Question about Pacific Image Powerslide 3650
Th slides I scan are all slightly out of focus - they look fuzzy, but the original imges are sharp and clear
    Brigadier General:
  • 3,917 Answers
Scanning of a natural picture handled by an image processing system always causes a loss of information, i.e., the micro picture elements become uncertain and vague. This is essential when the picture is to be used for measuring or evaluation of structural parameters. To make the induced uncertainty and vagueness transparent up to the computed results, specifications and procedures from fuzzy set theory are presented and suggested. In particular, distances of pixels are considered. For a demonstration of how this uncertainty can influence conclusions from the given picture, the computation of the approximate gradient of a curve is considered.
Reasons to change the automatically determined resolution
It is desirable to change the resolution if the destination of the scanned image is an image file or if it is intended for use on the World Wide Web.
When scanning to a file, unlike scanning to a destination program such as Adobe (R) PhotoDeluxe (TM), the intended use for the scan is not necessarily determined. It may be necessary to change the resolution to achieve the desired results. For example:
If selecting Image File or Image and Text File as the destination, and the resulting image is for on-screen use (for example, in a World Wide Web page), change the resolution to 72 to 75 dots-per-inch (dpi). (Resolutions higher than 75 dpi do not improve the appearance of an image displayed on a computer monitor and require longer download times.)
If selecting Image File or Image and Text File as the destination, and the image file is being sent to a printer with a resolution of 1200 dpi or higher, change the resolution to 300 dpi. (Resolutions above 300 dpi rarely improve image quality, even for high-resolution printers.)
Thanks for contacting Fixya.
Posted on Jul 02, 2009
The copies are not clear, they are fuzzy... its like somehow the reader is out of focus. have lots of toner and paper. we cleaned the glass and the spf roller and spf scanning window??
Have seen this problem before and if i remember correctly it is down to the fuser running at the wrong temperature. To prove this , make a copy. try and judge when the paper has left the drum but before it reaches the fuser. Open the side cover and very carefully remove the paper. look at the image. if it is clearer then it is the fuser. If it is still fuzzy then the problem lays in the development area.
Jun 18, 2011 | Sharp AL 1631 Copier
Photos are fuzzy
as you take a picture ( scene w/o flash ) slightly press the snap button and wait till red or green box appear, if red box, out of focus. if green box in focus. when green box, make sure you and the focus are very still, then take a clear picture, pressing the button all the way. make sure no shaking as press button either.
Mar 17, 2010 | Samsung S760 Digital Camera
Cant get blade out
Wear leather gloves or double rubber gloves. Hold on right on top of the sharp blades and turn it. You can also bend a 1/8 th inch diameter thick wire, galvanized or anything metal and insert both ends on the holes on the blades and turn it. Make sure you don't slip your hands on the sharp blades.
Jack Lalanne Juicer Manual
http://www.myeasypics.com/is.php?i=665112&img=1.jpg
http://www.myeasypics.com/is.php?i=665113&img=2.jpg
http://www.myeasypics.com/is.php?i=665114&img=3.jpg
http://www.myeasypics.com/is.php?i=665115&img=4.jpg
I hope this helps.
Dec 21, 2009 | Jack Lalanne Power Juicer 250 Watts
I cant take the strainer to clean it please let me know what to do thanks.
I hope this helps.
Oct 20, 2009 | Jack Lalanne Power Juicer 250 Watts
Blurry picture
If you know where the fly back is, ok open the casing and see at the back of the fly back, there are two knobs, one for the focus and the other is for the brightness. Try twist both and see which one is for the focus. Ok, from the focus knob try adjusting until the fuzzy sight disappears. Try this, I usually do it to screens with blurry appearances.
Nov 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
35mm scan not in focus
You need to uninstall and do a clean install of the drivers (software). If you do not have the CD you can download the driver here:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=58773&infoType=Overview
Be sure that when you download a new driver and install it, that you turn off all running programs including your virus/security control. You can turn it right back on when the drivers are installed and you restart the computer. Good Luck.
Aug 14, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Fuzzy/ not very sharp pictures
If the photos look pixellated, perhaps you've turned down the resolution/quality setting? Check the manual for how to correct this.
If your photos seem generally hazy, your lens could need cleaning. Use a lint free cloth such as one for cleaning spectacles.
If all your photos have a smooth, out of focus appearance, it could be a camera fault. However, if you've recently been taking photos in poor light without flash, it could also be "camera shake". You can distinguish this from out of focus because the blur is slightly directional rather than being smooth in all directions. Points of light become lines not blurry discs.
Jun 22, 2008 | Samsung Digimax A402 Digital Camera
One channel fuzzy
Tis is an ongoing problem I seen increase alot over the past few months. From what I can gather, all the channels being broadcast over going from the analog to digital, there's no big suprise to anyone. However, the change from analog to digital is changing at a faster rate, so when you look at the TV some channels will be fine and others will have grey lines, fuzzy picture. The only solution-you need a TV with some kind of digital tuner. On the TV itself if the (TV has one) it will say "SD" or "ED" which stands for standard digital or enhanced digital.
Jan 25, 2008 | GE 27GT277 27" TV
Fuzzy pictures
Go back to film. Digital SUCKS.
Dec 21, 2007 | Casio Exilim EX-Z50 Digital Camera
Distorted Scans
it could be your not scanner in a high enough resolution. I believe negatives have a 1000 dpi.
Oct 31, 2007 | Epson Perfection 4180 Photo Flatbed...
Pacific Image Powerslide 3650 Logo
47 people viewed this question
Top Pacific Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you a Pacific Office Equipment and Supply Expert? Answer questions, earn points and help others
