Question about Samsung Televison & Video
PEOPLE IN PICTURE APPEAR FAT AND SHORT - Samsung Televison & Video
  • 304 Answers
First check your source such as a Cable box or Sat box. The problem is that the Aspect Ratio is set incorrectly. It might be set wrong on the tv as well.
Posted on Jul 17, 2009
    Problem Solver:
Why does all the people look wider than they are i have my tv set to 16.9 (2 do you know a good aeriel guy the last one just cut into foxtel so now i ca not get free to air in HD do inside ones work
Posted on Aug 18, 2009
Techview DVR - people look short and fat onscreen
resolution is pixel settings
you need to change the aspect ratio
Oct 02, 2016 | The Home Security
Tip
How to fix No Bootable Media Error Message
FAT (File Allocation Table) is one of the most widely used file systems used now-a-days with various versions of Windows operating systems and memory cards. Every logical partition contains a FAT that consists of file allocation information and the information of free allocation units that need to be assigned to files. Although the FAT file system is reliable, corruption still occurs due to various reasons. In such situations of FAT corruption, your system becomes unbootable, resulting into inaccessibility of data saved in FAT based hard drive. To access the data after FAT file system damage, an easy way is to restore the data from an updated backup. But, with inaccessibility of data backup or backup falling short to restore the required data, an ideal option left is to use an advanced FAT Data Recoveryapplication that can recover the lost data.
To illustrate the above scenario, consider a practical case the below error message pops up when you attempt to boot your system:
“No Bootable Media”
As the above error message appears at the time of booting the system, you wont be able to access the data saved in the hard drive.
Cause:
The above error message because the FAT file system has been corrupted. Few main causes for file system damage are improper system shutdown, human errors, and virus attack.
Resolution:
To isolate the above error message and to access the data after the above error message appears, you will need to follow the below steps:
Run CHKDSK utility to repair the FAT file system. If the problem persists, format the hard drive.
While the latter resolution resolves the above error message completely, it also deletes the data saved on your hard drive. In such cases, if the backup is not available, then you can only recover your formatted data by using an advanced third-party FAT Data Recovery software.
A FAT Partition Recovery utility thoroughly scans a FAT based hard drive and recovers almost all data, even after formatting. The data recovery utility can be downloaded from the Internet.
Stellar Phoenix Windows Data Recovery is an efficient FAT Partition Recovery tool that recover lost, deleted, and formatted data from both FAT (FAT12, FAT16, FAT32, VFAT) and NTFS (NTFS, and NTFS5 ) based hard drives. The detailed help manual attached with the tool allows even a new user to perform recovery easily without any technical knowledge. It supports Windows 7, Vista, XP, 2003, and 2000.
on Jun 30, 2010 | Computers & Internet
File error appears on screen when viewing pkotos
can have different causes. To many pictures on the memory card card is full. From the last picture file name ends with 999 or 9999.
Or there was an error while writing a picture to the memory card, caused by a power failure.
I would put the card in an external memory card reader and try to put all pictures in a folder on the computer. Then format the card FAT 32 or FAT 16 and then put it back in the camera. When switched on, first format the card again, in the camera, to make sure the camera can work with the card and the format.
Success.
Apr 19, 2015 | Cameras
PEOPLE ON SCREEN ARE SHORT AND FAT HOW DO I CORRECT THIS
Change the picture settings back to factory settings:
Select Menu, select Picture
Select Reset
Press Enter
Press Menu to return to viewing.
You can download a copy of the manual at
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
If you need to further adjust the picture.
Please rate this solution. Thanks.
Oct 05, 2010 | LG 42LG30 42 in. LCD HDTV
Bad turn signal
The turn signal flasher appears defective. Chk bulb in tail light for burnt short fat filiment.
Jun 13, 2009 | 1995 Chevrolet Caprice Classic
Monitor appearance is short and fat
set the resolution to its native resolution 1440 x 900 this should correct things.
Oct 07, 2008 | Gateway FPD1975W 19" LCD Monitor
Images are too fat looking or spread out on my 22" monitor, how do i adjust so the images appear normal?
You need a video card that will adjust the resolution to the proper proportion. The closest I can get to a good aspect ratio is 1152 x 864.
Sep 28, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
How do I get body fat help?
The scales don't tell you the whole picture - your weight is less important than your percentage of body fat when it comes to appearance, fitness, and health. Tracking your percentage of body fat better shows how you are doing with diet and exercise than measuring weight. Remember that weight is measuring not only your fat, but also you muscles and your bones. If you did some extra work at the jym, your body weight might be effected (muscle tissue is heavier then fat tissue).
Aug 27, 2008 | Detecto Portable Digital Visiting Nursing...
Display appearing stretched
the original image size was probably recorded in 4:3 aspect ratio...meaning your widescreen is a 16:9 ratio size screen and is stretching it outwards to fill the whole screen. If you want the image to look normal.. ie. not short and fat people.... you need to change the picture size in the settings from widescreen 16:9 to normal 4:3 tv in the settings menu most likely...Also most remotes will/should have a button for that.
Oct 26, 2007 | ViewSonic VA1912wb 19" LCD Monitor
Televison & Video Logo
119 people viewed this question
Jerry Greenberg
Jerry Greenberg
