Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
Won't start - gas is leaking out
Had been having trouble starting and keeping it running.
Will not start and is now leakig fuel when I am trying to start it.
    President:
  • Poulan Master
  • 1,545 Answers
If the gas is leaking out of the carb, then it is most likely flooding and the needle valve possibly is being held open by some stray debris. Carb needs to be removed and checked....possibly even rebuilt as older models require this periodically.
Posted on Sep 20, 2009
My 2008 Equinox smells like gas even when it isn't running. No gas leak under the car, and the car runs good. Some trouble starting the car but does start.
What engine does it have ?Engine Controls and Fuel - 3.4L
Engine Controls and Fuel - 2.8L, 3.0L, 3.2L, or 3.6L
Do you know how to test for leaking fuel injectors , leaking fuel pressure regulator ? Check engine light on ? Videos on youtube showing how . Need fuel pressure gauge injector balance tester . Hooking up a professional type scanner an checking fuel trims , O2 sensor switching rate .
Fuel Injector Balance Test
Other videos testing for leaking injectors .
Apr 08, 2018 | Cars & Trucks
2004 chevy cavalier wi'll not start unless I keep my foot on gas. Then it will start but won't stay running until it warms up. While driving it runs fine untill you brare then it stalls out.
Pressing the pedal down, puts in clear flood mode. Any applicable trouble codes? Did you use a gage and check correct fuel pressure, also, see if pressure will hold for a bit, with everything off. If it drops like a rock you have fuel leak. Pull vac line off fuel pressure regulator, where applicable, if fuel runs out, you have a faulty fuel pressure regulator. You could have fuel injector leak?
Smell of your crankcase oil dipstick, if it smells like gas, either you don't change your oil and filter very often or fuel leak. There could be other issues? You have to start testing, somewhere.
Mar 09, 2017 | 2004 Chevrolet Cavalier
Gas leaking when key turned to run position
Hi, Joshua fuel leaks are dangerous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your problem. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Leaking gas valve letting fuel into your engine cases
Star 650 won start and is leaking gas
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-36_96.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Dec 26, 2012 | 2007 Yamaha V Star 1100 Classic
I have husqvarna 136 that won't start. If you put gas in carb it will start but won't keep running.
Replace the fuel filter in the tank, check the fuel hose up to the carb for signs of leaking, if so replace the line, between the cylinder and the carb back plate is a rubber induction tube, make sure this has no split.
Oct 14, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Motor turns over won't start. Cleaned terminals, put in new battery, still won't start. Removed gas cap to vent air on hot day, still won't start. Lights all come on, all electrics appear to...
Your problem may be one of the following:
First check or just replace the fuel filter. Usually located under the car in front of the rear axle, drivers side.
Next, the fuel pump may be worn out. Usually they get loud or stop working (running).
Next, check the fuel pressure regulator. Usually located on the front fuel rail, drivers side.
Is the vacuum line attached? Not leaking or rotted?
Also, do you smell a strong fuel odor when it won't start? May be one or more stuck-open injectors, or the coil pack is bad.
Checking these in the order listed will more than likely fix your problem.
The clicking noise indicates the battery can no longer run the starter, which also means the fuel pump won't run either.
It could be a fuel issue. How old is the fuel filter? Can you hear the pump run for a few seconds when you turn the key on? Try turning the key to ON without trying to start engine three times waiting for the pump to stop running each time. Then try to start the engine. If it starts, Its a form of Vapor lock caused by the extreme heat we have had lately, and a weak fuel pump.
If none of this works, try a new fuel filter first. From there have someone check the fuel pressure regulator and then the pump. If you are in need of a new pump, take my word for it and spend the money to get one from a Dealer, and not from your favorite parts store. Most parts store parts are made in China and they are JUNK.
Aug 28, 2011 | 1997 Chevrolet Blazer
My 2007 Yamaha V-star Classic 1100 won't start and is leaking some kind of fluid, possibly gas. It was running fine until a few days ago. It is low on gas, but not completely empty. It started up,...
Hi, Dan and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
Star Classic leaks fuel behind the air cleaner
Star 650 Post GAK Troubleshooting Fuel Leak from Vent Hose
Aug 22, 2011 | 2007 Yamaha V Star 1100 Classic
Trouble starting my 1992 cav. 2.2. New battery, starter ok, new plugs, can start with ether and then idles and runs fine. Seems like I do not have that initial fuel??
well there is a fuel pressure regulator which keeps pressure on, even while engine is off. i would suspect it is bad, or you have something else leaking pressure off while the engine is not running.
Jan 20, 2011 | 1992 Chevrolet Cavalier
1998 gmc suberban ran out of gas and cant start it??? i put gas i
It's never a good thing to let Fuel Injection run out of Gas. The Fuel pump runs on Low Voltage and has a Hard time Restarting. Could also have had some (Gunk) at the bottom of the Tank that got into the Fuel System. Keep tryin to start Her for a while and see if the Pump won;t pick up. Also got a Long way for the Fuel to go to the Motor in that Suburban! Let me Know!
Jan 02, 2009 | 1998 GMC Jimmy
Help w 1994 chevrolet truck
This injector set-up needs a specific fuel pressure supplied to the fuel rail to even start, much less run properly. The fuel pump is immersed in fuel inside the gas tank to keep it cool and not burn up. Running the fuel level low causes more heat in the pump and interuptions in proper fuel pressure. AC/Delco pumps have proven to be a reliable fix, the aftermarket pumps only last for a month or two sometimes. Check fuel pressure under the hood and power and ground to fuel pump at electrical harness at top of gas tank. This truck needs a fuel pump.
Aug 18, 2008 | 1994 Chevrolet C1500
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
268 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
