Question about Health-O-Meter Health & Beauty
According to my Health-O-Meter Everweigh scale RO399, I weigh 4.5 pounds. Can I reset somehow?
fitnessbalan
  • 59 Answers
SOURCE: somehow my tanita ultimate scale has been switched
Q: Why does "st-lb" or "kg" appear when taking a measurement?
A: The unit's "Weight Mode" has been set to measure your weight in units of stone-pounds (st-lb) or kilograms (kg). Tanita's Body Fat Monitors and the UltimateScales can measure weight in three different modes: lb (pounds), kg (kilograms) or st-lb (British stone-pounds). To change the setting, first find out which model you have (it should be written just above or below the display screen of the unit).
Method 1
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Method 2
Body Fat Monitor/Scales: BF-542, TBF-551, TBF-521, TBF-531, BF-681, BF-682, BF-679, BF-680, BF-578, all Ironman products, and all InnerScan products.
Select the preferred weight mode by using switch on the back of the measuring platform.
Posted on Mar 16, 2009
SOURCE: resetting the scale
You do not reset the scale. It only saves the last recorded weight of the user. So, if you weighed yesterday, it will put your recorded weight in memory. The next time you select your user number and step on the scale, it will compute the difference from your previous record and save your current weight.
Posted on Mar 25, 2009
SOURCE: unable to reset health o meter scale BFM676 need instruction man
I just got a BFM676 without instructions. I looked on Health O meter's home page. I then looked through various instruction manuals. One of them worked.
To adjust profiles. Turn on by pressing scroll. Choose profile number you want to edit with the scroll button. Hold down the Select button until the first height number starts flashing. Use the scroll button to change the numbers. Use the select button to change to the next field. Have fun. =)
Posted on Jun 12, 2009
SOURCE: Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Posted on Jun 24, 2009
SOURCE: What does the Bone Mass number mean on my digital scale?
I found this from another posting. Hope it helps.
FEMALES: age 20-29 normal= 6.2-7%
FEMALES: age 30-39 normal= 6-6.8%
FEMALES: age 40-49 normal= 5.6-6.4%
FEMALES: age 50-59 normal= 5.2-6%
FEMALES: age 60-69 normal= 4.9-5.7%
sorry no listings over age 69
My only thing now, is what it means if I am below the range.
Posted on Jan 13, 2010
Salter high precision stainless scale 1078ss. How do i get it to weigh ounces
Put the weight on the scale. It should weigh ounces, pounds, grams, and killograms, all in the same unit.
May 12, 2017 | Salter Health & Beauty
UP TO HOW MANY POUNDS CAN BE MEASURE IN THIS SCALE
I don't know specifically for this model, but for most like this, 300 or 330lbs is typical. To test a working scale for its max capacity, let a heavier friend try it or carefully hold a weight in each hand and stand very still when its a digital scale. A gallon plastic milk container weighs about 9lbs, so one in each hand,even if filled with water will give you an extra 18 lbs of testing room. You can also let the heavier friend or other person hold the weights to help you test the upper limits.
Jun 07, 2013 | Health-O-Meter Health o Meter BFM681DQ-63...
How do I reset my Weight Watchers Scale WW67T? It doesn't matter who gets on, we all weigh 150.1 pounds. How can I reset this? I put in a new battery also. Thanks
Wexem,,,, thank you. Your instructions worked like a charm. Sad that the manual doesn't mention or contain reset instructions.
Feb 04, 2012 | Health & Beauty
I can't reset the start weight. I have hit the reset button and also have taken out the batteries but it always has the same weight in it. Please explain what to do.
With the unit off, press and hold the 'select' button and then also press and hold the number of the person you wish to reset ( 1, 2, 3, or 4) The screen will ask you if you want to reset, use the select button to say yes, it will then ask if you want to enter a new goal. Again, use the select button and the up and down buttons to enter the new goal weight.
Jun 27, 2010 | Health-O-Meter Health o Meter HDM776KD-95...
Scale is stuck on setting for weighing in kgs and cm's
There is no black button on the bottom or anywhere on the model mbf681dq-63
Apr 04, 2010 | Health-O-Meter Health o Meter BFM681DQ-63...
Scale is not weighing correctly. Weighs correct
The scale must be on a hard, level surface. Make sure there is absolutely no dirt on any of the pivot points. Calibrate it with a KNOWN 25 pound weight.
Jan 04, 2010 | Health-O-Meter Health o meter 402KLWH...
Err 4
Sounds like it wasn't initialized, even though it says Er 4 instead of Er 0... According to my manual, to (re)initialize it and reset it to zero, tap the platform lightly. It should show zeroes running across the display for a second or two, then show all zeroes and turn off. It should be re-initialized...
Error Codes for the 5757 (according to my manual):
Er 0 Initialization error (remedy described above)
Er 1 Instability error (step off the scale, then back on)
Er 2 Overload warning (registering weight beyond the 440 pound max)
Er 3 Contact error (body impedance beyond technical limit - try dampening feet and try again for better contact)
Er 4 Bodyfat error (bodyfat percentage is beyond range - try dampening feet and try again for better contact)
Er 5 Bodywater error (bodywater percentage is beyond range - try dampening feet and try again for better contact)
Jul 02, 2009 | Taylor 5757 Digital Glass Body Fat Scale
Unable to pop battery compartnent in Health o meter EVERweigh
The whole top cover which is the part that you stand on (loading platform) comes off. Turn the scales upside down, pull the sides of the plastic cover to unclip the catches and the body can be removed from the cover. Remove the screws to the displlay and there will be a battery compartment underneath the display. Remove the cover to the battery compartment and make note of the battery orientation. Replace the battery in the correct orientation or you will destroy the scales. Repace the battery cover. Scew the display to the body. Press the cover on the body with the display showing through the window.
Jun 05, 2009 | Sunbeam Health O Meter Body Monitoring...
Health & Beauty Logo
344 people viewed this question
Top Health-O-Meter Health & Beauty Experts
creative_lac
Level 1 Expert
His Example
Level 1 Expert
TheHCGInstitute
TheHCGInstitute
Are you a Health-O-Meter Health and Beauty Expert? Answer questions, earn points and help others
