Home | Apple | (MA589LLA) (APP MA589LLA) Mac Desktop | I also can not move fol...
Apple Mac Desktop
Problem for Apple (MA589LLA) (APP MA589LLA) Mac Desktop
I also can not move folders to another hard drive
By rjohnson4525 on Jul 02, 2009
I can login from another mac and copy the folder, then I can go back to original and delete.
But the system doesn't allow moving at all!
Solution #1
posted on Jul 07, 2009
Not Rated)
darksidegds
Rank: Master
Rating: 91%, 7 votes
you need to check the files permissions. either you will need to fix the permissions by using the Disk Utility or you will have to click on the folder in question. press on the keyboard Command + i ( information for folder) then on the bottom of the window there is the sharing & permissions section. if you want to be able to move, copy, delete and read from that folder you will need to set it here.
If the little lock in the bottom right corner is locked you must click on it to unlock it, then enter in the admin password. once you set the privileges for each person or persons, you should click on the sprocket with down arrow. And specify if this setup is for only that folder tier or apply the same setting to all inclosed files and folders inside that folder.
if you do not do that last step then you will have that same issue again.
Was this helpful?
Yes
No
Popular Solutions for Apple Mac Desktop
Questions and Unsolved Problems for Apple Mac Desktop
Do you recommend Apple (MA589LLA) (APP MA589LLA) Mac Desktop?
Answer
Answer
mi Mac despues de arrancar unos segundos despues se va a dormir (sleep) de manera automatica y se ve... (More)
Answer
my destop will clear it self every wednesday and clear the setting of my font extension and quark... (More)
Answer
20'' Core 2 Duo iMac 2.16 Ghz Intel Duo , bought in 2007 does not boot past blue screen
Answer
Mac DVD burner TSST CDDVDW SH-203N LA00 Firewire EXTERNAL drive for iMac and Snow Leopard OS 10.6.1... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Apple Mac Desktop:
Top Mac Desktop Experts
Rank: Guru Guru
Solutions: 1447
Experience: Self taught, Keep up with the manufacturer's service manuals, Beta Tester
Ask Me
Find more Mac Desktop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
