Question about Xerox Office Equipment & Supplies
Poor copy quality
I just replaced the toner cartridge and the copy is too dark.
I have adjusted the "toner saver and "copy contast" settings.
I recently repaced the drum and have inspected it. The drum doesn't look damaged.
The copies are darker on the right side of the sheet.
Before I replaced the toner the copies had a gray tone in general.
Do I need a new copier or is there a setting or cleaning method I am missing?
I need help!!
Thanks!
    Scholar:
  • 175 Answers
The drum, developer and other parts have a certain life that they are good for. After they go beyond that cycle they can start to run dirty, use alot more toner, basically give you problems until a complete maintenance is done. The drum can have permanent light fatigue, even though they look good and in alot of cases one side will start to get darker than the other. You should get an estimate of what it'll cost to have servicing done and compare that with the cost of a new or refurbed machine. If the copier is very old, it might be worth it to get a new one. Good luck, please rate this if it helped you. Thanks
Posted on Jul 03, 2009
How do I prevent excess toner from spilling out of cartridge and affecting copies?
If you 'replaced' or refitted the original cartridge, then I would suggest that the toner cartridge has failed. If this is the case, please try a new one.
If the original has not done a fair (check manufacturers specification) number of prints, you may be able to ask for a replacement.
If this was a new cartridge, and printer uses separate drums and toner cartridges. Then it could be a faulty drum. Above replacement path could be tried.
Aug 01, 2015 | Sharp AL-1631 Laser Toner Cartridges
Our copier is copying in light shade. how to make it darker
To adjust the default lighter/darker setting
1. On the LaserJet 3015, press MENU/ENTER.
2. Use the < or the > button to select Copy setup, and then press MENU/ENTER.
3. Use the < or the > button to select Def. Light/Dark, and then press MENU/ENTER.
4. Use the < or the > button to adjust the setting. Move the slider to the left to make all of the
copies lighter than the original, or move the slider to the right to make all of the copies
darker than the original.
5. Press MENU/ENTER to save the selection.
Page 48 of the User Guide has instructions for adjusting the light/dark setting during a copy job.
Also see the Troubleshooting section of the User Guide for other possible reasons for light/faded copies.
If your copies continue to come out too light, you may need to clean the insert a new toner cartridge or change brands of toner. I tried several "generic" toner cartridges and refills, but my prints and copies were always faded or streaky. After going back to genuine HP cartridges, I haven't had any print quality problems.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
Fax quality poor when recieving fax from samsung scx 4521F
Good Day Sir, Hope my suggested solution will resolve your problem.
Condition: The incoming fax has a blank spaces or is of poor-quality.
Solution:
  • The fax machine sending you the fax may be faulty.
  • A noise phone line can cause line errors.
  • Check your machine by making a copy.
  • The toner cartridge, referring to "Replacing the Toner Cartridge".
Redistributing the Toner
  1. Open the Front door.
  2. Pull the toner cartridge out and remove it from the printer.
  3. Gently shake the toner cartridge from side to side five or six times to redistribute the toner.
Have a nice day and God bless.
Oct 09, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Printed pages look terrible...
I'm more familiar with HP printers, but it sounds like a fuser is bad. The fuser effects print quality as well. If you've replaced the toner, as you have.
Apr 24, 2009 | Sharp FO 5550 Plain Paper Laser Fax
Bad photo quality after changing drum
your laser printer
1) print color quality is now distorted that means print skew (technician called)
2) print tint means the print color not enough density,
3) print mottle means print dirty
you may try
1) print distorted--- find out the skew adjustment from your printer manu, it is adjust the image before transfer to the drum.
2) print skew could be happened when the drum replace install not very accurate, so install it more carefully.
3) print tint---you may increase print density from the manu, not fix,
4) print tint---the toner caridge near life cycle or using the less compatible toner. so you have change the quality toner or cartridge (if near life cycle) to improve quality photo print
5)print mottle---toner quality ? or cartridge near life cycle also cause print dirty paper,
Feb 08, 2009 | Konica Minolta magicolor 2300DL Laser...
Poor quality copies
Hi, this is most likely caused by a worn or faulty drum.
Jan 20, 2009 | Sharp AL 1631 Copier
Poor print quality
you need to replace the Drum otherwise known as the photoconductor I believe the part number is 75P5712 - your toner cartridge actually seats into the PC kit.
Dec 12, 2008 | IBM Infoprint 1412 Laser Printer
Poor quality of copies
If it is a real genuine Brother toner. Not a reman. You may also need to change the drum. If you have a user manual, it will show you where the drum life setting is in the menu structure. Make sure the little glass window inside on the right is clean so it can read the toner level. Make sure the toner save feature is turned off.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 14, 2008 | Brother IntelliFAX 4100 Laser Fax
Faded print quality
If your toner saver is off and still getting faded quality means you mirrors and Scanning Lamp are not reflecting images properly.
Now if you are handy on printer then you need to take off glass
bb15714.jpg from printer then you need to clean ADF units (mirrors,lense lamp etc)
0a45468.jpg but if you unaware of printer repairing, i highly recommend to call a printer tech who ca fix back it quick.
sometime printer acts weired due to this problem while printer or make copies.
Good luck
and rate all answers.
Jun 29, 2008 | Brother HL-2040 Laser Printer
Poor quality fax to fax, copy great, computor fax great.
beware of generic toner!
you may need to change out your drum unit
the drum unit may have been contaminated by the staples toner.
also clean laser window under drum cartridge.
Mar 17, 2008 | Brother IntelliFAX 2800 Laser Fax
107 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
