Question about Sony Televison & Video
Colors are off and the picture is concaved. Tried to flash focus with no change. Picture is narrower in the middle and the colors are seperated.
    President:
  • 788 Answers
Your symptoms sounds like a damaged convergence IC’s.
There are two and sometimes three very large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink.
Most of the time you can just correct the convergence through the television menu. All that needs to be done is line up the blue and red to the green. If the colors do not move then there may be faulty components in the convergence circuit.
You may want to consult a Television Repair Technician, or repair this yourself. If you want to tackle this yourself, let me know, I can give you some direction for the repair
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on Jul 02, 2009
The picture on our Sony TV Model KP-43HT20 recently became distorted, concaving at top and bottom. If I use reset the Flash Focus, the picture will return to full screen side for awhile but the colors do...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergene board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 15, 2011 | Sony KP-43HT20 43" Rear Projection...
The picture shows all 3 colors seperate from each
Sounds like a problem in your convergence circuit. This is the circuit responsible for making sure all 3 colors align perfectly so that you don't see what you are seeing now. If you have tried adjusting it and that did not work then you will need to have the convergence circuit repaired.
May 24, 2010 | RCA R52WM24 52" HDTV Projection Television
The picture and colors went out of focus.
Blowed Fuse there is 3 of them on the right hand side of the FBT flyback Transfomer they Look like small brown rectrangler caps But are Fuses .06amps
it will be the one in the Middle FL231
PartStore.com has them 1-866-925-7278
May 01, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Flash Focus does not focus the TV colors are seperated
if that doesn't work it will need new convergence IC's put in as well as a resistor or two
electech
Oct 29, 2008 | Sony KP-43T90 43" Rear Projection...
Mitsubishi projection tv
I have a similar problem. I have tried to fix the convergence via the remote and that has not helped. My three colors are separated and the edge of the picture is bent in toward the center. I am going to try a hard reset but i suspect the convergence IC are fried. Since the set is not HD, I will probably replace it if the hard reset does not work.
Nov 22, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
83 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
