Question about RCA L32WD26D HDTV/DVD Combo
My RCA L32WD26D turns on and off, over and over.
When I turn my RCA L32WD26D on, the power light changes from red to green to red to green over and over, the screen lights up for a moment, then it powers off, and then turns on again and repeats the process again over and over. Prior to this, it was making a clicking noise. Please assist!
Shuttle83
  • 1139 Answers
SOURCE: RCA tv Making a clicking noise
This is a power supply problem it may be as simple as a blown fuse or as complex as a malfunctioning IHVT (Integrated High Voltage Transformer). Is it worth fixing, only you can answer that I would estimate the cost from $100.00 - $500.00 at least.
Posted on Oct 03, 2007
SOURCE: Rca Big screen shut down and now no power
NO audio and no picture .... no power to on - off button. Checked outlet and it is good .... cable connection good - checked with another tv....
Posted on May 15, 2008
SOURCE: RCA D32F750T won't turn on
Well, I glad to know that fixing this set is unfruitful.
Yes, I am yet another unsatisfied customer with the same complaints.
Ha, my TV made some kind of weird noise and I saw a flash behind the set.
After pulling a back panel, because it only comes with a 1 year warrantee,
I saw the burned part.
Posted on Oct 17, 2008
ladywinn
  • 5138 Answers
SOURCE: 52 inch rca big screen tv will not come on
ck capacitor cp150 if it is bad replace 2 other caps in same circuit 2200uf 16v -220uf35v cp111 cp114?
Posted on Dec 09, 2008
  • 33 Answers
SOURCE: My rca L26WD26D does not power on - using the
The most common failures with LCD/ DVD combos is a failure in the DVD transport mechanism. The DVD transport mechanism is an easily replaced subassembly, that can be purchased for less than $200 in most cases. The best bet is t replace this mechanism ensuring that you purchase it from a vendor who will purchase it back if it dos not fix the problem for some reason.
In the event that the DVD player replacement does not solve the problem, the second most common problem is LCD's is the power supply module. Assuming that you do not want to have a shop repair this unit, search for a power supply module online and replace it yourself, ensuring you can return it if it doesn't resolve the problem.
There are other things that cause that symptom on LCD tvs that are beyond the scope of this discussion.
Posted on Apr 29, 2009
RCA L32WD26D TV/DVD/HD Combo - dvd wont eject
Hello
Check the loading motor and loading belt. If loading motor has damaged, or loding belt has broken or loose. the in-out tray mechanism won't work well.
Mar 03, 2012 | RCA L32WD26D HDTV/DVD Combo
My RCA 42 " LCD Is crazed. i USE THE REMOTE TO TURN IT OFF AND ABOUT A MINUTE OR 2 LATER IT AUTOMATCALLY TURNS ITSELF BACK ON. THE ONLY WAY I CAN KEEP IT OFF IS TO UNPLUG FROM POWER SOURCE. IS THERE A...
Check the sleeper timer is not on like 30,60,120 Mins.Turn the sleeper function off,should work.Not,go in ur tv menu,go to PICTURE,go down to reset the tv Tuner board,the setting will go back to the factory setting.
Jun 18, 2010 | RCA L32WD26D HDTV/DVD Combo
Havin problem with a1200 class a/b amp it ligts green and red at same time after hooking in remote how doi fixdo i need diagram to fix
Make sure you don't have any shorts on your speaker wires or rca cables. Unplug one at a time, the turn on power until it stays green with no protect light, then you know what input is causing the short. If you remove all speaker wires and rca wires and all you have connected is the ground, power(12volts) and remote and it still lights up red/green(in protect mode) then your problem is the amp.
Mar 09, 2010 | Car Audio & Video
37"RCA Lcd TV quit working
no parts available google model for part # for main pcb
Jun 08, 2009 | RCA L37WD12 37 in. LCD HDTV
Regional code error 4 RCA L32WD26D
It's possible your son may have by accident entered into the service mode for technicans. At this point, I think you would have to call the RCA for help on this one. Good Luck
Jan 24, 2009 | RCA L32WD26D HDTV/DVD Combo
RCA L32WD26D HDTV/DVD Combo Logo
199 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
