Question about Nextar X3-02 GPS Receiver
My x3t is frozen at logon screen help - Nextar X3-02 GPS Receiver
  • 2,200 Answers
Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In this case you must return the unit for exchange or repair to the retail location from which you purchased it, or contact Nextar for further assistance.
For technical support for your Nextar GPS see http://www.nextar.com/frontend/support.asp or you can phone them on 888-849-0846
Please remember to rate my answer. Thanks.
Posted on Jul 07, 2009
Tip
Applying the settings to the logon desktop
Next, you need to apply the Screensaver settings to the Logon Desktop / Welcome Screen (Technically, HKEY_USERS\.Default registry key), so that the Screensaver is invoked when no user is logged on. Copying all the Screensaver settings to the Logon Desktop (or Welcome Screen) manually is a tough task. Use Tweak UI instead.
Download and install TweakUI.
Launch TweakUI and click Logon, click Settings.
Select Screensaver from the list box and choose Copy Now
The Screensaver settings are applied to the Logon Desktop
Restart Windows for the changes to take effect
Allow few minutes at the Logon screen, to test if the Screensaver is working properly. The Screensaver should launch after the timeout. It will look as if the Company Logo moves around.
Additional Tip
The User interface / slider allows the minimum value for picture change interval to 6 seconds only. To reduce the change interval to less than 6 seconds, alter the registry value named ChangeInterval (Set decimal value 1000 for 1 Second, and so forth) in this key:
HKEY_USERS \ .DEFAULT \ Control Panel \ Screen Saver.Slideshow
For Current user profile, make the change here:
HKEY_CURRENT_USER \ Control Panel \ Screen Saver.Slideshow
With no logon wallpaper set, Windows displays a pre-defined color for the logon desktop. ( If you have enabled Welcome Screen, press CTRL+ALT+DEL twice to see the logon screen background color. ) To change the logon background color to that of your choice, you need to alter the registry:
Click Start, Run and type REGEDIT and press Enter
Navigate to the following key:
HKEY_USERS\.DEFAULT\Control Panel\Colors
Backup the registry key by exporting to a REG file
In the right pane, double-click Background
In the Edit String dialog box, type the Color code in R G B format and then click OK.
Example: Type 0 0 0 if you want to see a Black background. You can choose any combination from 0-255
Points to ponder
If the logon Wallpaper is set, the background Color may not be visible. So, you must reset the Wallpaper value to a blank string in this key: HKEY_USERS\.DEFAULT\Control Panel\Desktop
If the Background value is set under the following Winlogon registry key, the above setting is ignored. In other words, the Winlogon\Background value takes precedence over the .DEFAULT..\Background value.
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
DigitalPersona not visable on Windows XP Logon Screen
Don't connect to the internet with Windows XP, it is too dangerous.
May 20, 2017 | DigitalPersona DIGITAL PERSONA USB...
I have a dell dimension 5100, although i did not put in a password, at the logon screen each logon is asking for a password! please help before i hit it with an axe!!!! Paul
If you let me know the Operating system type, i can help you better, well try this.. actually this is for windows Xp, when you get onto the logon screen, press "ctrl+alt+delete" simultaneously several times, you'll be presented with a different logon screen (dialog box), type "administrator" in the logon name and press enter/Ok. I hope that you've tried blank passwords. Anyway Good luck and let me know the operating system type if you still get time before you turn into the real ....
May 27, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Last nite i was playn a app off my ipod 2nd gen and it froze now it wont even cut back on wtf plez help or u can have it
if your Ipod is frozen you might just need to reset it. Just hold both the power and the home keys for about 10 seconds and the screen should go black. after a couple of seconds press the power button and wait for the unit to boot back up. you should be back at your home screen or logon if you have password protection.
Oct 23, 2009 | Apple iPod touch Second Gen (8 GB,...
Having a problem...when I leave my computer for a length of time it returns to the log on screen, but becomes frozen. I can't turn it off from the front button. Must unplug then reboot...this has just...
There are two ways to do it.
1) when the logon screen appears, enter your password (if no, just press enter), you will be back where when you leave.
2) set the screen protection off by: clicking right mouse button on the desktop -> screen protection -->in screen protection box select none --- OK. Then, no logon screen will appear.
Try it.
Oct 17, 2009 | Dell Dimension 9100 PC Desktop
My gps is saying waiting for signal and just stands still. name brand is nextar x3t.
I HAVE A NEXTAR GPS SYSTEM AND IT KEEPS SAYING WAITING FOR A SIGNAL I RESET IT AND IT IS STILL DOING THE SAME THING.
Jul 15, 2009 | Nextar GPS
Hey i wanna change my logon screen how can i download a software for it tell me i can get it from your site or don't?
http://www.vistax64.com/tutorials/79886-logon-screen-change.html
This site provides a program as well as instructions on how to change your logon screen. Good luck!
Jul 10, 2009 | Alvarion Computers & Internet
Hp nc6230
hello there,
U can try booting into Safe mode with networking option.
If you log into a limited account on your target machine and open up a dos prompt
then enter this set of commands Exactly:
cd\ *drops to root
cd\windows\system32 *directs to the system32 dir
mkdir temphack *creates the folder temphack
copy logon.scr temphack\logon.scr *backsup logon.scr
copy cmd.exe temphack\cmd.exe *backsup cmd.exe
del logon.scr *deletes original logon.scr
rename cmd.exe logon.scr *renames cmd.exe to logon.scr
exit *quits dos
Now what you have just done is told the computer to backup the command program
and the screen saver file, then edits the settings so when the machine boots the
screen saver you will get an unprotected dos prompt with out logging into XP.
Once this happens if you enter this command minus the quotes
"net user <admin account name here> password"
If the Administrator Account is called Frank and you want the password blah enter this
"net user Frank blah"
and this changes the password on franks machine to blah and your in.
Mar 24, 2008 | HP Compaq nc6320 Notebook
Microsoft Fingerprint Reader
If a screen popsup requiring user input is it possible that the screen you are referring to is getting shot down by a popup blocker?
Sep 23, 2007 | Microsoft Fingerprint Reader
Nextar X3-02 GPS Receiver Logo
382 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
