Question about DeLonghi Trane 5t Rooftop Air Conditioner Ycy060g1m0ad
To much condensation in the coil, this is a chill water system
To much condensation in the coil, the fans are working okay, also is draining okay.
  • 158 Answers
Thermostat set too low or it's just too much humid in the air
Posted on Jul 02, 2009
My frigidaire air conditioner is making my apartment feel damp and when i took my filter out to clean it that part was damp too! What do I do to fix this?
You may have a clogged drain or the unit is installed without enough angle pitch for the water to drain to the back of the unit toward the outdoor section of the unit. I'm assuming it's a window air conditioner? The moisture condenses on the cooling coil near the filter and should drip down into a condensate drain pan, then the water should drain to the back of the unit into a pan at the condenser coil fan that is rejecting the heat outside. The fan blade usually has a ring on the outdoor fan that pick up the condensate moisture the fling accumulated water onto the hot condenser coil to evaporate it. Also the filter should not be touching the cooling coil. Make sure it in the correct slot. Some a/c cooling coil require a wetting agent that allow the water to slide down the coil and not pull off of the coil into the indoor circulating fan.
Sep 11, 2015 | Frigidaire Heating & Cooling
Tip
Cleaning Air Conditioner Condenser Coil with Pictures
The most important Air Conditioning maintenance that needs to be done every year is the cleaning of the condenser coil. Doing the job of cleaning the A/C coil is the best way to make sure that your air conditioning system is working efficiently and giving you the best performance possible.
The tools needed to do the air conditioner condenser coil cleaning will be:
Garden hose with nozzle
Garden pump sprayer
Condenser coil cleaner (can be purchased at HVAC Supply houses, or many hardware type stores)
Hand tools needed to remove condenser fan
To do the job correctly you will need to first turn off the power to the unit and remove the condenser fan.
Once the condenser fan is removed then, you should wet down the condenser fins with a garden hose. Use nozzle that will give you a high volume spray but not with high pressure. Too much pressure will bend the fragile fins and cause them to shut off the ability of the air to flow through them, this is want you want to avoid. You want it to be as easy as possible for the air to get through the fins, for the best possible heat exchange.
After wetting the fins, you then will need to spray the fins inside and out with a foaming coil cleaner. Make sure to wear eye protection and hand protection. If you have sensitive skin, you may also want to wear long sleeves to protect exposed skin. I buy it in a concentrated formula then dilute it with water to the proper working formula. You may need to go over the fins a couple of times with the coil cleaner to get it worked into the fins. Allow the coil cleaner time to work the dirt loose and boil it out of the fins.
After about fifteen minutes start to rinse the coils with fresh water. This will take a long time and lots of water to fully rinse the coil cleaner from the fins. It also is very important that you get everything rinsed fully. Failure to do this will result in excessive dirt accumulation and also can cause corrosion. Make sure that the water is running clear and that all bubbles are gone before stopping your rinse.
Then reassemble the condenser fan, turn on the power, and check the operation of the unit. It is okay to run the unit immediately after washing it. The water will not hurt the unit.
You now will have an Air Conditioning unit that will give you the best possible performance!
on May 15, 2011 | Heating & Cooling
Freezer not getting cold and dripping water
I own a similar Kitchen Aid fridge that had a defrost icing issue: Kitchen Aid KSRP25FNBL00
> Ice had plugged the drain hole at bottom of chill coil section inside the freezer compartment.
> I learned that the coil, circulation fan was not working, but condenser was working.
> I paid a tech to replace the circ fan, about $200, including a new swiss-made fan. He said it was unusual for these fans to fail, but not unheard of.
Expensive, but saved the purchase of a new fridge. Has worked great for 6 months since then.
HOpe that helps.
Al Zayha
Mar 09, 2014 | KitchenAid (KSRD22FKST) Side by Side...
Our Amana fridge freezer has stopped chilling and freezing
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 26, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Water dispenser does not dispence water
need to replace the water inlet valve. the part number for this model is 4389178
Jun 18, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Water seems to be draining from the freezer into the fridge, making the drawers all wet
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Mar 22, 2010 | Whirlpool ER2MHKXPL 22.0 Cu. Ft. Freezer...
Kenmore 18 top freezer doesnt freeze completely. refigerator cools to 48 f .
possible causes: bad door seals or condensate drain plugged causing evaporator coils (in freezer) to ice up, condenser or evaporator fans not on, condenser coils dirty, compressor not working, or a freon leak. if the back wall of your freezer is frosty or super cold, the coils are iced up. remove the back wall and defrost it with a hair dryer. if the water doesn't drain, unclog the drain tube. check the door seals for gaps. replace if necessary. check the fan in the freezer and the fan in the back. both should come on when the compressor is on. if not, check the fuses on the main board. replace if needed. if all that is fine, and there is no frost, you have a slow leak or a bad compressor. call in a pro or get a new fridge.
Nov 12, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Doesnt get cold??
Okay,
Defective compressor, refrigerant low from a leak in the system, dirty condenser coils, condenser fan not working, bad compressor relay or capacitor, main thermostat control not working, thermostat needs to be set at proper setting, frozen evaporator coils do to faulty defrost timer, defrost heater coil broken, or the defrost determination thermostat has stayed in the open position, which would result in no defrost and the ice blockage would stop air the circulation, defective evaporator fan, defective door switch which controls the evaporator fan when one opens and closes the freezer door. Freezer drain clogged which would possibly cause the fan to be stuck because of ice built up around it.
Oct 13, 2009 | LG LFX25971ST Bottom Freezer French Door...
The coil has to much condensation, the coil is clean and the drain its okay, also the fan is working okay, I dont know what is the problem
make sure drain has a trap so it wont **** outside air into unit and cause a vaccume in evap. compartment which will cause the water not to run out correctly.
Jul 02, 2009 | DeLonghi Trane 5t Rooftop Air Conditioner...
Water in housing
You will need to clean the evap coil with a bleach type product and then hose out the condenser coil as well. The bleack will also remove algie from the evap water pan. THX RepairUSA
Aug 26, 2007 | Goldstar R5050 Air Conditioner
DeLonghi Trane 5t Rooftop Air Conditioner Ycy060g1m0ad Logo
67 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
