Question about Refrigerators
ADMIRAL HG 22524 REFRIGERATOR NOT GETTING COLD IN FRIDGE ONLY.....FREEZER WORKING FINE... DO I NEED TO ADD FREON ???
  • 61 Answers
Try defrosting the unit.. May be ice buildup in vents between freezer and fridge. Freon is in sealed unit. Should not have leaked out..
Posted on Jul 02, 2009
We have a Admiral Top Freezer Refrigerator Model#
sounds like a defrost problem. if the freezer section gets too much frost build up then it wont be able to move air into the refr section. check to see if you have "heavy" frost in the freezer and if so then a defrost thermostat or a defrost control board may be you problem.
Nov 02, 2013 | Admiral Refrigerators
Admiral side by side, freezer working, fridge not getting cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Admiral 26 cu. ft. Side-By-Side...
The refrigerator is not cooling, the freezer is working fine.
heatman101
Jul 07, 2011 | Admiral Refrigerators
Freezer part is working fine. fridge part is barely cool on the highest setting
Sounds like your cooling tube ia blocked by an ice buildup or something. Some refrigerators have a fan to draw the cold from the freezer to the refrigerator and if the fan quits, then the cold is not drawn out of the freezer.
If it isn't a frost free freezer then it is probably just a case of needing to defrost the freezer.
Jun 01, 2011 | Admiral Refrigerators
My Admiral freezer is cold but not freezing. The fridge seems fine but food in the freezer is thawing.
See if the coil is clean, if not, vacuum and brush the coil clean.
That should make diagnosis much easier.
Jan 09, 2011 | Maytag Admiral Top-Freezer Refrigerator
I have a 19 cu.ft. refrigerator. Freezer seems fine but fridge is intermittently functioning. Can I fix this myself or I need help from specialist?
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 29, 2010 | Admiral Refrigerators
The fridge is cold but the freezer won't freeze
The grill being the condenser coil- The sealed system is low on freon or the compressor isn't working correctly.
Jul 01, 2009 | Frigidaire FRS3R5EMB Side by Side...
Trubleshoot refrigerator staying cold enough
First review the troubleshooting steps in the instruction manual. Check the freezer and frige temperature setting control knobs. Make sure the fan, coils, compressor etc. are clean. Check the door seals, especially at the bottom. If all that does not work, do some more online research (which is what I'm up to right now because I am faced with the same problem).
Sep 02, 2008 | Admiral 26 cu. ft. Side-By-Side...
All the cold air from your freezer gets pushed into the fridge with a fan in your freezer section. So your problem is from the fact that this cold air isn't get to your fridge.
- the door that allows this cold air into the fridge, normally in the top left corner of the fridge, is stuck shut and needs replacement.
-the freezer isn't defrosting and restricting the air flow
-the temp controller for the fridge is damaged and thinks that the fridge is cold enough.
Nov 15, 2007 | Admiral 26 cu. ft. Side-By-Side...
Admiral - GC2224GEKB
Does freezer cool like the cold food section? Did this suddenly happen, and frozen food began to thaw?  Most freezers control the cooling in the cold food section. The freezer must work fine before the cold food section will work fine. Let us know more, Thanks JT
Oct 24, 2007 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
135 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
