Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Just looking to see if worth repalce roller or
Just looking to see if worth repalce roller not the brush the actual rollers or buying a new vaccuum
  • 75 Answers
Just look to see if you can get the rollers replaced.
Posted on Jul 02, 2009
Belt
Look underneath where the brush roller is located. The brush roller is removed to replace the belt. The new belt is installed on the motor shaft and the brush roller then the brush roller is reinstalled
Jul 27, 2013 | Eureka Whirlwind 4481 Upright Vacuum
HV9010P ROLLER BRUSH DOESN'T MOVE
That is probably the belt. Open up the bottom screws and take a look. The cat or dog hair usually gets stuck in the ends of the rollers and stops the belt from effectively pushing the roller. You may find that the belt is still on the drive and the roller. If you do just clean out the roller.
Jan 22, 2013 | Black & Decker AV1200 DustBuster Handheld...
I have a lift-off bissell vaccuum and as I vacuum often the power brush will turn off and on. How can I fix this?
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuum's belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jul 16, 2011 | Bissell 37604 Lift-Off Pet Bagless Upright...
No power to brushes no result when brush switch activated
If you hear the brush moter running then the belt driving the roller has probably broken. It can be easily replaced by removing the brush plate underneath and pulling the roller out. Replacement belts are available on-line or may be available in hardware stores.Fit the new belt over the steel motor spindle first, then place the belt over the roller and insert the roller.
The belt will break if the roller gets jammed, so buy 2 belts and keep one as a spare.
Mar 07, 2011 | Bissell 3750 Lift Off Bagless Upright...
I bought a dyson DC14 hepa with no brush bar can i use it on wooden floors
Actually yes you can. The hard floor setting is the same as the carpet setting only it doesn't spin the brush roller. Running the vacuum without the roller will have roughly the same effect.
If you want to buy and install a roller I have made a video to show you how to fit one in your DC07.
Click here to go to my DC07 webpage. There is a link on that page called
How do I check the clutch or brush roller of my Dyson DC07?. (video)
that is the one to choose to see how you could install a new roller.
If you want to purchase a roller online check out vacuumspot or Nelson Vacuums.
Finally if this was a helpful answer please take a moment to give it a rating (a really good one pls)
Jan 07, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
Just purchased this Dyson dc24 today. brush doesn't spin after gettin tangled in a cord. removed the cord from the brush OK. I have several times: removed the brush and replaced it OK. pushed the red...
When you removed the brush roller dod you examine the end of the actual roller that is opposite from the removal opening. There is a gear that the roller fits over that may have gotten stripped when it became tangled. Check that the gear has not rounded off and look inside the roller bar to see if the area where the gear fits into may have gotten stripped as well. You might try to operate the vacuum without the roller brush installed for a few seconds just to see if the gear turns. When I say gear, it is actually a somall "post" about 1-2" long that the roller brush fits over. Hope this helps!
Dec 17, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Belt tensioner overheated and doesn't keep belt tight enough
Looking at the owner manual, there is no tensioner assembly.
If the motor is fixed in place and not loose, then you either have the wrong belt, or the brush roller is not properly installed, or the brush roller is worn out where the belt goes around the brush roller.
Dec 16, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Brush won't spin on my Hoover Mach 5
I love this vacuum but had the same problem.
SOLUTION:
take the roller off and flip the thin belt inside out. This fixed my vac and works great again.
Oct 12, 2008 | Hoover U5194-900 Mach5 Multi-Chamber...
Roller will not spin
Thank you a friend helped me find the problem. It was actually very simple!
Aug 28, 2008 | Riccar 8850 Vacuum
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
47 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
