Question about LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher
Dishwasher not washing or dissolving soap
I have an LG stainless steel dishwasher, 3 years old. # months ago it stopped washing altogether, any type of soap (liquid, tablets, powder, gel) just ends up at the bottom and does not dissolve. The dishes end up as dirty as they went in. I have taken everything removable out to check for clogs and can't find anything. Any ideas? This one doesn't have any display for error codes.
  • Jeff Meyer May 11, 2010
    If you own an LG dishwasher, model 7811, you would get an error display (2 letters) on the timer display. Are you saying you are not getting an error message? When you say you have removed things under the lower spray arm, does that include the screws and the filter assembly?
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
Do your dishes look cloudy or spotty? If so it is not soap but rather hard water residue. Go to www.dishwasherfilter.com and get a filter that filters the water before it enters your dishwasher. it is very affordable(like 70 bucks) and guaranteed to work or you can return it for a full refund. I bet this will solve the problem.
Posted on Jul 26, 2009
  • 10,865 Answers
Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Posted on Jul 02, 2009
Sorry was not very clear on first post. My indesit dishwasher smells really bad. I have cleaned it with dishwasher cleaner and washed filter.It does seem to be working as normal.
If you run a quart or two of white vinegar through the long part of
a wash cycle it will help dissolve some of the buildup that holds onto
odors. After this place
Amco Rub Away Bar
or any other brand of stainless steel hollow bar of "soap"into either a rack where it will not fall through or in the utensilrack. The water reacts with the stainless steel enabling it tobreak apart molecules that are creating an odor. This has worked very successfully for us for many years now.Frank in NC
Aug 17, 2013 | Indesit Dishwashers
Kenmore Elite dishwasher will not dissolve soap or wash well.
Temperature should be 140F. and the units heater should energize during fill to achieve this.
May 19, 2010 | Kenmore 24 in. 15173 Stainless Steel...
Detergent packs will not dissolve
check the water temperature, run hot water at the adjacent sink before pushing start on the dishwaher, or switch to powder, is your detergent door opening ? do not block the detergent door with long objects like spatulas etc.
Aug 27, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwasher only a couple of months old. Ran it
The water may not be hot enough. Increase the temperature of the incoming hot water or try this: put the tab in the open soap cup so it will start to dissolve during the pre-wash. Then it will finish dissolving during the main wash. If the dishes get clean using this method you may not have to increase the water temp.
Aug 25, 2009 | Dishwashers
Dishwasher
2 things will lead to soap not dissolving, first is cold water, so make sure you have hot enough water. second and more likely is the dispenser is not opening at the proper time , instead fully opens at end of cycle during the dry cycle never even getting wet, and washing dishes with no soap, id replace the dispenser or make sure your not stacking items in front of dispenser hindering the opening. also powder is best, tabs and gelpack put undo stress on the dispenser door not always allowing full operation...
Nov 06, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
LG LDS 5811 Dishwasher has white film everywhere.
You may have a water issue.  Be sure that the water line is connected to the hot water pipes, not cold water.  If your dishwasher is connected to the cold water, the soap residue will occur because it cannot dissolve in cold water properly.
Is your water very hard??  If so, you may need to get a water softener to remove the hard scales.
Jul 07, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher Logo
655 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
