SOURCE: VW Touareg V6 2005 - Battery seems dead, nothing works
under the hood is a positive post and a neg post to jump start ur ride.
SOURCE: reset check and service engine lights
It's in the console under the coin holder, in front of the gear shifter. You have to remove the coin holder and you will see it.
SOURCE: 2005 cayenne, 3.2, service reset light
resetting service now light after oil change on 2005 Porsche Cayenne
SOURCE: "SRS-AIRBAG SERVICE" fault message
Here's a quick check list
for most common cost of SRS / Air bag problem.
Dirty contacts on driver
and passenger seat belt buckles
Dirty contacts on seat belt connectors
(under seats)
Dirty contacts on driver and passenger sides weight
sensors (under seat)
Seat covers
Weight on passenger seat
(Example:
grocery package trigger SRS / Air Bag light on the way home.)
I
recommend you to pass an vacuum over the contacts and use CRC
electronic parts cleaner to rule out connectivity problem.
I DO NOT
recommend disconnecting the negative battery connector to clean the code(s).
Without the code(s) the dealer will takes "BILLABLE" time to reproduce
the problem.
Please rate my answer if it is useful to you.
Cheers,
Mustgo
SOURCE: How do I reset the SRS-Airbag SERVICE URGENT Fault
(under seats)
Seat covers
(Example:
I
I DO NOT
the problem.
Cheers,
Mustgo
