came off of the chain and is ripped
Install a new one it is not possible to repair the flapper when it is torn.
This link shows what is out there you don't have to buy it from them.
http://www.plumbingsupply.com/flappers.html
Feb 03, 2011 | Toto Aquia II Dual Flush Toilet
Aquia II Dual Flush Toilet: toilet after flush removes to much water from bowl...
Adjust the float on the Fluid-master a little higher if possible. This should allow more water to enter the bowl after the flush.
May 16, 2010 | Toto Aquia II Dual Flush Toilet
REMOVAL OF TOTO AQUIA TOILET
first shut off water and then flush the john. this will remove most of the water. for water remaining in tank us a sponge or similar to remove remaining water. find where toilet bolts to floor and remove these bolts or nuts. then pick whole toilet from floor, there should be a wax ring under toilet, replace wax ring when putting back in. when putting back in just push down on toilet to squish wax ring and bolt to floor, turn on water and check for leaks. good luck
Apr 16, 2010 | Toto Aquia II Dual Flush Toilet
I purchased a Toto Aquia II Dual Flush Toilet, around a year ago. No problems until now. The toilet won't flush. It doesn't appear to be running at all.
If this is one of those models that most people have, the valve that shuts the incoming water off when the tank is filled is probably bad. It only costs about 8-10 dollars to replace. This valve is actually a stem or tree shaped device.
Jan 14, 2009 | Toto Aquia II Dual Flush Toilet
FAMILIAR WITH TOTO AQUIA TOILETS AT ALL?
Everything you need to know about Toto! Hope it helps!
http://www.totousa.com/Default.aspx?tabid=215#
Jan 12, 2009 | Toto Aquia II Dual Flush Toilet
Toto Aquia II Dual Flush Toilet Logo
343 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
