Question about Packard Bell Easy One Silver 2120 Notebook
Doesnt boot up
Turn on it starts up displays packard bell screen sometimes will show windows start up screen then reports disk read error ,swapping to CD as boot drive and trying to boot using a windows CD doesnt work either, it will boot to DOS from a floppy but if I use an NTFS floppy it doesnt go resident
  • Blackchuck Nov 10, 2007
    Hi Poohawk
    Thanks for the response
    there is no problem entering Bios it correctly identifies the hard drive (set on auto) the CD drive and floppy
    I can as mentioned in the first post swap to CD as first boot drive and with a bootable CD in it still says read error
    the error when booting from a floppy says unable to mount drive ,no ntfs drives found even though the BIOS finds it.
    both Hard drive and CD (dvd) drive are set as master on primary and secondry respectivly
    I build and repair computers and if this had been someone elses lap top I wouldnt even let it cross the threshold let alone look at it ,I never touch them,consequently I know nothing about their peculiaritys ,any advise would be appreciated
    Thanks Peter
    Thanks for the suggestions
    Following your suggestions is probrobably the only chance I have of recovering this ,I have not flashed the BIOS but a currupted BIOS would explain the problems, I suppose a power spike could do it
    The OS cd I tried to boot with was a Microsoft XP OPK cd
    Memory?? or motherboard?? on a desktop 2 screws to take the side of, on a laptop after the screws are out the machine will probably weigh half what it did and this is always assuming you have been on a course in chinese metal puzzles in order to find them.
    I have repaired one laptop because I knew what the problem was
    it took me over two hours to take it apart 5min to fix and almost 3 hours to put it together again (not a small desktop a fiendish invention)
    once again thanks for your response ,I will let you know if I am successful
    Regards Peter
  • 324 Answers
Hey, Blackchuck, try this
When you power up, try to get into BIOS and see what you get.
Let me know and we'll go from there.
Posted on Nov 09, 2007
  • Ron Roske Nov 10, 2007
    And a good morning to you, Peter,
    Had to chuckle when I read the last paragraph of you last message. I take it that you mainly work on desktops and pretty much stay away from laptops? ;o)
    And, from what you have said so far, I'm sure that you understand that I am somewhat at a disadvantage because I don't have the system here in front of me.
    OK! Now to the problem at hand.
    I will assume that you've done all of the basic things-assuring that the proper voltage is coming out of the ac adapter, gone in to reseat all of the cable connectors and attached devices and so forth.
    From your description of the problem, at this point, I can only see maybe 4 things that might be causing the issue.
    1. Corrupted BIOS-Have you flashed that, and verified that you are at the latest level?
    2. Bad memory- Have you run a good memory test, (Mem+86 is what I use), tried running with just one RAM chip, swapped out to another RAM chip, etc?
    3. Corrupted OS-Recovery disks, OEM os disks, etc
    4. Bad system board. ;o(
    An additional thought might be to bring it up bare bones. Disconnect/remove anything not needed. Try to bring it up with just the following:
    External display.
    Hard Drive (or, CD, as you chose)
    External keyboard.
    No touchpad, wireless card, floppy, battery, etc.
    Do a mind-set reset. Just ask yourself the question " How would I approach this if it was the same problem on a desktop system?"
    Just look at it this way. A laptop is just a small desktop that the parts are harder to get to, and a desktop is just a large laptop that is much harder to move around.
    Hopefully, I've been of some help?
    My friend, I'm with you on the screw thing. Zillions of them and they are small!! Ever try to find one of them that you've dropped on a carpet? That's why I have a magnet in with my tools!
    Best of luck and I can help, let me know. I'll be looking forward to seeing the information on the successful resolution of this issue.
    Have a super day!
Hello, I have a Packard Bell branded laptop displaying the error there is no boot disk see details and the photos in first comment to know what happens and did someone can help me with it?!
If you set the boot order to USB first boot device and HD second. Insert USB and boot from there. It should find your HD and then you can install your OS. Another system for a different laptop will not work!
Jun 15, 2016 | Packard Bell Computers & Internet
Packard Bell OneTwo M3700 PC boots up but no display
most of the time on older monitors you can set the refresh rate in safe mode and that will, most of the time, resolve the problem otherwise time to purchase a newer monitor.
Jun 26, 2015 | Packard Bell Computers & Internet
Error 0xc000000f while formatting hard drive
try some formating toos .. like hiran boot cd or disk or diskformater ...u can use usb bootable device to install windows, u can make ur personal pen drive to bootable pen drive.
Jun 02, 2013 | Packard Bell Computers & Internet
When the computer boots, it display bluescreen
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.If after running the Check Disk Utility you still have problems you will probably need to reinstall windows. Look into doing a Repair Install so that you don't lose your data.
Apr 24, 2012 | HEWLETT-PACKARD 630 Notebook
My packard bell monitor keeps presenting a blank screen. When the computer is turned on, it starts up as normal but then just after the MS screen appears, it turns off and won't show anything on the...
Try this for starters. Shut down the computer like you normally do. Next turn it on and while its booting up press the F8 key(keep tapping it). You should get a menu and on that menu, one of the choices is Safe mode. Select it and press enter. This will boot your computer into a Diagnostic mode where you can troubleshoot hardware software and windows problem in general. If you successfully get into safe mode answer yes to the question it asks and then goto your Device can get there by rightclicking the mycomputer icon and select properties from the drop down menu then select the Hardware tab on top.and click DEVICE MANAGER. In this screen look for your display adapter..higlight your graphics adapter and right click...then select reboot your computer normally this time dont press the f8 key..gointo WIndows normally. This should reinstall your graphics card and possibly fix the problem.
Jun 17, 2010 | Packard Bell FT500 15" LCD Monitor
Cannot get recovery disk for my computer to work
ok what you need to do is put the disk in the cd drive then shutdown your pc then start it again wen the first screen shows up usually displaying the brand name with some options at the bottom of the screen select the option, boot options and select boot from cd rom and that should start the recovery process which will guide u through itself
Aug 31, 2009 | Dell (TD789) GeForce 7800 GTX, (256 MB)...
Display problem
You don't have a display problem, you have a hard drive problem.
It is probably a file system corruption.
Insert the Windows XP install disk into your CD drive and boot to it. At the first setup screen, press R to repair windows from the recovery console. Once the recovery console loads, type
chkdsk /r and then press Enter. Once this finishes, remove the CD and reboot. With any luck, you will be able to boot successfully, if not, come back and give details about what happens.
Mar 06, 2017 | Packard Bell iMedia 6826 (P481000502) PC...
Try another screen saver for starters. If another screen saver works than the Vista screen saver may be missing from within the Windows directory.
Dec 20, 2007 | Packard Bell PB 3.2GB IDE 3.5 Packard-Bell...
Hi, sounds like your hard drive is going/gone flaky...  & if so ya gonna haveta get a new hard drive & a Windows Operating System.
Or take it to a good PC repairer, and get a quote and  explanation.
Oct 15, 2007 | Computers & Internet
Packard Bell Easy One Silver 2120 Notebook Logo
357 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
