Question about Garden
Pentair whisperflo 3/4 hp left running over an hour with no water
I was cleaning the pool and was called away and turned off the water to my pentair pump. I came back 1 to 1.5 hours later with the pump still running and hot. I does run but will not pull water from the pool. I have a valve between the pump and the filter that shows some sign of pressure when I open it when the pump is running. Does anyone know the answer to my problem.
Thanks.
  • 4 Answers
The threaded fitting on the suction side has melted and is letting air in. You'll first have to replumb that to find if there's any other damage. It's possible that's all that's wrong.
Posted on Sep 12, 2009
  • 10,865 Answers
Sorry to have to tell you but you are going to have to either have your pump rebuilt or replaced. Sounds like you baked the plastic impeller and maybe did even more damage. These pumps require water in order to keep cool.
Posted on Jul 02, 2009
Pentair Intelliflo vs. Need bearing replacement for front and back bearings
Pentair WhisperFlo Pool Pump Motor Bearings Replaced ...
? 2:03
www.youtube.com/watch?v=qYRNMCh_7kM
Jul 10, 2012 - Uploaded by Pump Repair Supply
More Help & Information: https://pumprepairsupply.com Watch as Joseph shows you how quite your Pentair
Sep 27, 2015 | Pool & Spa
Pentair chlorinator tablets not dissolving. Also the dispenser tube loses water level when pump is down.
make sure water is running into unit take off top see if water rises run about 3.5 let water rise then close top
Aug 08, 2013 | Pentair 2.0 Hp Whisperflo Pump
When I turn on my pool filter with a Pentair WhisperFlo 2 hp pump, the psi has jumped from 18 to 30. There's nothing visible in the baskets in the skimmers or in the WhisperFlo. Where could the resistance...
If your pressure has gone up, the problem will be on the discharge side of the pump. First, make sure that your gauge is not malfunctioning.
Next see if all valves after the pump are set properly and that the three way valves or backwash valve are not broken inside.
Is this helpful?
Gary
Feb 28, 2011 | Pentair 2 hp WhisperFlo InGround Pool Pump...
How do you replace an impeller on a 1.0 hp Pentair Whisperflo pool motor
Remove the bolts that hold the 'wet end' of the pump to the 'dry end'. If the impeller is held on with a screw, it is a 'left-hand' tighten which means it turns the opposite way of normal screws. Be careful not to damage the impeller. Any scoring on it will effect its performance and it will only be worth doing if everything goes back together cleanly and properly. Replace and lube all O-rings with silicone lube. Make sure all bolts are tightened and do them in an alternating fashion to ensure that you get a good seal.
www.cpo2go.com
May 28, 2010 | Pentair 1.0 Hp Whisperflo Pump
My 3 year old pool pump whisperflo is running a louder. What do I need to check?
Loud operation is an indication that the bearings need replacing. A local small motor repair shop can probably get it done for $70 or less. Call around...
Apr 18, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
Pool pump won't prime
check for air leaks, cover o-ring is common culprit. anything in front of pump can cause this.
Jan 17, 2009 | Pentair 1.0 Hp Whisperflo Pump
Garden Logo
236 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
