It does no obey to any commands other than lighting up with the letters (RC1)
RC 1 or DVD 1 is the unit's default remote command mode. You can try the following with the remote:
While the unit is on, pick up the remote, then press and hold [ ENTER/OK ] and the number [ 1 ] button together for 5 - 10 seconds, then release. Repeat the procedure if it makes no difference and the unit still ignores the remote. If it doesn't work, try new batteries, then repeat the above.
{ You can reset the unit if necessary (press and hold [ CH UP ] and [ CH DOWN ] button together for 5 - 10 seconds on the front panel (not the remote), until 'SETUP' appears in the display). }
Hopefully this should help a bit. You should not need to continuously reset either the main unit or the remote.
